How would I get rid of a locked folder? I was testing the feature on my phone, but when making the password I must have hit the wrong thing. So now I cannot get rid of the test folder.
(2016-08-09, 23:54)AquaNaga Wrote: [ -> ]How would I get rid of a locked folder? I was testing the feature on my phone, but when making the password I must have hit the wrong thing. So now I cannot get rid of the test folder.
Browse to the folder via file manager and delete all the files in it, it should then delete normally
Sent from my iPhone
I have created a new SF folder. In there I put all my apps, etc. that I wanted too. Is there a way to get rid of the "Create new Folder Icon" and the space after it?
(2016-08-11, 05:15)jspyke52 Wrote: [ -> ]I have created a new SF folder. In there I put all my apps, etc. that I wanted too. Is there a way to get rid of the "Create new Folder Icon" and the space after it?
If it were possible where do you think the display setting (that's a clue
) might be?
Sent from my iPhone
(2016-08-11, 12:52)spoyser Wrote: [ -> ] (2016-08-11, 05:15)jspyke52 Wrote: [ -> ]I have created a new SF folder. In there I put all my apps, etc. that I wanted too. Is there a way to get rid of the "Create new Folder Icon" and the space after it?
If it were possible where do you think the display setting (that's a clue ) might be?
Sent from my iPhone
Oh I know I know, pick me, pick me. Is it in the settings
[SMILING FACE WITH OPEN MOUTH]
Sent from my iPhone
(2016-08-11, 15:12)ed_davidson Wrote: [ -> ] (2016-08-11, 12:52)spoyser Wrote: [ -> ] (2016-08-11, 05:15)jspyke52 Wrote: [ -> ]I have created a new SF folder. In there I put all my apps, etc. that I wanted too. Is there a way to get rid of the "Create new Folder Icon" and the space after it?
Sent from my iPhone
Oh I know I know, pick me, pick me. Is it in the settings[SMILING FACE WITH OPEN MOUTH]
Sent from my iPhone
Don't spoil the surprise!
Sent from my iPhone
Hi Sean,
Im having an issue with all my SF entries. They are all there but only a few seem to work. When i click on a link from the homescreen icon the SF diaglogue opens then nothing.
Not sure what you need for a debug.
(2016-08-15, 18:37)ed_davidson Wrote: [ -> ]Hi Sean,
I just started using Kodi and Super Favourites yesterday, and I'm seeing the same behavior. Whether links I make actually work or not seems really flakey. When they don't, if I add a new link, most of them suddenly start working again... but only temporarily. I just updated to 1.0.43 and the behavior remains. Let me know if I can do anything to help debug!
Thanks,
- Alex
I tried uploading a log but get a script error with the KODI log uploader. I tried to find the log and copy it but it's not in the .kodi folder.
alexg - turn debugging on in SF settings, then click some links. Then try and upload the log or copy it. The log.txt file should be in KODI folder.
FYI 1.0.55 is the current version.
Edit: Here is the log with debugging turned on
https://www.dropbox.com/s/srfbkidqgkc6sbs/kodi.log?dl=1 found it in the temp folder on. android.
Sent from my iPhone
(2016-08-15, 23:30)ed_davidson Wrote: [ -> ]I tried uploading a log but get a script error with the KODI log uploader. I tried to find the log and copy it but it's not in the .kodi folder.
@alexg - turn debugging on in SF settings, then click some links. Then try and upload the log or copy it. The log.txt file should be in KODI folder.
Edit: Here is the log with debugging turned on https://www.dropbox.com/s/srfbkidqgkc6sbs/kodi.log?dl=1 found it in the temp folder on. android.
Sent from my iPhone
What do you mean by
Hi Sean,
I have icons linked to super favourites on my home screen by adding them to kodi favourites. When I click on those links the super favourites dialogue box comes up saying that it's opening. Then nothing happens apart from the box going away. It doesn't actually open the favourite. Hope this helps. I can send a screen shot.
It only does it on 1 android device. All others seem fine. I've tried a full reinstall on a fresh version of 16.1 but it's the same.
Sent from my iPhone
SPOYSER
I keep getting this annoying issue where i when i click on my folder link for say MOVIES rather then that coming up i get the whole list of every SF list i have and then if i click on MOVIES in that list it takes me to it.
The other issue is where ei have an add-on saved in a section for say movies sometimes rather then taking me to that add-on it takes me again to that list of all my SF
Looks like Super Favourite's repo is down at the moment. Hope it's back up soon.
Later...
Bob
(2016-08-17, 22:58)ilovemymac Wrote: [ -> ]SPOYSER
The other issue is where I have an add-on saved in a section for say movies sometimes rather then taking me to that add-on it takes me again to that list of all my SF
I keep having the same problem. I click on a link stored in my SF, and instead of going where is is supposed to, it takes me to my master SF I have set up. Sometimes after clicking 3-4 times it will eventually go to the right place. More frustrating is when you hit the go back button, it will do the same thing, take me to my master SF folder. Driving me crazy lol. Seems I have been having this problem since the last update?? Also, was wondering... Spoyser repo is not working either?
(2016-08-19, 02:16)tvguru Wrote: [ -> ] (2016-08-17, 22:58)ilovemymac Wrote: [ -> ]SPOYSER
Any solutions?
