About wasapi, I think if u use reClock audio renderer u can set it to use wasapi, and I think with Sanear too.
here is my system:
HTPC:
Motherboard, Gigabyte GA-990X-Gaming SLI
Graphics Card, Gigabyte Geforce GTX 1050ti 4gig G1
Processor, AMD FX 4300
Processor cooling, Cooler Master Masterliquid Pro 240
Memory, Kingston 8GB DDR3-1866 CL9
OS HDD, Samsung PM961 128gig M.2 PCIe NVMe
Storage, 5x 4tb HDD’s
Case, Coolermaster Mastercase Pro 5
Power Supply, EVGA Supernova 650 G2
AV Amplifier:
Yamaha RX-V677 (updated firmware for 4k passthrough)
TV:
LG 65UJ634V 65" Smart 4K Ultra HD HDR LED
Cables:
HDMI 2.0 spec.
OS:
Windows 10 Pro Creators Edition ‘de bloated’
Kodi is the only program installed as its just for playing movies
not connected to internet as i dont need it to be
Kodi:
kodi-17.6-Krypton_DSPlayer-x64
Latest madvr
Movie Files:
All original 1-1 rips using MakeMKV (all metadata for movies/tv shows are stored local inside separate folder)
yes i have HDR set to passthrough. i might try plugging the htpc straight into the tv tonight so as to rule out the AV amp.
i was just looking at reclock, might give it a try.
(2018-03-02, 17:42)mclingo Wrote: [ -> ]There are a few things you need to enable in MADVR to get HDR working too, like DIRECT3d 11
aaahhhh.. i turned that off IIR as i thought it was for 3d.
Hey ! One day, you will add support bluray ?
(2018-03-02, 23:20)mclingo Wrote: [ -> ]so its working now?
nope. could not get kodi-dsplayer to work.
what does work is kodi-MPC-BE without any LAV, Reclock or madvr. picture quality using this is simply stunning (no more 'dulling' of picture with 4k content), no frame rate dropouts or sound dropouts. jellyfish 400 10 bit plays smooth as silk as does 'demo' clips. all files change hz rate to what ever is playing. as does the bit depth. if the file is 10bit 60hz then thats what it plays at, if its 10bit 24hz it plays at that etc.etc.
processor is using no more than 20% and 1050ti no more than 30% resources when playing 4k.
now i'm not using any 'plugins' MPC-BE works as should when exiting back to kodi.
so to sum it up kodi plus MPC-BE (as it comes) works perfect no matter the content and everything 'auto switches'. its also very fast at start of playback, about 1-2 seconds.
thanks for all your help and its much appreciated :-)
so MPC-BE does envoke your TV's HDR preset then automatically?
by the way, the 64 bit version is buggy anyway, try and stick to 32 bit path throughout.
(2018-03-03, 14:57)mclingo Wrote: [ -> ]so MPC-BE does envoke your TV's HDR preset then automatically?
**the only movie i have at the moment is guardians 2 which i believe is not HDR**
not tried that yet but i doubt the av amp will pass it as its not hdcp 2.2. its not triggering the HDR when playing demo clips such as eye of storm, wonderland or rays of light. the demos do look stunning though.
i fiddled with the 4k passthrough last night so not had a chance to test HDR content. the result with configuring the amp 4k passthrough was a revelation it terms of PQ. so it might have been that all along.
plans for tonight. plug HTPC direct into tv to test HDR playback. plug usb into tv to test demo clips to see if it triggers HDR playback.
add madvr and for HDR passthrough and test HTPC again via tv and amp.
if HDR triggers without the amp then its new amp time... lol
done a bit of testing.
as i suspected HDR wont pass through the amp even with madvr.
HDR wont engage with just standard MPC-BE with HTPC connected direct to the TV
HDR will engage with madvr and MPC-BE with HTPC connected direct to TV. but it wont turn the HDR off again after playback has been stopped and i have to exit back to the desktop and turn HDR off in the display properties.
turning off send metadata to tv results in a black or green screen.
(2018-03-02, 18:57)Bibio Wrote: [ -> ]here is my system:
HTPC:
AV Amplifier:
TV:
Cables:
HDMI 2.0 spec.
OS:
Kodi:
Latest madvr
Movie Files:
What video driver are you using?
I am using the same GPU and until recently had no problem with HDR.
I am have a few issue at the moment with all video's not playing not sure what it is , they play fine with the standard video player just not the DS player, watched a movie ok one night the following night nothing would play not sure what happened , did something update in window or perhaps a plugin ? I am not sure
Hi, just did a bit of research on your amp, its not a fully HDMI 2.0 spec amp, it was firmware updated to passthrough but it doesnt support HDR. Plug you PC direct into the TV and if you have a second HDMI output plug that into the reciever for sound, that way you'll be able to get HD sound, if use ARC you'll lose DTS-HD, DTSX, ATOS etc.
https://www.dropbox.com/s/gn2n0he0fvnmkx...0.png?dl=0
post 617
(2018-03-04, 17:22)m0v1em4n Wrote: [ -> ]What video driver are you using?
the latest from Nvidia. 384.76-desktop-win10-64bit-international-whql
(2018-03-04, 17:36)mclingo Wrote: [ -> ]Hi, just did a bit of research on your amp, its not a fully HDMI 2.0 spec amp, it was firmware updated to passthrough but it doesnt support HDR. Plug you PC direct into the TV and if you have a second HDMI output plug that into the reciever for sound, that way you'll be able to get HD sound, if use ARC you'll lose DTS-HD, DTSX, ATOS etc.
post 617
my amp is fully HDMI 2 spec but it does not have HDCP 2.2 which is needed to pass HDR. so yes its new amp time... lol
as i said in my earlier post the HTPC is sending the HDR to the TV when connected directly and playing HDR content with madvr. its either windows HDR switching or nvidia drivers not working correctly that is not dynamically switching on/off the HDR.
i dont know why windows even has an HDR switch as HDR should be turned on/off dynamically depending on content. its what HDR is all about.
after digging about for a while today it seems that the latest xbox has dynamic HDR switching for games. now i could be wrong but is the xbox and windows not the same OS. if it is would in not just be the case of copying the drivers from the xbox to windows to enable HDR dynamic switching.
either microsoft or nvidia need to get this sorted as it seems like neither of them have a clue as to what they are doing. the AV hardware vendors seem to have things sorted so you would think that it should not be that hard to implement.
please forgive if i'm sending this thread in the wrong direction.
(2018-03-04, 19:10)Bibio Wrote: [ -> ] (2018-03-04, 17:22)m0v1em4n Wrote: [ -> ]What video driver are you using?
Update your driver, I believe latest is 390.77 or even higher now.
MS offers their API and NVidia offers theirs. I think they have a clue and have had one for a long time now. What software does or doesn't do with them, is another story. I'm not sure you understand how HDR works? For one thing, when using with MPC players and related components, Windows HDR switch has zero to do with anything. That's why we always leave it off and never activate it. You might notice it doesn't even switch on when playing in HDR and it shouldn't using this method or others such as DVDFab player. I don't know about your Xbox but this forum has nothing to do with that. The NVidia API integrated with madVR for various compliant players like MPC turn on/off HDR mode automatically as intended. So does DVDFab. Early drivers as HDR developed were iffy at times but has been stable for quite some time now. If you're having problems, I don't think Nvidia or MS are responsible much less clueless.
