I have installed this last night and using the normal version of Aeon MQ3.
One thing though this seems to crash everytime for me when trying to browse back to my main homescreen. I can be in my TV section and press backspace to get me to the home screen then it will go back but when pressing back space once more to get to my actual home screen it crashes and my entire system freezes up.
Any ideas what could be causing this?
(2012-04-23, 16:15)JonSnow Wrote: [ -> ]I have installed this last night and using the normal version of Aeon MQ3.
Not heard any instances of this happening with the skin, could you please let us know what hardware you are running on, perhaps then someone can advise. Does the same thing happen with any other skin?
Hi a couple of questions I can't seem to find the answers to:
1. When I update the skin should the old be uninstalled first or just browse to the new zip file and update?
2. Is it possible to have the home menu items (TV Shows/Movies) change random backgrounds of the TV Shows/movies I have? I have my movies arranged with folders for each movies + pictures.
3. Is it possible to arrange movies after "file date changed" instead of "recently added movies"?
4. Is it possible to make a home menu button to a shortcut for another program (DVBViewer)
Thanks for a great skin btw.
(2012-04-23, 20:23)chippie Wrote: [ -> ] (2012-04-23, 16:15)JonSnow Wrote: [ -> ]I have installed this last night and using the normal version of Aeon MQ3.
have heard of it before....sounds like you have dirty regions enabled which is almost a must if you have a low powered machine...this only happens with mq3 as far a i know
this issue caused me to move my machine to aeon nox
hey guys havent posted in a while, anyways are you guys still using EMBER to scrape your vids/tv shows ?? Also if i save all my movies for eg. Avatar 2009 BluRay it will show up as a bluray title with the blue border right ??
(2012-04-25, 02:59)johnny87au Wrote: [ -> ]hey guys havent posted in a while, anyways are you guys still using EMBER to scrape your vids/tv shows ?? Also if i save all my movies for eg. Avatar 2009 BluRay it will show up as a bluray title with the blue border right ??
It got picked up by someone else:
http://ember.purplepig.net/projects/embermm
I still use it. It's the only third party artowrk manager that I like.
How do I get artwork downloader to put the artwork in the actual movie folder or tv show/season folders?!
I want every show to have the fanart and extra fanart located in each individual season folder and each individual movie's folder.
(2012-04-25, 22:10)wouterdt Wrote: [ -> ]Hey Marcos, is it possible to build support for the smart playlist recently added widget in your skin?
http://forum.xbmc.org/showthread.php?tid=122448
this would actually work really nicely, as I don't use the MOVIES category, I use smart playlists / the VPLAYLIST entries instead to separate the movies into the playlists I have for the categories (movies, standup, documentary, etc...)
this would prevent the "recently added" widget from showing entries that shouldn't be listed under the current smart playlist.
Quote:How do I get artwork downloader to put the artwork in the actual movie folder or tv show/season folders?!
I too would like help on this,..
(2012-04-26, 08:38)Zxurian Wrote: [ -> ] (2012-04-25, 22:10)wouterdt Wrote: [ -> ]Hey Marcos, is it possible to build support for the smart playlist recently added widget in your skin?
Exactly the reason I would like to see it in this awesome skin
(2012-04-25, 19:34)Zxurian Wrote: [ -> ] (2012-04-25, 02:59)johnny87au Wrote: [ -> ]hey guys havent posted in a while, anyways are you guys still using EMBER to scrape your vids/tv shows ?? Also if i save all my movies for eg. Avatar 2009 BluRay it will show up as a bluray title with the blue border right ??
It got picked up by someone else: http://ember.purplepig.net/projects/embermm
Same here, still works like a charm and easy to use.
I have an issue that isn't that big of a deal but it bothers me and I would really like to know how to fix it.
At the bottom of the screen it shows the media flag MKV (matroska) fine on all of my movies that are 2.35:1 or 1.85:1 like this picture.
but on my 1.78:1 movies it doesn't show the MKV flag. Why would it not work on only those movies?
