Hi Guys,
Another question for you, I seem to be having trouble installing add-ons from a zip,
I tried to install
this but a notice pops up stating the the program is active, but it doesn't install, Am I doing something wrong :confused2:
Also is there a switch to show some form of new movie flag ?
m0v1em4n
supermax Wrote:I put the themes in the folder where the textures.xbt is and it seems to work. Users>your computer name>AppData>Roaming>XBMC>addons>skin.aeonmq.3>media
Sorry, that was for the mq2 themes. Still working on the location for mq3 themes.
Thanks. I tried it but it's not working. I guess MQ3 has different location.
ldi9999, you can create a folder and subfolders to put themes in this, any place, then just go to settings, skins, themes, and set the path for the theme you want.
example
c:\themes
c:\themesdark - extract manually zip files for this place
and Setting path in the skin configuration...in themes press enter to access the configuration path.
Found a couple of bugs:
The highlighting is broken in some menus, this is one I found (TV Show scraping, multiple matches found):
The list view of video files displays the poster as banner:
The info view uses a different poster then the TV Shows (in my case wall) view. In info the poster.jpg in the series directory is used, the wall view uses the scraped image:
The episode title runs over the HD image in wide view:
and because of the 6 images per post limit, here's the rest of my post:
In the trailers, using wall view, the movie name used to be on the bottom of the screen, can I enable that or is it gone in MQ3?:
In the side menu in programs I think there should be a switch next to "Horizontal" not this arrow:
And a couple feature requests:
Is it possible to show the temperature in white instead of yellow? It's poorly readable on most backgrounds, even white:
Can you add the episodes filename in the right pane that hides behind the episode/fanart image in wide view?:
Are the borders for the library statistics and clock gone, or can I enable them somewhere?:
Ok im a bit lost...
I downloaded the repo, installed that fine.
In addons -> Get addons I can see Repo Aeon MQ3, but how do I actually install the skin?
Im running Eden from OpenElec..
Meh forget that post, its now showing up!
Wanilton Wrote:ldi9999, you can create a folder and subfolders to put themes in this, any place, then just go to settings, skins, themes, and set the path for the theme you want.
example
c:\themes
Thanks. Will try that.
I was trying to change themes under Setting->Apperance->Themes (option underneath the Skin). Isn't that supposed to be the one?
ldi9999 Wrote:Thanks. Will try that.
Yes correct, right arrow in Themes, enter, appears 2 options, set second, and put path folder with theme, done...
wouterdt Wrote:Are the borders for the library statistics and clock gone, or can I enable them somewhere?:
I just noticed that the borders are there when clock/stats are attached to the menu, if they are in the upper corners the borders are gone.
Anyone using this on a ATV1 with nightly build...just wondering how smooth it is before I attempt to upgrade from Dharma (MQ2) to nightly builds (MQ3)
Wanilton Wrote:Yes correct, right arrow in Themes, enter, appears 2 options, set second, and put path folder with theme, done...
See, that was the issue. There was no 2nd option. It's only one there (1/1).
Hi Guys,
How would I name a 3D iso file ?
I think in this skin there are different box colour for different formats, i.e. Bluray sddvd etc
thanks
m0v1em4n
