(2016-12-09, 16:35)JoshDi Wrote: [ -> ] (2016-12-08, 23:52)quixote23 Wrote: [ -> ]I have a question. Prior to the Krypton 17 DSPlayer release, I was using playercorefactory.xml (or the built-in rules) to send all videos encoded with .aac to DVDPlayer instead of DSPlayer (weird quirk of my system, short answer is that after hours and hours of fighting with it I found that this was the easiest solution.)
However, Krypton changes the name of DVDPlayer to VideoPlayer. I've tried changing this in playercorefactory.xml (just replacing 'DVDPlayer' to 'Videoplayer' for the relevant rules) but Kodi is still defaulting to DSPlayer when I try to play those files. Does anyone know what the default video player should be called now? Should I be creating a new player entry here even though it wasn't necessary before, and what would that look like?
It works for me... I changed DVDPlayer entries to VideoPlayer
The value may be case sensitive
Sent from my SM-N910V (typie typie)
Weird... I tried that too (with case-correct VideoPlayer) and it didn't work for me.
Ah well. I finally sorted out my AAC codec problems so it's a moot point now. Thanks for the reply though.
Hi, with dsplayer enabled i could not watch pvr. (I use DVBViewer as Backend). Is there a way to get DVBViewer PVR to work with dsplayer? Or else, what i have to do so that only movies use dsplayer?
Here is my log:
08:04:06.457 T:10080 NOTICE: CDSPlayer::OpenFile - DSPlayer: Opening: pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_1.pvr
08:04:07.600 T:10080 NOTICE: CDSPlayer::OpenFileInternal - DSPlayer: Opening:
08:04:07.600 T:10136 NOTICE: CDSPlayer:
rocess - Creating DS Graph
08:04:07.601 T:10144 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/filtersconfig_internal.xml (filters configuration).
08:04:07.604 T:10144 NOTICE: Loading filter core factory settings from special://profile/dsplayer/filtersconfig.xml (filters configuration).
08:04:07.605 T:10144 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/filtersconfig.xml (filters configuration).
08:04:07.610 T:10144 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/mediasconfig_internal.xml (medias configuration).
08:04:07.611 T:10144 NOTICE: Successfully loaded rules
08:04:07.611 T:10144 ERROR: CFGLoader::LoadFilterRules Extension "" not found. Please check mediasconfig.xml
08:04:07.611 T:10144 ERROR: CFGManager::RenderFileXbmc Failed to load filters rules
08:04:07.611 T:10144 NOTICE: thread end: CDSGraphThread::OnExit()
08:04:07.611 T:10136 ERROR: CDSPlayer:
rocess - Failed creating DS Graph
(2016-12-10, 10:09)MaxMan23 Wrote: [ -> ]Hi, with dsplayer enabled i could not watch pvr. (I use DVBViewer as Backend). Is there a way to get DVBViewer PVR to work with dsplayer? Or else, what i have to do so that only movies use dsplayer?
Here is my log:
08:04:07.600 T:10136 NOTICE: CDSPlayer:rocess - Creating DS Graph
08:04:07.611 T:10136 ERROR: CDSPlayer:rocess - Failed creating DS Graph
That backend is not supported. Try NextPVR or MediaPortal and Argus TV.
I installed both 32- and 64-bit versions with the latest MadVR on a beefy HTPC (i7, 32GB DRR4) and after playing most video files I get almost 100% of my RAM used so everything becomes choppy or even crashes.
Has anyone else had that issue? Would love some feedback before i reinstall everything from scratch...
I use Krypton beta 6 with DSPlayer, but whe i use madvr is after videostart blackscreen, close can i only withe taskmanager, without mdvr DSPlayer works fine.
MPC.HC with madvr works correctly...
Question:
"Update internal LavFilters to v0.68.1.45 (DSPlayer version)"
What is the different to normaly LavFilters?
Thanks a lot
revilo
I have a question. I have downloaded the latest dsplayer branch from git . I have followed the compile instructions from the wiki. All went fine. Now i have dsplayer32bit.
Can someone point me how to compile the 64bit version? what do i need to do?.
Question- Is reclock necessary when bitstreaming? I have a 7.1 av receiver connected via HDMI that is capable of dts HD and true HD. I have never used reclock but see it constantly mentioned on various forums.
(2016-12-10, 23:43)_Andy_ Wrote: [ -> ]I have a question. I have downloaded the latest dsplayer branch from git . I have followed the compile instructions from the wiki. All went fine. Now i have dsplayer32bit.
aracnoz posted an installer a couple of pages ago.
(2016-12-11, 00:11)bkrieger Wrote: [ -> ]Question- Is reclock necessary when bitstreaming? I have a 7.1 av receiver connected via HDMI that is capable of dts HD and true HD. I have never used reclock but see it constantly mentioned on various forums.
ReClock is not necessary if bitstreaming. Either it or Sanear will do fine.
So you do recommend using a program of some kind for audio sync, and not using nothing at all?
(2016-12-11, 03:54)bkrieger Wrote: [ -> ]So you do recommend using a program of some kind for audio sync, and not using nothing at all?
ReClock prevents frame drops by syncing the audio to the video. It won't fix audio sync issues.
(2016-12-10, 18:42)Warner306 Wrote: [ -> ] (2016-12-10, 10:09)MaxMan23 Wrote: [ -> ]Hi, with dsplayer enabled i could not watch pvr. (I use DVBViewer as Backend). Is there a way to get DVBViewer PVR to work with dsplayer? Or else, what i have to do so that only movies use dsplayer?
Here is my log:
And how to enable movies with dsplayer and pvr with the normal player?
