2012-12-31, 21:15
(2012-12-31, 17:18)DocMAX Wrote: [ -> ]How can i make ContextMenu work with Joystick Button 3? Doesn't work in Adv. Launcher but everywhere else...That's not Advanced launcher which decide if you can access the program ContextMenu with Joystick Button 3 or not but XBMC itself. Advanced Launcher code do not touch/assign/change anything concernant XBMC keymapping. You tell me that it is working everywhere else.... Does it works also with other program add-ons (not video or music add-ons, really program add-ons)?
(2012-12-31, 18:24)Elixxen Wrote: [ -> ]With that being set up I started looking into regular games like for instance Angry Birds, GTA Vice City and stuff like that. I managed to get the games to launch but the problem is that XBMC still sits on top after they launch. In other words, the launcher fails to bring the game to the front and therefore I have to use my mouse to bring the game to the front. Enabling the full screen option does nothing. Same thing happens except that XBMC goes into window mode when I launch something.I'm not really familiar with OSX system, but Advanced Launcher and XBMC have several option to influence the way application are started and focused from XBMC.
I should mention that I'm running OSX, not Windows. Any ideas of what I'm missing?
First, you can try to go into the context menu of your launcher ("C" key) > Edit Launcher > Advanced Modification > and change the state of the "Toogle XBMC in Windowed mode" option. Then look if it has an effect on your windows focus or not (normally it as).
