Wanilton Wrote:The trouble with weather, look this topics:
http://forum.xbmc.org/showthread.php?tid=112798
and look the last posts in weather plus addon topic:
http://forum.xbmc.org/showthread.php?tid=95329
Change provider for AccuWeather in adjust addon weather plus, solve this..
Wanilton
Many thanks for the info (had no clue), thought something broke with the skin but looks like it is a licensing issue.
When I was fiddling around with it I found weather plus worked but not the standard version, moreover the 4 day forcast isn't working on plus either.
No biggie.
MQ... I have a feature request.
I really like your skin and have been using it. But, I'm not a fan of full screen fanart since it make many things which are already difficult to read, impossible... like the way-too-small text for time/day/etc on the home screen.
How about adding an option to have "windowed" fanart...
Hi MarcosQui,
What you have added in new version (1.0.1) over the previous (1.0.0) in /language/English/strings.xml ?
I translate to Polish and I want know what's new.
thank you
mq3 1.0.1 is perfect
Wanilton
I have Accuweather set in the provider, the other one is US only so no use for me since i live in europe. But I still dont have the weather icon with degrees next to the date in the main menu. Am i missing something?
I am unable to access the menu to change the viewtype. Is anyone else having this problem?
This skin is almost perfect for me, with one exception. I can barely read the RSS feed text. Is there a way to change the color?
Update: I just saw now that we can make the RSS window solid instead of transparent. This helps quite a bit.
One bugfix and two requests for a future version:
Bugfix: When attempting to "Add Source" in files view under videos, there's no way to move over to the large window where you can manually key in a source, or down to the source title where you can edit the name. I keep having to switch back to Confluence to do this when adding or renaming sources.
Requests:
1. Can a "Unwatched" item be added to the movies submenu that shows ONLY unwatched movies?
2. Can there be an option that the "Videos" menu main option takes you right into the files folder? Instead of having to go that extra click down into Files to get there? Or maybe even an option to take you to a specific folder inside of Files (set via the interface)?
I know you have a lot on your plate but I think the requests and bugfix would benefit many.
Thanks for all you do sir!
well as i do it you can fav a source in files under videos then add that as a custom menu item , that way you have direct access to the source you specified , like for me anime and movies are seperate sources both favd and added as menu item
p.s: btw just realized the weather wont show anymore its blank ? supposedly the weather api closed shop? and went all copyright crazy, what is the world coming to even an weather api is trying to get youre cash nowadays
Thanks for a beautiful rom!
Two things:
1. I still cannot disable the artist biography in 1.01? Can anyone else confirm please?
2. I know you're fla out with this new release, but is there any way that asian fonts (esp. Korean) will be integrated into the fonts later on? At the moment I am forced to use arial which looks very subpar
Thanks for everything!
Just a few things I have noticed...
Overlapping text when hovering on some menus during music playback. Seems to be happening on Shutdown, Weather, Addons.
Weather not functioning properly. Weather plus is pulling forecasts but not current weather info. Weather channel is not working.
Latest music album widget not working on main menu. Latest tracks displays latest albums.
When hovering on options in weather sub menu on main menu the background changes. Is it supposed to be that way?
Info: XBMC Dharma with latest version MQ3.
could you
please add a teletext button at LiveTV-OSD! Just realized it yesterday that there is none when I tried to check some political news
