Quote:These green bars at the top & bottom of the video constantly flicker in and out. This only happens in PseudoTV
What skin are you using? Does this happen on other skins?
Quote:It says something like "opening locked 1" or something like that and it takes too long to wait for it to finish
If there was some problem, it can take something like 10 seconds. It should normally take a second or two at most. Are you doing sharing over SMB using Windows?
Quote: It seems that the "Pause" and "resume" rules do not work on a hidden channel
Quite right, they do not. Once a hidden channel is integrated into some other channel (through interleaving or scheduling) all of its rules are lost and it follows the rules of the new channel. I don't know a way to accomplish what you're looking for.
Quote:I can't exit from PseudoTV in a normal fashion
Have you tried the latest stable-pre? I recently put in code to fix this...
Quote:min/max number of inserted videos
The min and max parameters when interleaving do exactly what you're looking for...
Quote:If I interleave 1 channel then interleave that into yet another channel
I believe this sort of thing should work, although I haven't actually tried it myself.
Quote:I am trying to do the interleaving so that my adult swim channel has the bumps between the shows
Your best bet is probably a directory channel for bumpers. You may want to change the threading mode in the options to minimum so that you can see the channel being created. I just changed that to the default since full threading mode causes confusion.
Quote:Does using this add to the watched count?
Yes. No one likes it, but I don't control that, XBMC does. I may or may not be able to fix it, but it's not very likely since direct database access was removed.
Quote:the info popup for the "coming up" ... is too small
Agreed. Several of the skinners have also requested to be able to customize that dialog. I was more concerned with the feature at the time, but it may be something that I have to give in to.
Quote:I know his stance before was that if you wanted to help out, then just fork it.
That's not my stance at all. I welcome help. My stance, though, is that I will only accept code that I want to accept. If a person wanted (and even coded) features that I don't want in, then I won't put them in.
Quote:Now I have cleared some of the channels I did not think relevant to my needs and now I think this has caused PseudoTV to go all weird.
Log?
Quote:Submitted changes for Apple Tv Menu button
Excellent, thank you! I'll merge very soon.
Quote:I turned off "include iceLibrary streams", but on one channel I set it to "include iceLibrary Streams = yes" as a rule. That channel isn't showing up at all in PseudoTV
This
should work the way you're saying. The channel rule can override the global, that's the point of having that rule. One reason you could be having problems is that IceLibrary included durations for strm files, while many other plugins do not. If there are no durations then I ignore it.
Quote:The actual performance issue wasn't with turning on iceLibrary support in general, but adding the rule to turn off iceLIbrary support for all other channels.
Yea, I'm not surprised that that did bad things to performance. PTV suddenly needs to check to see if each file is a strm file and remove it from the list. Go back to the global off and a single on rule for the channel.
