(2016-03-05, 09:27)Warner306 Wrote: [ -> ] (2016-03-05, 03:00)Wanilton Wrote: [ -> ]Kodi Jarvis 16.1 RC1 + dsplayer * (03/04/2016)
link for download:
https://dl.dropboxusercontent.com/u/7799...5.dx11.exe
Update internal lav filters for version 0.67.0-142 (03/03/2016).
Warnings:
- This is an unofficial Kodi build not from Team Kodi.
- This build comes with no warranties, explicit or implied, and you use it at your own risk.
- This build was compiled by Wanilton, for use only in Windows OS, and have same functions official Kodi Jarvis build Nightly + dsplayer support.
git:
https://github.com/mediaBrasil/xbmc/tree...r_dsplayer
Is Derek correct? Does the interval LAV Filters include installation of the optional MVC 3D decoder?
I have installed this version and the latest madvr. Mkv's playback is fine. 3d isos don't start at all. What do I need to configure?
DSPlayer iso handle is very limited / incomplete. Try mounting ISO in virtual drive and play from there
Thanks Wanilton for the new release!
One question: in the post is written 16.1 RC1 while the file reports "final" in the name...which one is the most correct?
The name of build came from version number from Kodi master branch. Don't think too much in it. It's nightly and main number is build date.
Here data version
APP_NAME Kodi
COMPANY_NAME XBMC-Foundation
WEBSITE
http://kodi.tv
VERSION_MAJOR 16
VERSION_MINOR 1
VERSION_TAG RC1
VERSION_CODE 160991
ADDON_API 16.0.991
# Notes:
# Change AC_INIT in configure.ac
(2016-03-04, 19:16)oldpoem Wrote: [ -> ]There was hardly any any internet streaming direct show filters at the time. There were probably only well-known 2 source filters, file souce one that support http only which has not been updated in years and LAVsource which do the same and better in every possible way. So probably aracnoz didn't see the point of make it customizable.
Too bad your reference Youtube source filter had been unknown piece of software so far. Unless someone with coding skill step in to do the job. We're stuck with current code which is not that bad. But lately I've been using Chrome Launcher to view youtube most of the time. It has pre-configured Youtube Leanback (which launch youtube/tv). It is the same as launch Chrome and open youtube. It can be use with remote as well.and can be configured to feel seemless with Kodi.
Unfortunately YouTube Leanback doesn't use madVR, though... and it doesn't use refresh rate switching.
As far as the coding skill are concerned, I pointed out before... it's really just a couple of lines. Somebody with a building environment could fix it and test it quite rapidly
I think.
http://forum.kodi.tv/showthread.php?tid=...pid2250639
(2016-03-05, 17:41)oldpoem Wrote: [ -> ]DSPlayer iso handle is very limited / incomplete. Try mounting ISO in virtual drive and play from there
This doesn't work either.
(2016-03-05, 18:55)Caramba69 Wrote: [ -> ] (2016-03-05, 17:41)oldpoem Wrote: [ -> ]DSPlayer iso handle is very limited / incomplete. Try mounting ISO in virtual drive and play from there
Then it can't playback with DSPlayer (given your mediaconfig is correctly configured for bdmv/mpls). You'll have to resort to convert to mkv or using external player like TMT.
Or use native player, remember install have native player video Kodi too, only need press C above title, choose Play with, select dvdplayer...
(2016-03-05, 13:24)oldpoem Wrote: [ -> ] (2016-03-05, 09:27)Warner306 Wrote: [ -> ]Is Derek correct? Does the interval LAV Filters include installation of the optional MVC 3D decoder?
Read carefully, it's a joke, don't take it seriously.
I never understand if Derek is serious or not. He makes my head hurt when he posts sometimes.
madVR doesn't support 3D ISOs, only MKVs and Blu-ray discs. Try converting the ISO to an MKV file with MakeMKV. That is what I did to test this feature. However, I deleted the file after watching it.
(2016-03-05, 22:47)Wanilton Wrote: [ -> ]Or use native player, remember install have native player video Kodi too, only need press C above title, choose Play with, select dvdplayer...
Can you answer if the MVC 3D decoder is installed? It isn't that important, but some users are trying to play 3D files and I'm not certain it is possible with the internal filters.
I am assuming it is if all of the GitHub commits are included.
(2016-03-05, 17:07)Zpectre87 Wrote: [ -> ] (2016-03-05, 03:00)Wanilton Wrote: [ -> ]Kodi Jarvis 16.1 RC1 + dsplayer * (03/04/2016)
link for download:
Warnings:
git:
Thanks a lot, do I need latest madVR build or only the last one that was supported by DSPlayer?
As of today, the latest madVR builds still work with Jarvis DSPlayer.
Warner306, it´s no clear to me to, because I get files compiled, install LAV update, get dlls x86, and overwrite for create install with files updated.
I don´t use 3D here, sorry.
(2016-03-05, 17:42)axlt2002 Wrote: [ -> ]Thanks Wanilton for the new release!
"Final" must be the DSPlayer version since, due to aracnoz leaving the project, it's, well, final.
