Komet..
latest nightly..
TVshows
i need to scrape latest homeland episode
By just clicking the homeland episode Mediaelch moves the display and this selected episode is last...
also i ve noticed in the latest nightly series that have new episodes move to the top of the list,
the thing is that when the new episodes are scraped one has to click on the show in order to be moved to its regular place.
is it also possible to move the series to its regular place when the last new episode is scraped?
MediaElch 2.3.2 is not downloading _any_ media for me. Also the first time, I start MediaElch it is crashing. I reported this some time ago, but no one answered.
Win7, MediaElch extracted to a new folder. It loads the Series and Films wothout problems.
(2015-12-01, 17:43)Solo0815 Wrote: [ -> ]It loads the Series and Films wothout problems.
And where is the problem?
(2015-11-29, 22:58)solamnic Wrote: [ -> ]also i ve noticed in the latest nightly series that have new episodes move to the top of the list,
I just fixed this right now.
Your second problem is a little bit hard to reproduce but I'll have a further look at it.
(2015-12-01, 17:49)Komet Wrote: [ -> ] (2015-12-01, 17:43)Solo0815 Wrote: [ -> ]It loads the Series and Films wothout problems.
It loads ("imports" is the better word, I think) the pictures from the HDD without any error. It does
not download Pictures from
online sources like TheTVDB.com or Fanart.tv at all. Not for Films, not for my TVShows.
Already reported here:
http://forum.kodi.tv/showthread.php?tid=...pid2135151 some time ago.
Thx for any help
Which Folder do I need to delete to start from scratch? I already deleted the kvibes-folder with the sqlite-db
(2015-12-01, 17:58)Solo0815 Wrote: [ -> ]It loads ("imports" is the better word, I think) the pictures from the HDD without any error. It does not download Pictures from online sources like TheTVDB.com or Fanart.tv at all. Not for Films, not for my TVShows.
Thx for any help
The folder that is used by ME is ~/.config/kvibes
It contains a configuration file.
If you want to drop the sqlite database I suggest you install a database editor like sqlitebrowser or sqliteman from the repo's. I would not suggest to delete the database (folder) itself. Might do more harm than good
HTH
@Solo0815: Back to your "old problem": I saw that sometimes the settings dialog "falls" behind the main window after selecting a folder. This looks like MediaElch freezes but the settings window is still responsive and needs to be closed.
So you can add your sources now and MediaElch displays your movies. What happens exactly when you try to scrape a movie? Does it load title, actors, plot and so on? What happens if you click on an image? Lets take "Poster": It should show a dialog which has the available scrapers and the search query on top and the previews of found posters in the main part. Do you see this? And if yes: What happens if you click on an image?
It is safe to delete all settings, the cache and the database of MediaElch (you just need to adjust the settings again): What files you need to delete depends on you filesystem:
http://community.kvibes.de/topic/show/wh...ngs-stored
I deleted all folders and the regkey and started from scratch.
If I click on "Settings" > "Add sources" (Hinzufügen) ME reezes and nothing is clickable. Even on Alt+Tab the ME-window is not shown. The ME-window buttons: Close, Minimize and Maximize can't be clicked. ME must be killed with the Taskmanager.
To the DLProblem:
It does not load any image, even when I click on a existing Image and want to replace it with another. I tried different online-sources, like TheTVDB.com or Fanart.tv. I see only the "spinning" loading message in the lower right corner.
But can you scrape other information? Is MediaElch maybe blocked by a firewall?
EDIT: nevermind, found the nightlies in the community section... blindme
(2015-12-02, 01:33)Komet Wrote: [ -> ]But can you scrape other information? Is MediaElch maybe blocked by a firewall?
Will try that, when the "no window response"-bug is fixed. Atm I can't add new sources, because of a freezing ME
(2015-12-02, 18:26)Solo0815 Wrote: [ -> ]Will try that, when the "no window response"-bug is fixed. Atm I can't add new sources, because of a freezing ME
That's really strange. And it is still working for you with 2.2? And with 2.3 its broken? I've not received a bug report according this so it must be some special thing at your side. I've also just checked it with Windows 7 and it's working...
no prolems here with win10
and love the new stuff KOMET
well done and big THX
(2015-12-02, 22:27)Komet Wrote: [ -> ] (2015-12-02, 18:26)Solo0815 Wrote: [ -> ]Will try that, when the "no window response"-bug is fixed. Atm I can't add new sources, because of a freezing ME
I overwrote the 2.3.2 files with the 2.2.2-versions and it worked! I can add Films and Series without a problem.
What I saw is, that with version 2.3.2, there where no message "Lade Filme" (Loading films), which appeared after overwriting with version 2.2.2. I had no Films or Series or Music sources added.
-> 2.2.2 is working, adding sources, scraping and DL images is no problem (Firewall on)
overwote the files with 2.3.2
-> 2.3.2. is working the first time. I can't get any images, but Plot and other text is fine. I can't add sources (freezing, no focus) and when I close MediaElch, I can reopen it. But when I look at the TaskManager, there are 2 processes of ME. If I kill both, I can not start ME again.
Replacing all files with 2.2.2 versions does resolve ALL the problems.
There might be something special on my side, but also on ME 2.3.2.s side
