hentai23 Wrote:och29 thanks for the advice and sorry for the bumping but this is important -.-'
Important for you only I'm afraid. If you don't use a scraper and are just looking to have the raw file names at the bottom then it could be a case of invalid characters in the file name. If some of the files show up correctly then that's probably the option. Try renaming one of the files to something simple like 'test' (without the inverted commas), refresh the info and see if it shows up.
My only other suggestion is to start a thread of your own e.g. [AEON MQ3] Problem with file names not appearing. Give all the details of what you've tried and the results, you'll be more likely to get a response than posting in this general thread.
@ Marcos: Any plans on maintaining any GIT or SVN ?
I wouldn't mind translating to Danish if noone else has volunteered?
bostoneric Wrote:wanting to check out MQ 3 since i'm such a huge MQ 2 fan, BUT
can anybody direct me to upgrade for dharma live to eden?
thanks!
You can update XBMC Live to use the
unstable nightly builds, I'm using the PPA's from Mario Sitz (the team xbmc unstable PPA's seem to have some issues and Mario's PPA's have blu-ray support), you can update this way
sudo apt-get install python-software-properties -y
sudo add-apt-repository ppa:mario-sitz/ppa
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install xbmc
If after this XBMC wont start (it probably wont), edit /etc/uxlaunch/uxlaunch and add this:
user=xbmc
tty=2
session=/usr/bin/xbmc
If in the future you wish to update to the newest nightly build, just do
sudo apt-get update
This works for me on a fresh XBMC Live 10.1 install.
First of all Marcos thanx for this great skin! it's works way smoother then MQ2.
One thing i couldn't get to work though, create a custom submenu (e.g. add a specific playlist) under, for example, Movies. Only thing i can customize are the menu items VPLAYLIST1 and FAVOURITE1 etc. and their submenus.
How do i add a submenu item under Movies/Music/Video?
hentai23 Wrote:anybody have a solution on my problem ? please?
Have a little patience, the skin has only been out for two days and is an RC, not a final release. Posting over and over and pm'ing people is not going to get an issue fixed any quicker.
Thanks Marcos and all that have put time in to create this Great skin looking skin, best I have seen.
m0v1em4n
I'm having a heck of a time trying to get the fanart to show up for playing music in visualitation or home screen. I can get the smaller icon cd art and cover but nothing else except the guitar. Any suggestions would help thanks.
Love the skin, found a bug though.
When i pause a movie and go back to browse other movies there's this big black square on top of everything that says "100% buffering"
I'm getting alot of these errors in my log:
DEBUG: Error: Requested setting (pvrmanager.enabled) was not found. It must be case-sensitive
Has to do with "system.getbool(pvrmanager.enabled)" on line 2433 in CustomSkin.xml and line 2162 in Home.xml
edit: I'm running XBMC on linux. Live 10.1 updated to Pre-Eden
ok stoli but looks like och29 has a point looks like ill have to open another monster thread of mine ,marcos hope you partake id appreciate it
p.s: all of youre suggestions och29 have been tried out it isnt because of unknown characters i even did as you said and named one file test , no success still nothing only a freaking "/" -.-'....mindboggling dare i say?
