If I did not make mistakes, removing height and width, it is not applied to the green check of the rules the field.
(2016-02-03, 05:51)Warner306 Wrote: [ -> ]It might be necessary to use a single profile for 3D videos.
You mean, that goes well even for 1080p ?
if, you, is not possible, with render settings for 1080p applied to the profile 1080p 3D , too dropped frames and high rendering values in ms.
That's why I have to have 2 independent profiles (Scaling Algorithms) (Processing) and (Rendering)
Does DSPlayer run the same on Jarvis nightlies compared to Isengard?
(2016-02-03, 13:06)Zpectre87 Wrote: [ -> ]Does DSPlayer run the same on Jarvis nightlies compared to Isengard?
Yes, and it works with recent versions of madVR.
(2016-02-03, 10:35)gotham_x Wrote: [ -> ]If I did not make mistakes, removing height and width, it is not applied to the green check of the rules the field.
I thought a single profile rule If (3D) else might work. I can't understand what might be wrong with the original rule.
(2016-02-03, 22:21)Warner306 Wrote: [ -> ] (2016-02-03, 13:06)Zpectre87 Wrote: [ -> ]Does DSPlayer run the same on Jarvis nightlies compared to Isengard?
That's cool, I think I'll keep using it then and maybe stay on Jarvis for a while, not much need to upgrade.
I had a play with this today and media player with madvr works a treat but in kodi it works in a window but as soon as i go full screen i get a crash is this a setting im missing?
(2016-02-06, 17:39)Derek Wrote: [ -> ]I had a play with this today and media player with madvr works a treat but in kodi it works in a window but as soon as i go full screen i get a crash is this a setting im missing?
Pretty hard to tell with that information. What are your DSPlayer settings?
Baring in mind I've already set up ReClock, disabled bitstreaming, adjusting the PCM audio on the fly so it's bitperfect, is there a way to account for the 70ms of lag that the display mode I'm using on my TV introduces? I tried using audio delay in the LAV Audio Filter but it seems to reset itself every time you close the dialog window and reopen it.
Anyone care to share their settings for a HD4000 GPU? Only 1GB.
(2016-02-06, 23:53)Warner306 Wrote: [ -> ] (2016-02-06, 23:38)danjames92 Wrote: [ -> ]Baring in mind I've already set up ReClock, disabled bitstreaming, adjusting the PCM audio on the fly so it's bitperfect, is there a way to account for the 70ms of lag that the display mode I'm using on my TV introduces? I tried using audio delay in the LAV Audio Filter but it seems to reset itself every time you close the dialog window and reopen it.
Try this: 2033893 (post).
Is there a way to check it's working? I've edited and placed in the correct directory.
(2016-02-06, 23:00)Warner306 Wrote: [ -> ] (2016-02-06, 17:39)Derek Wrote: [ -> ]I had a play with this today and media player with madvr works a treat but in kodi it works in a window but as soon as i go full screen i get a crash is this a setting im missing?
Yeah i agree,
Im running it on an older PC so will get a debug log up ASAP see if that helps,
Should i use the external codec settings i've configured for mediaplayer?
Got it working perfectly, thanks for the link Wanilton. There was something a little off about it before, disabled auto delay on my amp, set a manual of 250ms and the lip sync is perfect. I could see a difference at 175ms, I must have very sensitive eyes. Happy Days.
I recently upgraded from kodi dplayer 15 to kodi dsplayer 16 (I tried as well beta1 als latest unofficial build from Wanilton). I am using kodi dsplayer together with SVP4 pro and the software it installs (madvr, reclock, lav filters, etc..).
I had stuttering video and found out that it was GPU (nvidia geforce GTX750) that was running at high cpu and clipping to 100%, causing the stuttering video. When setting hardware decoding back to "none" instead of "nvidia cuvid" in settings -> dsplayer -> videodecoder the issue was solved. I ONLY upgraded kodi, all the other software was not updated, so it seems to be the new kodi installation that causes this higher GPU load.
Why is kodi 16 using GPU more heavily then kodi 15? Any explanation/solution for this, other then disabling hardware decoding?
