I found an interim work around for the Super favorites error. Actually 2 steps:
1. Super favorites settings - display - show unavailable addons - check yes
2. Edit each favorites.xml file (one in each subfolder) - search and replace
- "&" with "&" - if using with panel widgets
- "ActivateWindow(10025" with "ActivateWindow(Programs"
its not ideal, but if your build is highly tied to favorites and widgets like mine this will get things working until an update comes out.
Cheers
I tried to open Kodi 16 (with Xon skin, Windows 10) today and the intro video doesn't play (the sound does) and then I get the Exception Main Loop Exiting message, I havent changed anything, does anyone know what the deal is?
EDIT: Sorry not a Xon problem it seems, apologies.
Running Kodi 18.0-BETA 4 on Odroid-C2 with CoreELEC community build 8.95.4.1.
Trying to install Xconfluence 3.3.19 and it failing: "The dependency on xbmc.gui version 5.12.0 could not..."
All dependencies are successfully installed (Favourites script 6.0.3, Skin Widgets 0.0.32, Library Data Provider 0.1.6, Random and Last items script 2.2.2, simplejson 3.3.0, Plugin routing 0.1.0)
You're trying to install the krypton version of xonfluence in leia.
Install Helly's repo and xonfluence 4.0.2 should be available. That's the one you want.
(2018-10-28, 20:34)trogggy Wrote: [ -> ]You're trying to install the krypton version of xonfluence in leia.
Available repo zip file is hellyrepo.kodi-master.zip on
https://github.com/Helly1206/hellyrepo.kodi and it contain only 0.2.6 version of HellyRepo with 3.3.19 version of Xonfluence.
Could you please provide the link I can download 4.0.2 version of Xonfluence?
(2018-10-29, 00:04)rafikW Wrote: [ -> ] (2018-10-28, 20:34)trogggy Wrote: [ -> ]You're trying to install the krypton version of xonfluence in leia.
Available repo zip file is hellyrepo.kodi-master.zip on https://github.com/Helly1206/hellyrepo.kodi and it contain only 0.2.6 version of HellyRepo with 3.3.19 version of Xonfluence.
I just tried this on a fresh leia install.
Installed Hellyrepo 0.2.6
Tried to install xonfluence and only saw 3.3.19
Went back to the repo, used the context menu to 'check for updates'
Now I see 4.0.2
(2018-10-29, 01:40)trogggy Wrote: [ -> ] (2018-10-29, 00:04)rafikW Wrote: [ -> ] (2018-10-28, 20:34)trogggy Wrote: [ -> ]You're trying to install the krypton version of xonfluence in leia.
Now I see 4.0.2
That was the trick... thank you...
(2018-06-17, 19:05)Shasoosh Wrote: [ -> ]Hey,
How can I hide the OSD after pause & play?
Right now if I'll pause a movie I will see the OSD (Poster and info) and that's fine.
Pressing Play will continue the movie but will require me to also press back on the remote in order to hide the OSD.
I didn't find a way to do it natively, however, I did find a solution. I had to install "skin helper settings" from
https://github.com/marcelveldt/script.sk...r.service/. Once installed, navigate to userdata\addon_data\skin.xonfluence and open settings.xml, edit the line <setting id="SkinHelper.AutoCloseVideoOSD" type="string">xx</setting> where "xx" is how many seconds you want it to remain before disappearing. Hope this helps.
Is it possible to select custom colors for video resolution 4K, HD, SD icons?
In Xconfluence 4.02 (for Leia) there are the following ugly colors (blue HD is almost not visible on plasma TV):
and in Xconfluence 3.3.19 (for Krypton) it is:
^^^^ The above would be a nice feature if it's not too difficult to accomplish. But I think those symbols are contained in the textures.db file.
I personally like the Blue/SD, Green/HD. Would personally prefer something a little less garish than Red for 4k but that's no big deal.
What I really don't care for is all the symbols being white with grey buttons that you get if you choose to use the Grey theme. I've been using the Kryptonite theme for about two years and still really enjoy it.
This is on Kodi Krypton by the way. I won't be changing to Liea until final release, but when I do I'll be installing the Xonfluence skin as my first task.
I love this skin, Helly!
Cheers,
Robert
Hi, what are the settings so that a musicians fanart is not mixed with the background picture (e.g. Guitar for Music) on the main menu?
Using simple client iptv pvr with xonfluence and was wondering if I could change the background of the epg menu from black to another colour? Didn't see any options to do this, and I'm fairly certain the epg look is controlled by the skin, not the pvr addon?
thats in either mypvrguide.xml or includeslivetv.xml ( not sure if this xml is called includesmypvr.xml in xonfluence).
Hi, I've got a question, I coudn't find the answer anywhere.
Regarding Genre Icons:
Is it possible to use Genre-Icons (addons) for movies? Running Krypton and can't find any setting or tutorial on how to have own Genre Icons instead of default folder symbols?
Thx dafür
Uatschitchun
