I found a bug using coverflow for TV Shows and poster.jpg.
I don't know if it has already been reported, but the main (selected) poster is in fact the poster.jpg, but the other ones (left and right) are the ones scraped by XBMC. As soon as I turn uncheck 'Coverflow' (going back to flat), the problem disappear, and all the poster shown are the poster.jpg.
Posted by och2 Wrote:Hi,
I think I may be the only person experiencing this but I am unable to add network sources in MQ3. I've tried a completely clean install and am able to add sources in Confluence but when I try in MQ3 I have no luck. I get as far as choosing what type of source I'd like to add e.g. http, smb, etc. but I am unable to add any details. The only thing I can do is to add the source in Confluence and then switch back to MQ3
sl4m Wrote:same here
Hi Guys,
I had the same problem but with a combination of mouse , keyboard and remote was able to enter my details.
is this down to pre 11 nightly ?
MarcosQui Wrote:This weekend I will release RC1 which includes several fixes and also the return of the shelf view as so requested.
Thanks for your continuing hard work,
will the skin auto update ?
m0v1em4n
Can you please make an option to enable bluray covers without having to rename my entire collection? thanks.
I did rename some of my newly installed bluray movies but they just showed with a blue cover and no bluray logo on the top of the box, yet some of the old installed bluray movie that was not renamed did have the bluray logo on the box
so go figure
Does anyone know if there is a different coloured box for 3D content and would I get to use it with ISO ? I have tried putting 3D in the name
m0v1em4n Wrote:Hi Guys,
Just for info, I am using Windows, pre-Eden from 26th August, MQ3 downloaded from Marcos' website on 26th August and I'm using a Logitech diNovo Mini keyboard.
I could post a debug log but I don't think anything would be generated.
You just brought a tear to my eye, thank you for bringing shelf back from the dead.
astrotrain Wrote:You just brought a tear to my eye, thank you for bringing shelf back from the dead.
Yep, that is a great news !
Does anyone knows who is in charge of french translation for MQ3 ?
same problem with network panel here. (similar problem in MQ2)
Butterfly Wrote:same problem with network panel here. (similar problem in MQ2)
You can try using a mouse. That's what worked for me.
Does this work with the pvr branch?
SSMI Wrote:Does this work with the pvr branch?
id love to get the pvr functionality working. Cant find a tutorial anywhere... pah
Idk if this was posted before, im sleeping, but reporting one thing on Panel view (using 4ghz phenom 2 and good gpu, so not bcs of bad hardware, altho i dont have SSD), when i go a line-down
I mean
I have
XXXX
YYYY
ZZZZ
visible on screen
and i go to
YYYY
ZZZZ
TTTT
The transition its very slow and sttutery (i suposse its getting the covers and such...), its not a bug itself, but would be good if improved, had to switch to low-list because of it.
xecutionx Wrote:You can try using a mouse. That's what worked for me.
If that works then i suppose it's a good temporary fix but I know a lot of people will either not have a mouse or have it disabled. Hopefully this will be fixed by the final release.
I'd be interested, and I'm sure it would be useful, to know if anyone is able to add a SMB or other network share. You don't have to actually add it just see if you can. So if you are looking for a way to help in the testing here's your chance.
original post:
och29 Wrote:Hi,
shelf view? wohoooo, thanks
