Hello danz0l, you probably did not have good roms, you should do a search for MAME roms 0.142.
There are also managers of roms as RomCenter or ClrMAME Pro to help you maintain your set to date.
does Advanced Launcher once again no longer pause XBMC when launching emulators? having the problem with using a 360 pad for both xbmc and emulator input and both receiving button presses problem again
I have just installed the advance launcher, is there a step by step guide on how to get it to launch chromium, on ubuntu
Cheers
Jurai Wrote:does Advanced Launcher once again no longer pause XBMC when launching emulators? having the problem with using a 360 pad for both xbmc and emulator input and both receiving button presses problem again
You can use scripts to do this under
windows or under
Linux.
This version of Advanced Launcher bring a new option for information data scraping. You have now the possibility to use the item filename as title instead of the returned scrapped title ("Ignore Scrapped Title" option). This option is useful for example when you have several time the same item but into different version (country, bootleg, etc...). Also "Clean items titles" and "Titles Formating" options still active when the "Ignore Scrapped Title" option is activated.
Example :
If your item filename is :
The Legend of Zelda - A Link to the Past (U) [!].smc
And the returned scrapped title is :
The Legend of Zelda: A Link to The Past [Player's Choice]
With Ignore Title : OFF
- Clean title : OFF, Format Title : OFF -> The Legend of Zelda: A Link to The Past [Player's Choice]
- Clean title : ON, Format Title : OFF -> The Legend of Zelda: A Link to The Past
- Clean title : OFF, Format Title : ON -> Legend of Zelda: A Link to The Past [Player's Choice], The
- Clean title : ON, Format Title : ON -> Legend of Zelda: A Link to The Past, The
With Ignore Title : ON
- Clean title : OFF, Format Title : OFF -> The Legend of Zelda - A Link to the Past (U) [!]
- Clean title : ON, Format Title : OFF -> The Legend of Zelda - A Link to the Past
- Clean title : OFF, Format Title : ON -> Legend of Zelda - A Link to the Past, The
- Clean title : ON, Format Title : ON -> Legend of Zelda - A Link to the Past (U) [!], The
This version of Advanced Launcher bring also a minor bug fix and the german translation update.
ChangeLog:- Add an option to use filename as title when scraping.
- Fix text display for search by release dates.
- Update german translation (thanks to mandark).
I want to use launcher to run some custom .sh scripts on ATV. But when i want to browse for scripts i can not browse on my local disk even if a have those already as source selected.
Ok im having another quite annoying issue on xbmclive ubuntu 10.4. When playing a game for prelonged periods (say 15 minutes etc) the screen goes black and i have to hit ESC to bring focus back. I have xbmc paused as in the scripts angelscry provides so assumed it was xbmc doing some power saving, so went into the xbmc options and turned all the power saving options off (screen blank etc) and its still doing it ? Does anyone else have a solution for this ? I can reproduce this every single time.
Angelscry Wrote:This version of Advanced Launcher bring a new option for information data scraping. You have now the possibility to use the item filename as title instead of the returned scrapped title ("Ignore Scrapped Title" option). This option is useful for example when you have several time the same item but into different version (country, bootleg, etc...). Also "Clean items titles" and "Titles Formating" options still active when the "Ignore Scrapped Title" option is activated.
Been meaning to ask, what skin is that ?
danz0l Wrote:Ok im having another quite annoying issue on xbmclive ubuntu 10.4. When playing a game for prelonged periods (say 15 minutes etc) the screen goes black and i have to hit ESC to bring focus back. I have xbmc paused as in the scripts angelscry provides so assumed it was xbmc doing some power saving, so went into the xbmc options and turned all the power saving options off (screen blank etc) and its still doing it ? Does anyone else have a solution for this ? I can reproduce this every single time.
It could also be Ubuntu power saving. If you close XBMC instead of pause it. Do you still have the problem?
danz0l Wrote:Been meaning to ask, what skin is that ?
Alaska Revisited (with aeon theme and colors).
illiac4 Wrote:I want to use launcher to run some custom .sh scripts on ATV. But when i want to browse for scripts i can not browse on my local disk even if a have those already as source selected.
First you have to know that I have not ATV system, so I have never tested Advanced Launcher on that system. I will try to help you. Normally, you must not encounter this kind of problem for file selection (it is platform independent).
Are you able to see or select other files? Maybe you script is into a hidden folder. Have you activated the "Show hidden files and directories" option into XBMC (into Settings / Files list)?
Angelscry Wrote:It could also be Ubuntu power saving. If you close XBMC instead of pause it. Do you still have the problem?
I dont know as the live distro launches as an xwindows replacement, so if i close xbmc i effectively close xwindows
Angelscry Wrote:Alaska Revisited (with aeon theme and colors).
Gonna be a royal pain now but i cant find that anywhere, can you link me to it please ? Would really appreciate it. I can find alaska revisted but not with the aeon theme and colors
Angelscry Wrote:First you have to know that I have not ATV system, so I have never tested Advanced Launcher on that system. I will try to help you. Normally, you must not encounter this kind of problem for file selection (it is platform independent).
Yes i did. But can not browse anything. Obviously it is the problem with ubuntu 8.04.
