apañero Wrote:I'm having problems with the Favourites Custom Menus. They appear empty when you access them:
BrainSturm Wrote:This should help you with your problem:
http://forum.xbmc.org/showthread.php?tid=115655
Thanks, I've solved it. It was a bit tricky, you need to Set a folder as Favourite, then go to edit favourites.xml removing the quotes and finally go to the Custom Menu options to assign the Favourite to the Menu.
jweaks Wrote:I searched and found mention of similar issues, but none of the fixes worked. I have no backdrop images (just black) on the main menu for Movies, TV Shows, and Music. The other selections have backdrops. I've tried default image, replace single image, and replace multiple image... I got nothing.
Thoughts?
I figured this out. It seems that I turned on the Fan Art for "Movie Item" and TV and Music. It couldn't find the Fanart apparently so it went blank. Turned that off and the default backdrops came right back. Then I selected my own multi-image folder in the settings and that started worked just fine too!
My XBMC is gorgeous!
How do I use Season Thumbs from fanart.tv in Aeon MQ3?
nekrosoft13 Wrote:anyone?
Best bet is to raise and issue as described on page 1 of this thread.
Is it possible to add Unicode font to the Skin? I'm using the Chinese add on and MQ3 can't display the characters.
Still working on list view for file mode. I can't get folder.jpg posters to work. Found out than in low list it does work by deselecting all other options in settings (use poster etc), but when switching to normal list it will then always show folder.jpg squished to a banner. Is there a way to make folder.jpg work for posters?
Also in list view when going to narrow list view I lose the checkmarks for files viewed, is that to be expected?
Hi MarcosQui, Did you remove 3d blueray case .png in the new version ? My new 3d movie don't get 3d bluray case now ? Please add 3dbluray.png image for 3d case ?
is it possible to disable the ability to move the main menu to the center and bottom? its annnoying when the menu move up and down.
so i've got several movies, as well as several stand up comedy videos. In order to not have them show up in the same list, I've created two video playlists based on the directories that the video files are in.
due to this, I don't use the MOVIES menu item, but instead disable it, and use VPLAYLIST1 renamed to "movies", and VPLAYLIST2 renamed to "stand up".
Everything works properly except that by using VPLAYLIST1 instead of the MOVIES menu item, I lose the ability to view the "recently added" widget when VPLAYLIST1 is highlighted, or the "recently added" submenu that goes along with it.
Is there any way to add the "recently added" widget & submenu to a VPLAYLIST1 menu item?
This is the theme I've been looking for. I like the Aeon Nox theme, but I prefer the movie OSD in this theme. Easy to customize too.
Any ideas what has caused my skin to start showing options and side menus with no darker menu background, like this?
As far as I know I haven't enforced any changes. It is also making things like scrolling through video files difficult as I don't know clearly which one is highlighted. Not sure if a debug log will help here, but if you think it would I'll post one right away.
soldave Wrote:Any ideas what has caused my skin to start showing options and side menus with no darker menu background, like this?
offtopic:
I like your backdrop, were did you get it?
Nevermind, found it. Didn't checked other extra packs before.
Quick question about this awsome skin:
I have my movie filenames set up with ****.dvd.mkv or ****.bluray.mkv, so MQ3 displays the correct box cover in showcase and it displays whether the movie is a DVD or bluray on the skin "floor".
However, when I pause or press info, MQ3 displays codec info, eg H624, mpeg4 etc instead of DVD, bluray.
Is there any way to change this?
