Thank you Spoyser... seems easy enough to do.
I've created a Super Favourites Folder called "Mediatheken".
In this folder there are kodi video addons and android apps combined.
Additional to that is that I added this folder as widget on my main menu.
The problem is, when opening an addon or an app, it firstly opens an empty list, then it's actually opens the addon/app.
As my english is not very good, I've made a short video which is showing my problem:
Video
Is there anything I can do to prevent this?
(2016-04-23, 20:29)ErAzOr2k Wrote: [ -> ]Hi,
Video
Firstly check you are running the latest version from my repo, 1.0.50 I think
Any chance you've cracked the code on that addon that won't allow playback from SF?
Sent from my iPhone
(2016-04-23, 20:32)spoyser Wrote: [ -> ] (2016-04-23, 20:29)ErAzOr2k Wrote: [ -> ]Hi,
Video
Thanks for your feedback. I' on 1.0.51
(2016-04-23, 20:35)ed_davidson Wrote: [ -> ]Any chance you've cracked the code on that addon that won't allow playback from SF?
Sent from my iPhone
Yes but in the meantime try this:
From the context menu select Edit Super Favourite, then choose Manually Edit Favourite.
Leave everything the same except change the windowID to 10005 - its a hack but it will work.
I've been playing around with the run script option in SF and am having trouble getting it working. I'm trying to run this bash script:
#!/bin/sh
rm -rf /var/media/Storage/Incoming/*
The manual entry I've added is:
<favourite name="Clean torrents" thumb="">RunScript("bash /storage/.cache/clean.sh")</favourite>
It's basically to clean a download dir. I've tried the entry without bash and still doesn't seem to run. Can SF run a bash script? Or do I need something like advanced launcher?
(2016-04-24, 11:49)Morphy99 Wrote: [ -> ]I've been playing around with the run script option in SF and am having trouble getting it working. I'm trying to run this bash script:
#!/bin/sh
It basically calls
xbmc.executebuiltin(RunScript(blah))
So I doubt what you have will work.
What you could do is write a python script to clean the download folder and call that from SF
(2016-04-24, 13:49)spoyser Wrote: [ -> ] (2016-04-24, 11:49)Morphy99 Wrote: [ -> ]I've been playing around with the run script option in SF and am having trouble getting it working. I'm trying to run this bash script:
#!/bin/sh
It basically calls
Ok thanks thought so. I'm a complete noob when it comes to python so I may give advanced launcher a go unless anyone could kindly knock one up for me.
Video
1.0.50 and 51 ?? On official kodi repo it's 1.0.43.... i need to install a "unofficial" repo for obtain this newest version ?
(2016-04-24, 16:10)DjDiabolik Wrote: [ -> ] (2016-04-23, 20:32)spoyser Wrote: [ -> ] (2016-04-23, 20:29)ErAzOr2k Wrote: [ -> ]Hi,
Video
Correct.
Number of reasons, Kodi don't like too many updates in quick succession, about 1 month. I tend to push updates a lot quicker, so my repo has the latest version.
1.0.50 was submitted to the org about a month ago but I think they are swamped at the moment.
You said you had 1.0.51 anyway so I assume you have my repo installed.
(2016-04-24, 14:05)Morphy99 Wrote: [ -> ] (2016-04-24, 13:49)spoyser Wrote: [ -> ] (2016-04-24, 11:49)Morphy99 Wrote: [ -> ]I've been playing around with the run script option in SF and am having trouble getting it working. I'm trying to run this bash script:
#!/bin/sh
It basically calls
stackoverflow is your friend:
http://stackoverflow.com/a/185941
(2016-04-24, 16:41)spoyser Wrote: [ -> ]stackoverflow is your friend:
Thanks man I did look at this page when I googled briefly but I wasn't sure it was applicable to my goal. It was a bit scary dabbling with scripts that remove data too
Working great now
(2016-04-24, 16:32)spoyser Wrote: [ -> ] (2016-04-24, 16:10)DjDiabolik Wrote: [ -> ] (2016-04-23, 20:32)spoyser Wrote: [ -> ]Firstly check you are running the latest version from my repo, 1.0.50 I think
Correct.
*EDIT*
Great info.... i have .43.. the currently version on official kodi repository...........
I thinks i have found you repo and i goes to install in about 50min later
