(2013-02-05, 13:27)Angelscry Wrote: [ -> ] (2013-02-05, 06:26)hunterx Wrote: [ -> ]So this Advanced Launcher won't automatically find my ROM's, but I think I read that's a bug currently?
You need to perform a scan to add new item to a Launcher.
(2013-02-05, 04:45)gurgietrueshot Wrote: [ -> ] (2013-02-04, 22:58)Angelscry Wrote: [ -> ]Version 1.11.0:
This new version of Advanced Launcher attempt to fix all the annoying bugs appearing during the last days. It first fix the way thumbs and fanart images are saved during update/refresh. I'm not sure it will definitively fix the problem of launchers.xml file corruption (empty saved file) but for now I was not able to reproduce the problem. This version also rollback to the way used by version 1.10.15 to start windows application to avoid problem under Windows systems.
Changelog:- Fix launcher thumb image update/refresh.
- Fix launcher fanart image update/refresh.
- Rollback way to start Windows application as for version 1.10.15.
Because previous version was really unstable, feedback on this version will be really appreciated.
Well I was just about to post and say it appears to be fixed but I tried to change and overwrite some art in my Mame launcher and got the error again. This time it just knocked out the first few lines.
After error: http://pastebin.com/uFtF8rYP
Before Error: http://pastebin.com/w43ss6QH
xbmc.log: http://pastebin.com/yAGTF86q
The error at the end crashed XBMC after I set the launcher delay to 100ms
Thank for the report... Bad new it is not yet fixed.... I have to understand now WHY the launchers.xml file is corrupted at its begining an not, like most of the time, at its end.... Pleae could you confirm me that after the bug, the begining of the launchers.xml file is filed with spaces and and the first visible character is a ">".... because... heuuu... that's do not have any sens. The launchers.xml file is writed line by line. I can understand that first lines could be replaced by spaces... but not that a line was partially written...
For the delay, If you do not have a fast computer and if the value is to small.... XBMC will effectively crash. Set the value to 1000ms... then decrease it to slowly until it not crash. For example on my different systems :
Windows 8 Laptop -> delay of 0 ms is ok.
Archlinux Laptop -> delay of 100 ms is ok.
Archlinux HTPC -> delay of 300 ms is ok.
The idea is to reduce to a maximum the delay between the moment of start the application and the moment you switch to this application. This delay was added since Frodo.... With Eden use delay was never needed.
(2013-02-05, 06:38)count_zero Wrote: [ -> ] (2013-02-03, 16:37)Angelscry Wrote: [ -> ]This is how I have configured my linux system to have audio for applications started from XBMC Frodo. I'm using the Archlinux distribution, so I'm not sure this manipulation will be exactly the same for other distributions (Ubuntu, XBMCBuntu, Openelec, etc...). The main cause of the problem is that applications using pulseaudio (XBMC) and applications using ALSA (firefox, mednafen, etc...) cannot always play audio at the same time.
First you need to have ASLA and Pulseaudio packages installed on your system. This is the package I have installed on my systems :
alsa-firmware
alsa-lib
alsa-oss
alsa-utils
pulseaudio
pavucontrol
You have to check that the pulseaudio-alsa package is not installed on your system. If it is installed, just remove it.
Then you will have to edit the /etc/pulse/default.pa file.
First, found the lines refering to module-alsa-sink and module-alsa-source loading and edit them to indicated to use dmix and dsnoop parameters, like this :
load-module module-alsa-sink device=dmix
load-module module-alsa-source device=dsnoop
Then, found the lines refering to module-udev-detect and module-detect and comment them, like this :
# load-module module-udev-detect
# load-module module-detect
Save the /etc/pulse/default.pa file and reboot your system.
I can confirm this works. I'm not a huge fan of pulseaudio, but this is a workaround.
You need to set your audio playback preferences in XBMC to pulseaudio.
Are you also be able to make it works using HDMI? I was able to make it work on my linux laptop system (using analogic output) but not on my linux HTPC system (using HDMI output).
Yes, I only use HDMI for audio output. I have not tested analog or optical audio out.
(2013-02-05, 22:32)count_zero Wrote: [ -> ]Yes, I only use HDMI for audio output. I have not tested analog or optical audio out.
Ok... thanks. So I have to dig more on my HTPC system to discover why XBMC do not have sound when pulseaudio is active.
