e2zippo Wrote:I went back to 1.1.0 and everything worked just as usual, without any need to add my local disk as source
malte Wrote:Hmmm, this is nearly impossible. I checked all changes that I made with 1.1.1 (just two bugfixes) and nothing would explain this behaviour.
Well, thats what happened
But I did the config in 1.1.0 and it worked after upgrading to 1.1.1
e2zippo Wrote:I just browsed around alot, in Confluence, and suddenly, once in a while, I get this
https://www.sugarsync.com/pf/D6085304_609_884986444
Missing filter is not activated
This happened twice within maybe 10 minutes, once while I was editing a rom collection, the other time I didn't do anything, I didn't even touch the keyboard, and it changed.
mate Wrote:I could reproduce this now.
I did not yet find out what is causing the issue.
That's great, I'm sure you'll figure it out!
e2zippo Wrote:Since i started from scratch, I have tried importing my videos again, and I got it working for GBA, but when I try to scrape local artwork for my SNES & NES collection i get
"Site local artwork does not exist in config.xml"
What am I missing?
malte Wrote:This error was fixed with release 1.1.1. As I think your issue above is not related to release 1.1.1 you should update again and see if it will work with this one.
It worked with 1.1.1, great!
There's just a couple of issues left now (damn frodo, everything worked great in Eden
In Aeon Nox 4.0.6 (repo version) I can't get any games to load, it just stays at "loading"
I get this in the log
19:05:57 T:3044 NOTICE: RCB_INFO: onAction: 7
19:05:57 T:3044 NOTICE: RCB_INFO: Begin showGames
19:05:57 T:3044 NOTICE: RCB_INFO: helper.buildLikeStatement
19:05:57 T:3044 NOTICE: showGames: load games from db in 13 ms
19:05:57 T:3044 ERROR: EXCEPTION: Unimplemented method: Control::XBMCAddon::xbmcgui::Control::setLabel(...)
19:05:57 T:3044 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.RuntimeError'>
Error Contents: Unimplemented method: Control::XBMCAddon::xbmcgui::Control::setLabel(...)
File "C:\Users\e2-htpc\AppData\Roaming\XBMC\addons\script.games.rom.collection.browser\resources\lib\gui.py", line 397, in onClick
self.applyFilters()
File "C:\Users\e2-htpc\AppData\Roaming\XBMC\addons\script.games.rom.collection.browser\resources\lib\gui.py", line 634, in applyFilters
self.showGames()
File "C:\Users\e2-htpc\AppData\Roaming\XBMC\addons\script.games.rom.collection.browser\resources\lib\gui.py", line 678, in showGames
self.writeMsg(util.localize(40021))
File "C:\Users\e2-htpc\AppData\Roaming\XBMC\addons\script.games.rom.collection.browser\resources\lib\gui.py", line 1710, in writeMsg
control.setLabel(msg)
RuntimeError: Unimplemented method: Control::XBMCAddon::xbmcgui::Control::setLabel(...)
19:05:58 T:3044 NOTICE: RCB_INFO: onAction: 107
Also, I seem unable to return to XBMC after i quit a game, I just stay on desktop, I've tried locating any interfering programs, but my setup looks exactly the same since Eden, and it all worked good there.
Full screen setting is set to "true fullscreen" not a window, since that causes tearing in movies, so it's not really an option.
I also tried solo mode and I recieve this error when XBMC is about to launch again.
"CApplication::Create() failed - check log file and that it is writable"
Cheers malte and thanks again for you impeccable support!
