I noticed in the switch from OE to LE the "Wait for Network on startup" wasn't honored in the OE settings but it seems all my other settings were like Time Server(s) and other settings. It really didn't effect my RPIs since they are slower to boot but my x86 box boots so fast it needed it or the mysql wasn't connecting. Just an FYI but I figured it out through troubleshooting.
(2016-04-17, 14:46)pyrodex Wrote: [ -> ]Just an FYI but I figured it out through troubleshooting.
Thanks, settings should in theory be copied across - not sure why "Wait for Network on startup" would be missed... odd.
Is there an updated service addon for the newest build (TVHeadend)?
(2016-04-17, 15:33)Ipaddle Wrote: [ -> ]Is there an updated service addon for the newest build (TVHeadend)?
Not yet, we still need to update the addon so that it builds against ffmpeg-3 - on the list...
(2016-04-17, 13:10)smiffy1989 Wrote: [ -> ]Here you go: http://sprunge.us/efUa
EDIT: and just in case it helps, here's a debug log after downgrading back to the 14/04 build: http://sprunge.us/OJEh
@smiffy1989: Can you try test build
#0417b it's the same as #0416 but has PR9621 reverted.
(2016-04-17, 16:49)Milhouse Wrote: [ -> ] (2016-04-17, 13:10)smiffy1989 Wrote: [ -> ]Here you go: http://sprunge.us/efUa
@smiffy1989: Can you try test build #0417b it's the same as #0416 but has PR9621 reverted.
Same problem here. Will test with the 0417b build in a view minutes and report back.
Edit: With 0417b build argustv is working again, thx.
OK thanks, unfortunately this needs fixing upstream so the problem will also be in tonight's build. I'll add a post on PR9621 that it's causing a problem, although the fix may need to be done in the addon.
The LE download server seems very slow compared to the OE server.
(2016-04-17, 18:14)Raitsa Wrote: [ -> ]The LE download server seems very slow compared to the OE server.
The LE download server has a 300/300Mbps connection so on paper should be good enough, but there could be local/peering issues. Additional mirrors will be added in due course.
Edit: I'm in the UK and just tried a download which maxed out my 20Mbps downlink, so not seeing a problem here.
Sorry I've been out and about all day. Glad to see it's been confirmed as an issue
This is why Kodi is so awesome!
How can I add a link to the LibreElec dev update to my OpenElec dev Update addon?
(2016-04-17, 20:42)Gregoire Wrote: [ -> ]How can I add a link to the LibreElec dev update to my OpenElec dev Update addon?
See
this post for a modified add-on that is supposed to work with these builds (haven't tested it myself).
What about to post here optimal video settings suggested in fritsch's egl topic ?
(2016-04-17, 21:11)Roby77 Wrote: [ -> ]What about to post here optimal video settings suggested in fritsch's egl topic ?
Anything in particular...? Maybe a link to the source would be best.