(2013-02-05, 22:17)bakito Wrote: [ -> ]hey angel!
long time I have no problem with advance but...well since sometimes now xbmc, when quitting pcsx2 ( with autoit script) , is not on focus...the most strange is that it is not every time...some all works fine some times xbmc don't get focus after quitting ps2 game...I remember having this kinfd of problem and I add a "wait" line in the autoit script to fix it, sadly I don't remember how I achieve this ( and I have far less time now to search and experiment
I remember that you post my script somewhere at that time ( the one who shut down xbmc then start it ) but I could not find it...could you help me?
I'm pretty sure that this focus thing happen because xbmc start to shortly after pcsx2 is closed...well I hope it's this anyway!
thanks!!
cheers
You will have to modify the autoit script you are using. Do you have the code?
That s ok ! I found my old post! It was winwait then winactive with xbmc as window name! Now it work! Well so far!
Cheers
I have no idea what is going on with my Advanced Launcher. I am running the latest version, and just as I was manually updating images to a game I started getting python errors...then I went back to the Advanced Launcher main screen and all of my launchers were gone.
http://pastebin.com/Aq7F7z3L
Version 1.11.2:
This new version of Advanced Launcher attempt again to fix the problem of launchers.xml file corruption (empty saved file) during thumbs and image scraping. It add new error images when the scraping is not possible (timeout/no images found) and add a launchers.xml file statut check before read/write it. But here again, I'm not sure the problem is really fixed.
Changelog:- Add error message display for image scraping
- Add file statut check during launcher.xml file saving/editing
(2013-02-06, 05:51)hunterx Wrote: [ -> ]I have no idea what is going on with my Advanced Launcher. I am running the latest version, and just as I was manually updating images to a game I started getting python errors...then I went back to the Advanced Launcher main screen and all of my launchers were gone.
Thanks for the feedback. This is actually a bug into Advanced Launcher that I try to fix...
(2012-08-21, 10:17)bakito Wrote: [ -> ]hello angel
I came again with my problem of launchers that disappears...
but I know why now...I try the "launcher tool" add on to get rid of explorer at start up and ....boom!
I check and it's my launcher from external drive that disappears...
I guess that when windows launch without explorer it doesn't check for this particular drive and then they vanished from the launcher.xml ( litteraly vanished because it goes from 1,5 mega to 0,700 mega )
so ....well not really a problem but launcher.xml remplace itself wich is surprising..well for me as I understand nothing to code
is there a way to make it "no rewritable" ?
anyway it's not very important
you're addon rules!!
and sometime I wonder why it's not a "normal" fonction for xbmc because it is REALLY convinient
thx for your great work
cheers
hello angel, some times ago I posted about launcher that disapeared, I don't know if that help but I quote that post ( and I think there are some others maybe some with log, I don't remember ) about this problem since many user have come up with the same problem recently...just to say it's not a new problem so maybe their something hiding in the code for a long time and not especialy in the last version of your ( great ) add on, if I'm correct I got this problem with eden but not with darma, since then I had this bug again ( not that not all my launcher disapear but just some of them ) but now I make regulary back up of my launcher.xml to avoid this problem, maybe a temporaly fix would be to make an automatic copy of the old launcher before anything is change to the current one ,like launcher.old, with an option to put it back if their was a problem...maybe it's silly, I don't know...anyway I hope it help ( even a little)
cheers
(2013-02-06, 14:35)bakito Wrote: [ -> ] (2012-08-21, 10:17)bakito Wrote: [ -> ]hello angel
cheers
cheers
No, no... that's not a silly idea. Actually I'm trying to see what is going wrong, trying to fix any possible errors. My problem actually is that the bug do not occurs at any time, and it is complicated to reproduce it. I can spend more than 1 hour, editing/deleting/creating/scraping launcher and items without any problem... and suddenly... the content of the launchers. xml file it empty. But even with the XBMC debug mode activated, I cannot see any reported error. The error that everybody report me actually is due to the fact that the launchers.xml file is empty... The error message is not the cause, but the consequence.
So, the idea to make backup of the launchers.xml file once it is modified have reach my mind. I think that's what I'm going to work on now. It will avoid user to completely lost their data, and give me time to definitively fix this bug.
I'm really sorry for all the problem bring by this bug. If any of you have an idea what could happen... an help will be really welcome.
