2017-05-20, 20:32
(2017-05-18, 18:12)x6adidasx6 Wrote: [ -> ]When I run the Xonfluence skin on my Amlogic S905 box using Kodi 17.1, it opens, shows me the Kodi splash, I hear the intro movie start, but then crashes back to the home screen of android... Any thoughts? Any reasons why it's crashing? No build installed. No add-ons. Just plain Kodi 17.1 from the Google Play Store. I download the zip from Helly repo, install the 3.3.18 and when I try to open it, doesn't work...
UPDATE: I have tested this on two S905 boxes, both running 5.1.1 - when you try and open Kodi, it crashes. Then I tried testing on a Mi box (running 6.0), it boots, but then says Kodi is unresponsive and gives the option to wait or close. Then I ran it on a S912 running 7.1, same as the 6.0, it boots, then while the screen is black, the pop up comes on saying Kodi is unresponsive, do you want to close - I click Wait and it runs, if I click Close, it obviously closes the program.
What gives? Why is Kodi becoming unresponsive?
Please help! Thanks!!!!
(2017-05-20, 17:37)Richie0632 Wrote: [ -> ]Hi all, New here. Ive spent quite some time trying to get my customised intro movie to play on my 6.0 t95m android boxes. It plays flawlessly on my laptop but on all the boxes I tried its just a black screen with sound till the very last 2 seconds. Ive tried moving the intro file to the xonfluence folder on the box directly but no good. Also messed about with the resolution from 1080p down to mpg still the same. The original intro movie wont play either just sound and 1 second of video at the end. Have tried on different tvs and the results the same.
On my android smart phone & laptop it works flawlessy. My heads done in lol
Any help will be much appreciated.
I have the same box as you...It would never play. I simply removed the url to the video in settings. I however never had Kodi crash because of it being played which suggests there is something else going on with your unit.
I have always had some issues with that intro movie, even on a PC it would be delayed in playing...
I will add that I believe the firmware that comes with some of these T95M units is not all that up to snuff. I have been researching about finding a more stable firmware to flash to the unit and failing that I may just move to the LibreE. While I like the ability to run android as well as Kodi, Stability of Kodi is more important in the end.
