2017-10-30, 19:33
Works perfect now.. thanks
Helly1206
I checked your log and there are some messages of includes that are missing. They are all referring to ViewsPVR.xml. Probably this file is missing or corrupt. Can you have a look at C:\Users\HTPC\AppData\Roaming\Kodi\addons\skin.xonfluence\720p and check if this file is present? Probably a re-install will help, or get this file from:
here. This file is in the repo zip file, so it should be installed when installing xonfluence.
I'm also using live TV and don't have any issues.
Success.
Helly.
Helly1206
(2017-10-24, 23:33)markus3000 Wrote: [ -> ]Having an issue with Live Tv channels showing up, The page its completely blank. Funny thing is I can set a timer and record tv , I can see the tv guide channel list, I can playback the recorded tv but the actual live tv channels themselves is completely gone under "channels" on the left sidebar menu of live tv, just blank. There is nothing there to click on. I switched skins and live tv works fine... just when using xconfluence... I also tried using the HDHomerun app to see if channels show up and they do without problem, its just the built in live tv on kodi. Using hdhomerun tuner with nextpvr. Any help would be appreciated...
Here is my log
Kodi Log
Success.
Helly.
