mindweaver Wrote:http://ftp.df.lth.se/pub/xbmc/addons/ede...avourites/
Marco
I've noticed that you also created somekind of 'fixed list' on the submenu's on the mainscreen. Would it be possible to get something like that for the main menu items as well? Now it goes in a circle and can be confusing sometimes.
Aeon MQ 3 - version 1.0.1 available.
Changelog:
Added: ExtraPacks now supports multiple images.
Added: Pictures views/side menu - buttons Recersive Slideshow and Random Slideshow.
Updated: Translation into Swedish - mindweaver, thank you for that.
Updated: Translation into French - BabaOrum, thank you for that.
Updated: Translation into Slovak - therrookiee, thank you for that.
Updated: Translation into Italian - Giskard, thank you for that.
Changed: Library Totals - improved for larger counter.
Fixed: Visualisation Preset Window/Music OSD.
Fixed: Disable Artist Biografy.
Fixed: Wall View - Missing icon Video Files. samurai07, thank you for that.
Fixed: Custom Menu - No possible customize buttons 6 to 10.
Fixed: Word 'Concerts' in side menu.
Attention:
Current images extrapacks are obsolete.
If you use some, after the update skin, you will only get a black screen.
For fix this you need to download the extrapacks V2.
Thanks Marcos, MQ2 and MQ3 are really awesome. I didnt find another skin as beautiful as they are.
One question: I upgraded recently from MQ2 to MQ3 on my atom system. I am using the "normal" mode but for me the MQ3 is quite a bit slower at some places than MQ2. For example when switching to the Movies view or switching back to the main menu it takes several seconds while MQ2 was much faster. Is this just the case or am I doing something wrong?
I might just stick with MQ2 then when it performs better for me.
Thanks Marcos, now the skin is perfect for me :-D
Marcosqui, in this image, you can see, the tittle "
Lista de RE..." at the top, and "
HIP-HOP ESPA..." at the bottom are not complete, but there is space. Could you change this?
Will it be possible to have different view in You Tube besides list and low list on EDEN ?
Maybe something custom like confluence has ?
is there a way to get playlists to play automatically with this skin?
I have video playlists on my home menu but they go to the list when i select them. If i need to modify an xml that's fine, but could someone point me in the right direction?
In the neon skin you can choose whether to 'start the palylist automatically' or let it list the items in the playlist, then play them
thanks
Is it just me or is the zip file on the website corrupt.. downloaded
a few times and everytime the same result..
EDIT: looks as though the problem has been fixed.. Thanks
Anyone else now have problems with animated weather background and icons?
Re-downloaded from marcos site but still no joy
m0v1em4n Wrote:Anyone else now have problems with animated weather background and icons?
YES... and I have no Home screen background when Weather is highlighted. I have tried Setting to reset the BG but no love.
I'd also like to know how to install ExtraPacks - anxiously awaiting the How-To on the first post!?
jitterjames Wrote:I don't think that XBMC will allow you to create a playlist of stuff that hasn't been scraped into the library. This has nothing to do with MQ3. However, I think I have a reasonable solution for you. From the home screen select Videos. Browse to the path just above your special folder (add as source if you need to and mark content and "none"). Highlight the special folder and then press C and select "add to favorites".
You can then access favorites from the home screen by going to videos and pressing down. Or, now that it is a favorite you can add it as an item on the home screen.
The only way I can think to create a playlist of non-scraped content would be either with a text editor, or by queuing all the files in the directory and then saving the playlist but you would have to keep updating it every time you added something.
Thank you very much for your help. I just thought there is a way but I cannot figure out how. Not each and every content that comes from tv is available in those scraper databases. I was under the impression that xbmc also is to archive your videos, no matter what they are and where they are come from. So I was mistaken. Thanks again.
I will try one of those workarounds but I am afraid I have to install the skin completely from scratch because I think the update did not make it work properly. For example, if I click down on archive, the sub opens but there is nothing in. No text, no favorites, nothing, it is just black.
Also, if I queue something and call the now playing context, it is not possible for me to hit the save button. I can not reach it with my keyboard and not with my mouse. That makes it impossible to create any playlist from queued content.
So if this is all working quite well with you guys, then my update from MQ2 to MQ3 was not working or the fact that I run Eden!!!
Who knows.......
Look here how set extrapacks in skin aeonmq.3:
http://www.youtube.com/watch?v=kPigHUPlHRw
If you use themes, please visit site Marcos, and download new themes packs v2..
http://www.marcosqui.com.br/skin_english.html
For fix this you need to download the extrapacks V2, because now skin
supports multiple images for each category in home menu...
Wanilton
Wanilton Wrote:Look here how set extrapacks in skin aeonmq.3:
If you use themes, please visit site Marcos, and download new packs v2..
Wanilton
Thanks Wanilton
I know how to install and everything was working OK before update, I have re-downloaded the weather extra pack for mq3, can't see any version 2 for that. anyone else have weather icon issues
I had same problem today, the background for weather, settings etc. went blacked. Moreover the weather forcasts (standard not plus) is unable to get any information.
Was there a recent skin update today or yesterday i am not aware of?
Was able to correct the backgrounds but my weather updates are dead.
