No problem for now, just have to creat different fanart folder for each genre because it use the same exe and fanart keep remplacing each other....that s all!
Cheers
Hi
I replaced the old advanced launcher with 2.0.9 but it wont scrape any thumbs/fanarts from gamefaqs. What am i doing wrong
(2013-06-08, 00:01)Sgt.Stedenko Wrote: [ -> ]Hi
I will check, maybe the gamefaqs scraper need to be updated.
Thanks for the fast reply and for all your effort !!
I could only wish you would also work on Mediabrowser/Gamebrowser!!
You're the best!
(2013-06-08, 00:15)Sgt.Stedenko Wrote: [ -> ]Thanks for the fast reply and for all your effort !!
You're the best!
It will not happen. I'm not a Windows user.
(2013-06-08, 00:04)Angelscry Wrote: [ -> ] (2013-06-08, 00:01)Sgt.Stedenko Wrote: [ -> ]Hi
Ok... it will be more complicated
23:49:33 T:139759552489216 NOTICE: You appear to be using an application or script that is disallowed on our site due to past abuses. Please discontinue use of this program in order to continue using GameFAQs.
Version 2.0.10 : This new version of Advanced Launcher fix several minor bugs :
Changelog :- Fix GameFAQs scrapers (info, thumbs and fanarts).
- Fix post-Frodo XBMC versions compatibility.
- Fix toogle fullscreen option for files launchers.
When I set the background for my games it's only screenshots of ingame play. No nice backgrounds. Why is that?
(2013-06-08, 03:54)tential Wrote: [ -> ]When I set the background for my games it's only screenshots of ingame play. No nice backgrounds. Why is that?
It depend the scraper your are using for fanart images. Some provide screenshot, some provide background, some provide back covers, and some provide any kind of images. That depend of your taste and of the skin you are using. So, if you prefer to have backgrounds, use for example TheGameDB fanart scrapper.
How do I change my scraper? Can't believe you answered me haha wow.
I can't touch anything though right now so I can't look around because I clicked that Batch Download Artwork. XBMC is unresponsive, I'm only at 5%. This might take awhile. I saw you were using Cirrus in one post and decided to try it and I think this may be my new favorite skin. Didn't think anything could replace Aeon Nox.
Can't wait to put this on my main HTPC gaming machine. All the parts are coming this week! First time I'll ever have a SSD. Never had one before. Way too long haha.
To change scraper, you need to go into Advanced Launcher settings menu. For this, go into any Advanced Launcher context menu ("C" key) then select "Add-on settings" entry. Here you will have 3 tabs titled : Data & Infos, Thumbs and Fanarts. Each one correspond to a scraper, and for each one you can define a website source (Allgame, GameFAQs, MobyGames, TheGamesDB, etc...).
Ok I think I was using GameFAQs. 10 hours from now, when XBMC is done running that Batch Download Artwork thing then I guess I'll do that haha. I had no clue what it was when I clicked it. Oh well.
Still not even too clear what the difference is between using this vs what XBMC normally does haha. Guess I'll figure out soon.
Since the 2.0.10 update, advanced launcher has deleted all my entries... I was about 50% done with re-adding my stuff and it deleted it again.. it just reverts back to as if I just installed it (aka only empty Default folder).
(2013-06-08, 12:48)Xepo Wrote: [ -> ]Since the 2.0.10 update, advanced launcher has deleted all my entries... I was about 50% done with re-adding my stuff and it deleted it again.. it just reverts back to as if I just installed it (aka only empty Default folder).
http://forum.xbmc.org/showthread.php?tid...pid1432031
(2013-06-08, 06:19)tential Wrote: [ -> ]Ok I think I was using GameFAQs. 10 hours from now, when XBMC is done running that Batch Download Artwork thing then I guess I'll do that haha. I had no clue what it was when I clicked it. Oh well.
And so , because you didn't know what you are doing, your are decided to do it on all your game collection instead of on just few games.
