I just checked all PRs. There is only one PVR fix more than in my build. I will wait for the official release of 17.1 RC1 and make another build.
(2017-02-23, 21:04)SALAMINOMACHOS Wrote: [ -> ]@ Warner306
Focus on madVR display modes and turn off refresh rate matching in Kodi. You want to add: 2160p23, 2160p24, 2160p50 and 2160p60.
Thanks a lot
i changed all the 2160's with 1080 and 720 , and everything is perfect now
Not dropped frames atall
The only strange is , when i start a movie , it delays for about 2-3 seconds
the delay is normal. it is due to the change of resolution/refresh rate to your TV/Monitor
So currently I am not using any Hardware acceleration at all in LAV. "None" is selected.
watch gallery
I have also previously disabled refresh rate switching in Kodi.
Warner, I have updated the display modes previously as well after reading a separate post by you.
watch gallery
Any other suggestions?
Also, regarding your question about refresh rate, I don't know if it is related, however for me to get videos to play in 60fps on the rare occasions they do play, I have to enter windowed mode and then back to full screen. I also still have the problem where about 10% of the right side of my screen is off of the display. Going to windowed mode and back fixes this as well. I have done the screen configuration and scaling options in Kodi with no success to fix this issue. I have added another log file below to show what happened. In this case, the video did play and I just had to go to windowed mode and back to get correct FPS and display scaling.
http://pastebin.com/mg49DcTR
-Sayajin
(2017-02-23, 18:08)Warner306 Wrote: [ -> ] (2017-02-23, 10:51)oldpainless Wrote: [ -> ] (2017-02-23, 08:37)Sayajin Wrote: [ -> ]So after weeks of trying different settings and messing with stuff, I am turning here for help. I have been unable to successfully run DSPlayer without it continually crashing and giving me errors since day 1. I am confident the issue is with DSPlayer and not MadVR as MPC-HC runs flawlessly with MadVR.
I have tired multiple versions, 32bit and 64bit, multiple installs, multiple settings, DX9 instead of 11, no fullscreen exclusive and everything else I can think of.
Essentially, I load Kodi, play a file and 60% of the time the application crashes, freezes, or displays no picture and freezes but has sound. I have attached a pastebin file for analysis. I am at a loss as to the issue and am close to giving up hope. Please review the log and advise.
http://pastebin.com/CZqJaetr
http://pastebin.com/h8FpC6H1
I'm no expert on crash reports, but:
21:30:25.445 T:7284 DEBUG: CRenderDSManager::Configure - change configuration. 1920x1080. display: 1920x1080. framerate: 23.81.
21:30:26.445 T:7284 WARNING: CRenderDSManager::Configure - timeout waiting for configure
Two questions - what are you using in Lav Video - Cuda, Native or copy back? Try copy back if not already using. And, have you disabled refresh rate change in Madvr and enable in Kodi? With a 4k display,not sure why its trying to switch to 1080p...and that framerate looks odd.
K
(2017-02-24, 00:17)_Andy_ Wrote: [ -> ]I just checked all PRs. There is only one PVR fix more than in my build. I will wait for the official release of 17.1 RC1 and make another build.
Awesome! I Will try your build tonight!
One other question.. im using Windows 10 64bit And so im using Kodi dsplayer 64bit aswell..
But Will a 32bit version of Kodi run more stable? Anyone suggestions?
Verstuurd vanaf mijn MI 5 met Tapatalk
Aracnoz has released the fix one day after he updated his github. So i don't have access to the fix. I hope he will surprise us all when 17.1 final is released. So keep fingers crossed.
(2017-02-24, 19:45)_Andy_ Wrote: [ -> ]Aracnoz has released the fix one day after he updated his github. So i don't have access to the fix. I hope he will surprise us all when 17.1 final is released. So keep fingers crossed.
OK
Thanks for clarification.
(2017-02-19, 06:39)_Andy_ Wrote: [ -> ]Can someone please test to play a bluray iso with the Kodi internal VideoPlayer with the DSPlayer x64bit version?
With the x64 version of DSPlayer i get an error of a mising libbluray.dll (ERROR: Win32DllLoader::Load: Failed to load "C:\Program Files (x86)\Kodi17_ds_x64\libbluray.dll" with error 126: "Das angegebene Modul wurde nicht gefunden.) but the dll is in this directory. So i guess it's because of the x64 version or maybe it's because of my system.
The same bluray iso works fine with the x32 version of DSPlayer.
It would be nice if someone can confirm or not confirm, so i know it's my system or the x64 of DSPlayer.
try to replace the dll with this one
http://www.mediafire.com/file/027eildk20...ay_x64.rar
I built all dependencies last summer in a few days and I've never tested all kodi features so why I continue to mark this version as unstable, plus there are most of the binary addons that are not working because there is only the 32bit version available
p.s.
I updated the package with all the dependencies
https://github.com/aracnoz/xbmc/releases...cies_x64_1
from now this dll is already included
I do not know why your build still have the problem but my github is updated with all my patches since the day I posted the fix for videoplayer here on the forum
Hello aracnoz. Thanks for the continuous support. The libbluray is working now in the x64 version. I know the x64 is marked as unstable but for me you did an amazing job and the x64 is stable as the x32. I only found two issues that is not working like in the x32 build. The python module PIL and the libbluray. I don't blame you because i know x64 it's experimental. I only want to report what i found.
If your PVR fix is in your github than the fix is in my build too. I can't test this because i don't use and have PVR. I only saw you have released the fix one day after you have updated github. As i'm not really good in c++ and reading such amount of code i assumed the fix is not in github. If the PVR fix is not working in my build maybe the new PRs from Kodi Krypton broke this. No user who uses my build confirmed or not confirmed the PVR fix.
So i don't really know if PVR is working as expected.
Maybe the user who asked can download and test the builds (aracnoz PVR fix and my build) if PVR is working as expected or not and report.
Regarding this PVR channel switching issue. I just checked that the official 17.1 RC1 works correctly, no problems in channel switching. Also both 17.0.1-versions (32/64bit) by aracnoz works. But these new versions, which _Andy_ has built based on 17.1 RC1, introduced this bug again. Strange, especially if the aracnoz fix after all should be included in these.
(2017-02-21, 16:15)goldenfingaz Wrote: [ -> ]I build a net HTPC with a Intel Pentium G4560 on a DeskMini 110 and the problem is the gui is blinking when i watch a video, help me please.
http://pastebin.com/7Bfd5ksY
Any idea how i get rid of the blinkin gui ?
Like I asked before, should I use the 32 bit version on my 64 bit machine? Will this be more stable? Have the 64 bit version any benifits?
