(2023-07-01, 16:55)Wanderer189 Wrote: [ -> ]Is there any way I can manually add the TheTvDb scraper back into the current release and make it usable again? There are certain old news shows like 48 Hours and Dateline that nothing works but TheTvDb. I have actually had to go back to ME v2.8.12 just to attempt to fix some of this stuff
Hi, sorry, but there isn't. MediaElch never used their latest API version, but I tried updating MediaElch to their latest version and found too many issues besides the licensing stuff that I decided not to support it anymore.
If you send me a private message on the Kodi forum with your operating system (Windows/Linux), I can see what I can do.
Regards,
Andre
(2023-07-01, 23:47)Kallita Wrote: [ -> ]Just something that has been in the back of my mind for a while...
When loading information(mainly for movies) is there any way to automatically filter out everything after the year?
99.9% of the movies i am loading info for are of the
Name (year) extra info about supplier and format
variety and I need to manually remove all of the info after the year.
Is there anyway to get the program to ignore or remove that extra stuff automatically?
Thanks for your time and program.
<me>
You mean to just strip everything after the year? i.e. the default movie name that is generated from the file / directory name? :-)
There isn't at the moment.
Regards,
Andre
bugwelle - This latest version is not working for me. When I click on an artist, or album it returns nothing. If I go back to the previous version, then it works well. Any ideas as to what can be going on here?
Regards,
Shedrock
(2023-07-03, 20:58)shedrock Wrote: [ -> ]@bugwelle - This latest version is not working for me. When I click on an artist, or album it returns nothing. If I go back to the previous version, then it works well. Any ideas as to what can be going on here?
Thanks for reporting. What system do you use and which Version of MediaElch have you downloaded? e.g. "Windows 10" and MediaElch v2.10.2 for "Windows 10 and later" or "Windows 7/8"?
I tested it quickly on all major systems and it worked for me. Just tested it on Windows 10 again and artists appear. Which version did you downgrade to? v2.10?
Regards,
Andre
(2023-07-04, 18:44)bugwelle Wrote: [ -> ]What system do you use and which Version of MediaElch have you downloaded? e.g. "Windows 10" and MediaElch v2.10.2 for "Windows 10 and later" or "Windows 7/8"?
I am using Windows 10 & MediaElch v2.10.2 for "Windows 10. I had to downgrade to version 2.10.0 for it to work.
Shedrock
hey, just as a heads up im getting broken icons and odd resolution errors on linux. Not even sure where to start in diagnosing it. Not a huge deal but I thought I would let you know.
Not sure when stopped working. In v2.10.2 "TV Tunes" isn't working. Older version still are. Just reporting
Just to let you know:
"Movie Original Title" tick box does not seem to be working.
program is not saving original name with it ticked or not ticked
2.10.2 on windows 11(latest)
shedrock The Universal Music Scraper had a bug. It's now fixed. However, it shouldn't work in previous versions either. Nevertheless, the latest snapshot version (see
https://mediaelch-downloads.ameyering.de/snapshots/ ) will fix this issue.
PopcornLinux I guess you use the Qt5 version, correct? See
https://mediaelch.github.io/mediaelch-do...nformation for how to check. The Qt6 version has fixed a lot of those UI issues, see
https://github.com/Komet/MediaElch/issue...1312743005 for an example comparison.
Our linux versions do not come with Qt6 support out of the box. I plan to update our release script for the Ubuntu PPA for Ubuntu 23.04 and later: I want to use Qt6 there.
If you want Qt6 support, you have to build MediaElch yourself, see
https://mediaelch.github.io/mediaelch-do...index.html for guides.
Kallita Thanks. Fixed it in the latest snapshot version.
Wanderer189 It works for me. However, there is no good error reporting. If a TV show can't be found, you won't get notified. For example, "American Dad!" does not work. "American Dad" does. I've opened
https://github.com/Komet/MediaElch/issues/1605 to keep track of it.
Regards,
Andre
(2023-07-08, 19:53)bugwelle Wrote: [ -> ]@shedrock The Universal Music Scraper had a bug. It's now fixed. However, it shouldn't work in previous versions either. Nevertheless, the latest snapshot version (see https://mediaelch-downloads.ameyering.de/snapshots/ ) will fix this issue.
I just tried the snapshot version for Windows 10 but it is still not working for me. It brings up nothing when I scrape an Artist, and/or Album.
You are right in regards to it not working in the previous version, but the thing is, when I scrape an artist, the info does get populated, but there is no scraping of the discography. I am not sure if that's what you meant by it's not working with Universal Scraper.
Regards,
Shedrock
re Original Name for movies
Still not working with 2.10.03
downloaded and installed the Dev version but the original name is still not being scraped/saved
went through about 20 movies to test and nothing showed up in the "Original Name" section on any of them.
Windows 11<latest>
Sorry to be a pain.
shedrock Ah, now I see. I didn't check for discography. I can confirm it. I've opened a new issue at
https://github.com/Komet/MediaElch/issues/1606 to keep track of it. I'll also need to add tests...
Kallita You're not a pain, thanks for reporting!
Do you use the "Custom Movie Scraper"? If so, which title scraper did you select? Do you have an example movie title that I can use to test?
Regards,
Andre
I noticed the "TV Tunes" no longer works but still does in older versions.
Also, it would be a VERY handy feature if you could make a "fanart" for movies like you can for episodes, JMO
Hi !
... is there a way to scrape images but not overwrite the already existing images during download ?
