first time that i try suspend funcition with this beebox so i don't know if it's buil related (0616) ( i remember that with oe and chromebox with same remote ir worked)
Maybe my fault but i could not resume from suspend using ir remote with libreelec , resume only with power button on remote
am i the only one ?
bios settings default
(2016-06-17, 11:37)Roby77 Wrote: [ -> ]first time that i try suspend funcition with this beebox so i don't know if it's buil related (0616) ( i remember that with oe and chromebox with same remote ir worked)
am i the only one ?
HI,
I'm able to resume from suspend mode using my ir with build 0615.
Suspend is pure luck game and won't change for the next years. If it works good - if not bad luck for you. Nowadays when systems boot within 5 seconds time there is absolutely no need for suspend / resume on non mobile devices. Even the AVR/ TV need more than 2 seconds to switch on ...
(2016-06-17, 11:49)Tequilla9 Wrote: [ -> ] (2016-06-17, 11:37)Roby77 Wrote: [ -> ]first time that i try suspend funcition with this beebox so i don't know if it's buil related (0616) ( i remember that with oe and chromebox with same remote ir worked)
am i the only one ?
HI,
Thank you will try with #615 and report
(2016-06-17, 11:51)fritsch Wrote: [ -> ]Suspend is pure luck game and won't change for the next years. If it works good - if not bad luck for you. Nowadays when systems boot within 5 seconds time there is absolutely no need for suspend / resume on non mobile devices. Even the AVR/ TV need more than 2 seconds to switch on ...
i was try a workaround for my black boot screen issue (after syslinux boot msg) cause my wife is getting mad (did i never talked about it to you ?
but maybe i found out another workaround
instead off reboot 2/3 times to get libreelec logo, if i power off and on again works works at first try
I don't get how can be a avr problem if is see Asrock logo and syslinux boot code
(maybe something isn't correctly killed at power off ? )
with chromebox same avr and tv no problem
i will check bios settings asap
fritsch thats normal on cherry Trail (z8300) 4K LiveTV drop frames - glitching ? (even with switch off deinterlace)
maybe i could record some sample and send you ?
(2016-06-17, 13:14)fritsch Wrote: [ -> ]Has nothing to do with the bios - I asked you some posts before to do a "touch" command, try that, please:
http://forum.kodi.tv/showthread.php?tid=...pid2353702
I tried and worked if i remember correctly..will try again this night , is there a system to map this command to ir key for waf ? (just to save my wedding
thank you fritsch
@Roby77: You should only need to run the command once - you would only need to re-run it if you wiped the disk, or deleted the file...
ah okay, so i can confirm that that command doesn't solve my problem
instead ... black screen issue after movie stop seems to be fixed
Not possible ... and totally not related to movie stop.
Post: journalctl -a | pastebinit
sorry lost in translation, i would not say that your command solve my problem but in the meantime (maybe kernel upgrade) other problem of black screen disappeared
thank for your assistance
(2016-06-17, 01:15)lrusak Wrote: [ -> ] (2016-06-17, 01:03)Milhouse Wrote: [ -> ]Would those who experienced problems after the recent lirc bump please test the following build and confirm if IR is now working as expected, or not (this doesn't include the lack of auto-repeat which may be a different issue):
Generic: #0616x
Anyone who tests this build please post the output of
systemctl status | pastebinit
And
It does NOT work. Still no IR on this. Here are the logs:
http://sprunge.us/aENW
dmesg | paste
http://sprunge.us/UjPe
