LupinSansei Wrote:Thanks for the info! Ok, I got my log now. I hope this helps H
I'd take that link down asap and edit out your trackt password!
zepfan Wrote:I'd take that link down asap and edit out your trackt password!
Oh crap thanks for! I didn't realize my Trakit password was in it. I could the link down but the file is still up on MU. Couldn't editing out the link your quote? It still seems to link to MU
I'll re-upload it.
Ok this site seems to work better for txt files. I hope this helps. Please let me know what you find. I can't figure this one out.
http://pastebin.com/VZLaKEzX
Is anyone else having this problem?
Sorry, I've never seen it, but Jason should be able to help.
LupinSansei Wrote:I'm still getting "no valid channel data found" even with debugging enabled. I'm in Windows 7 at the moment and not sure where my logs are kept so I can post it.
Hi. I have the same problem. Using windows 7 and nighly build 18.04
It could be the nighly builds. They change a lot and quickly. My advise, stop using them they are more trouble than they are worth if you're not developing.
zepfan Wrote:It could be the nighly builds. They change a lot and quickly. My advise, stop using them they are more trouble than they are worth if you're not developing.
Thanks will try dharma 10.1 and report back
It was the nightly builds! Working on 10.1
LupinSansei: Can you please turn on debug logging in the system settings and post the log after starting PseudoTV again? Thanks.
Jason102 Wrote:LupinSansei: Can you please turn on debug logging in the system settings and post the log after starting PseudoTV again? Thanks.
Hmm looks like I got it working. Seems it wasn't working with the nightly builds like the post above. I switched back to 10.1 and it's working now!
Yea, there's a bug in the nightlies where the duration isn't reported in JSON calls. In most cases, though, my video parsers should be able to figure it out. Since your files are stored locally, I'm not sure why that part isn't working. Hopefully the vfs module will be implimented before Eden is released so that all of this will be fixed...
Thanks Jason102 for this addon, we’ve been using it most days now for the last couple of weeks and its almost replaced our cable subscription.
I’ve had a little trouble getting the osd menu to display on my htpc using my harmony remote. When I plugin a keyboard and press ‘M’ I’m able to get it to display but not if I use ‘Menu’ on the remote. All other aspects of the xbmc interface that use ‘M’ keyboard key seem to display correctly when using the menu button on the remote.
I noticed a couple of posts back zepfan was having the same trouble and wondered if you or he have had success when using a remote and not a keyboard?
For what its worth I’m using a harmony 300 on a first gen. appletv running ubuntu hardy. The IR receiver is controlled by a program called
atvclient. The harmony remote is setup to use the plex remote layout through the harmony software.
Would you be able to tell me what file on your repository I should be looking at that defines the osd? I’m no programer but I'd like to have a look.
xbmc.log
does this work with a centralized mysql database
thesuffering Wrote:does this work with a centralized mysql database
It works perfectly on mine...
GJones Wrote:It works perfectly on mine...
hmm, this is strange
i get an error
"No Valid Channel Data Found"
http://pastebin.com/aNAVyW8y
any ideas?