I don't really think that it is related but the difficulty to reproduce this issue reminded me of an issue that I have in RCB. Maybe the problem only occurs if saving the file is done at the same time as some other process in XBMC is working. Maybe some service addons, widgets, pvr tasks, anything like this. That would explain why it only happens every x times. Just an idea.
If you are interested, the RCB issue is described
here. Although I don't think it is the same actuator.
can this be related to skin.widget that check our library some times?
(2013-02-06, 15:42)malte Wrote: [ -> ]I don't really think that it is related but the difficulty to reproduce this issue reminded me of an issue that I have in RCB. Maybe the problem only occurs if saving the file is done at the same time as some other process in XBMC is working. Maybe some service addons, widgets, pvr tasks, anything like this. That would explain why it only happens every x times. Just an idea.
If you are interested, the RCB issue is described here. Although I don't think it is the same actuator.
It could be linked... I will investigate also in that way. Thank you malte.
The Advanced Launcher autobackup feature is actually functional. I just Have to add some options to control it.
Version 1.12.0: Since I do not clearly understand why the launchers.xml file was randomly deleted, this new version of Advanced Launcher add autobackup support. This option is activated by default but could always be desactivated from the Advanced Launcher settings menu.
The autobackup feature automatically make a backup of the launchers.xml file each time you add/delete/edit a launcher or an item. You have the possibility to define the number of backup file to be saved, from 5 to 100 (default 10). Finally you have an option to load directly from Advanced Launcher any backuped launchers.xml.
Changelog:- Add launchers.xml file autobackup.
- Add an option to activate/desactivate autobackup.
- Add an option to define the number of keeped backup files (5-100).
- Add an option to load/restore a backup file.
Hey angel, thanks for looking into that disappearing launchers bug, hit me a few times sadly.
Quick question.
Anyway to make a link to load from CD for emulators?
eg It's all well and good having ePSXe 1.8.0 loading a cue (or Bin if it fails on cue) but some games work better when on disc (or mounted) and It'd be great to have 'Load CD' shortcut in the rom list. A good example being Tomb Raider 1+2, couldn't get it to play from hard drive, works fine from my actual disc.
ePSXe loads from disc by default with just the -nogui argument, but I'm sure other system emulators have other options if load from cd drive is supported. So anyway to override the launcher default arguments options?
Failing that I guess some form of script to mount a .cue first then load that virtual drive into the emulator
(2013-02-07, 14:59)aNILEator Wrote: [ -> ]Hey angel, thanks for looking into that disappearing launchers bug, hit me a few times sadly.
I know.... I'm into the same boat than you. I try my possible to fix the problem. But the more I try, the more I starting to think that the problem come from XBMC itself and not from the Advanced Launcher code.
(2013-02-07, 14:59)aNILEator Wrote: [ -> ]Quick question.
You just have to create a a .bat or autoit script that will automatically mount the CD image file before starting the emulator and that will unmout it once the emulator is closed. Here is a script example :
http://www.gwenael.org/forum/viewtopic.php?id=7
Purely a cosmetic concern here...
My wife likes Windows Media Center, so (within Aeon Nox) I created a custom button that launches to the WMC guide, no splash. When I click the button, XBMC switches to windowed mode, then back to full screen, the WMC launches. Is there some setting that I need to change to skip the first couple steps and just launch WMC over XBMC? Just looking for a smoother transition.
p.s. I tried using "full screen window" instead of true full screen. It did the same thing.
Hey guys. Hope you can help me. I wanted to get completely off of 7MC and use XBMC. Now that Frodo is released I have integrated LiveTV.
Next thing was me integrating the HuluDesktop, as I don't really like the functionality of the xbmc hulu app.
One thing I did when I was on Eden, was I created a shortcut that pointed to a autohotkey launcher that would hide and freeze xbmc then launch my app. Once I exited the app, then it would unhide and unfreeze xbmc.
I had integrated the Kylo browser with this method and, now with Frodo out, was just about to do it with HuluDesktop. However now I noticed that the the kylo and hulu won't launch anymore.
The shortcuts still work, if I click them with my mouse, but ADVLauncher throws an error if I choose them there.
Here's my
xbmc.log
Here's my
Launcher.xml
Here's my
post on how to integrate the autohotkey with a shortcut.
Thanks for any help
