(2014-09-25, 19:46)gman3042 Wrote: [ -> ] (2014-09-25, 16:03)Zacharybinx34 Wrote: [ -> ] (2014-09-24, 21:13)gman3042 Wrote: [ -> ]Google it. This isn't app related, this is emulator related. Nobody will provide you with this.
Is there a different emulator I can use?
I suggest you read up on how emulators work.
I suggest you don't make useless posts.
(2014-09-25, 20:07)Zacharybinx34 Wrote: [ -> ] (2014-09-25, 19:46)gman3042 Wrote: [ -> ] (2014-09-25, 16:03)Zacharybinx34 Wrote: [ -> ]Is there a different emulator I can use?
Learn to read. And stop clogging up the thread with your garbage.
http://www3.nd.edu/~dpettifo/gaming/emul...index.html
Hello friends, I have everything working fine, I use Gotham 13.2, RomCollection Browser 2.0.17, Aeon MQ5 and Retroarch 1.0.0.2. I just have a question, is there any script post launch that disable the mouse?, it is really annoying having to press f11 every time I load some game to disable the cursor. Thank you very much in advance
(2014-09-26, 01:34)gman3042 Wrote: [ -> ] (2014-09-25, 20:07)Zacharybinx34 Wrote: [ -> ] (2014-09-25, 19:46)gman3042 Wrote: [ -> ]I suggest you read up on how emulators work.
I have literally every other emulator working.
Stop being obnoxious.
Hi Malte.
I did "hacked" RCB to run FBA roms using the Virtual Boy config.
Could you tell me how can I rename the Virtual boy to Final burn on platform select list?
Quote:Hyperglide Wrote:Hi everyone! I'm having an issue with RCB when I go to import Playstation games I find that all the ISO's that have .sub extension in the ROM folder always re-import when I import new games, even though they already have nfo's and have been scraped numerous times. I tried adding a *.sub to the ROM File Mask, Saved Config and it doesn't seem to fix the problem. Can anyone tell me what's causing this? It's really annoying that, whenever I go to import a new game, it constantly scrapes games I've already got data for.
You have to deactivate Rescrape already imported games in Addon Settings. This should solve the issue.
It already is deactivated. It's deactivated by default and I never activated it. Still having this issue.
Help please.
Any idea why I can't get PokemonDS games to show up? I can get literally every other game, but this one imports them, or at least scrapes them, but then nothing afterwards...
I have a problem.
When I add games to RCB, I got this message:
"ERROR: could not create artwork file." Check xbmc.log for details.
When I open the artwork folder, I had the files jpg created but the size is 0 kbytes.
I ran cat xbmc.log | tail and I have this:
22:54:39 T:140081655510784 NOTICE: RCB_INFO: Begin getFilesByWildcard. pathName = /home/juanar/ROMs/SNES/Artwork/boxfront/Sunset Riders (U) [!].*
22:54:39 T:140081655510784 NOTICE: RCB_INFO: dirname: /home/juanar/ROMs/SNES/Artwork/boxfront
22:54:39 T:140081655510784 NOTICE: RCB_INFO: filemask: Sunset Riders (U) [[]![]].*
22:54:39 T:140081655510784 NOTICE: RCB_INFO: xbmcvfs dirs: []
22:54:39 T:140081655510784 NOTICE: RCB_INFO: xbmcvfs files: ['Street Fighter II Turbo - Hyper Fighting (E) (V1.0) [!].jpg', 'Star Fox (U) (V1.2) [!].jpg', 'Mortal Kombat II (U) (V1.1).jpg', 'Mortal Kombat 3 (E) [!].jpg', 'Mortal Kombat (U) [!].jpg', 'Mortal Kombat (E) [!].jpg', 'Mega Man X (U) (V1.1) [!].jpg', 'Killer Instinct (U) (V1.1) [!].jpg', 'Final Fight Guy (U).jpg', 'Final Fight 3 (U).jpg', 'Final Fight 2 (U).jpg', 'Final Fight (E).jpg', 'Double Dragon V - The Shadow Falls (E).jpg', "Donkey Kong Country 2 - Diddy's Kong Quest (E) (V1.1) [!].jpg", 'Donkey Kong Country (U) (V1.2) [!].jpg']
22:54:39 T:140081655510784 NOTICE: RCB_INFO: Download file to: /home/juanar/ROMs/SNES/Artwork/boxfront/Sunset Riders (U) [!].jpg
22:54:39 T:140081655510784 NOTICE: RCB_INFO: File does not exist. Starting download.
22:54:39 T:140082032904096 DEBUG: ------ Window Init (DialogOK.xml) ------
22:54:39 T:140082032904096 DEBUG: Window DialogOK.xml was already loaded
22:54:39 T:140082032904096 DEBUG: Alloc resources: 1.10m
(2014-09-24, 19:24)Zacharybinx34 Wrote: [ -> ]Anyone able to get PSX games to work? I keep getting the following error.
* !Error: PSX BIOS not found [bios\SCPH7001.BIN].
I don't know why gman was being a dick about it but if you're still having this problem it just means that you're missing the relevant Playstation BIOS file. The BIOS is copyrighted material just like the game ROMS themselves, so it cannot be distributed with the emulator. You'll have to find the BIOS and copy it to the system folder of the emulator you're trying to use for PS1 games. Typing the name of the BIOS into Google should net you several different places to download it from.
(2014-10-06, 03:56)DrJuano Wrote: [ -> ]I have a problem.
I am having this exact same problem also. Only with my n64 roms all my other emulators and roms imported with no problems
Ok so this program is driving me insane. I've been trying to add local artwork now for a while and I can't figure it out. I scraped a bunch of Window games using the default scrapers and it grabbed all the art work online, but it grabbed some that were wrong or not very good. I tried to re-scrape the game and the whole selection using local artwork, but both ways won't refresh it with the art work I added in the art work folder since it already had the "wrong" art work. Just won't replace it once it has it. Is there anyway to manually put in art work or refresh it to a local source that I say? I had no problem with my movies, tv shows and other stuff. The local scraper in this program isn't worth a damn if it already grabbed the pictures off the net.
I am constantly getting the error: "Could not create artwork file". When I am importing my n64 roms. I imported my nes,sega and super nintendo roms no problem. Please help me fix this it is extremely frustrating.
Hi all, what are peoples opinions on the easiest platform to get this up and running with all emulators too?
I a running a revo r3610 and am more experienced in windows but can use Linux command line
Anyone run across a handful of random games just refusing to show up? Everything else is working just fine.
(2014-10-10, 07:06)IZNICE Wrote: [ -> ] (2014-10-06, 03:56)DrJuano Wrote: [ -> ]I have a problem.
I have this issue too, I have tried using different online scrapers in case some of them are down but still the issue persists.
