I'm trying to add something to SF then add that to kodi favoourites.
I can add to kodi favourites. But the link doesn't work (I don't get sent to what I saved the favourites as). Is it working for you?
(2015-05-31, 21:04)MediaPi Wrote: [ -> ]I'm trying to add something to SF then add that to kodi favoourites.
Can you send me the favourites.xml (the SF one) file with the item in it before you add it to kodi favourites and I'll take a look.
Also try this, in your kodi favourites file change the mode=660 to mode=650 see if that helps
PM sent. Short answer changing mode=660 to mode=650 works but after a split second I get sent back to video addon menu.
(2015-05-28, 23:11)SportySpice Wrote: [ -> ]Hello spoyser, your plugin is great.
Would you mind telling me how exactly do you override kodi's context menus and retrieve any folder's path/url at the same time? I would like to add a similar feature in my new addon YouTube Collections
If you look in the source, the code for it is in capture.py (build the menu contents and handles selection) and menus.py (display menu and returns selection)
Have a look and give me a shout if you get stuck.
I love this add on TY
I do wish there was a feature to auto sort your favorites via the alphabet
Is there a way to display super Fav tv show description below the selected show fanart?
I only have the options: List, Big List, Wide, And Thumbnail
Can Media Info or Media Info 2 be added?
Thank you in advance
Amazing AddOn Spoyser!
Quick question:
Would it be possible to have "info" displayed for a description of a SuperFav? Maybe a txt file to choose and display similar to how picking an icon or fanart works?
Or, is this something that would need to be included into the skin's ViewType settings? (Info and Info2 viewtypes from confluence...other skins w/ info in viewtype.....ect)
Since Advanced Launcher doesn't work for android and I can't add Android Apps (Games) to RCB, I want to have a sub-menu of Android Games under the Games Main Menu. The only way to have this list is through this wonderful AddOn.
Minor cosmetics, I know, but if it's possible, I think it'd be pretty cool and "SUPER" useful.
(2015-06-06, 17:19)harpua1982 Wrote: [ -> ]Amazing AddOn Spoyser!
Quick question:
Actually I like the sound of that.
For most items I could probably pick up the text automatically from existing info labels, eg plot or addon description. Obviously this would only work using the SF menu override system.
If I then set the content type to movies and set the plot info label to the text that would show up in the mediainfo views.
Thank you for considering the feature and your response.
Super Favorites is the best addon I've found and most useful for kodi I have found.
Keep up the good work.
Thanks Again
Also How do I donate to the Super Favorites developer via Paypal as soon as I can I will when my budget lets me because I'm disabled and on a fix income?
(2015-06-06, 20:28)Coolcell Wrote: [ -> ]Thank you for considering the feature and your response.
Thanks Again
No problem, I'm always looking for feature suggestions and I liked yours.
Donations aren't necessary.
(2015-06-06, 19:35)spoyser Wrote: [ -> ] (2015-06-06, 17:19)harpua1982 Wrote: [ -> ]Amazing AddOn Spoyser!
Quick question:
Do you think it would work w/ Apps outside of Kodi?
On Android, within Kodi you're able to access "Android Apps" (programs that run outside of Kodi) in addition to Program Addons from the Program menu (confluence skin). From there I'm able to superfav those android apps. (note: I'm only able to access these apps with the Confluence skin. Once I favorite them, I can access them w/ any skin).
That being said, I'm not sure if they have existing info labels or not.
Would work great for movies/music/ect.
Being able to choose the txt file could open up many possibilities, if possible. (i.e.playlist descriptions/stream descriptions/ect.)....just a thought, anyway.
