2014-08-03, 02:11
(2014-08-03, 01:50)teeedubb Wrote: [ -> ]Tried making a script file to run the Exec= command and pointing AL to that?
Yes; however, if I put the path name in quotations, its loads and crashes, if I do it like the *.desktop launcher does it gives me the following message:
heinrich@heinrich-desktop:/$ env WINEPREFIX="/home/heinrich/.wine" wine C:\\\\Program\\ Files\\ \\(x86\\)\\\\EA\\ GAMES\\\\Need\\ for\\ Speed\\ Underground\\ 2\\\\SPEED2.EXE
bash: syntax error near unexpected token `('
It only seems to work if I open it from a folder or the *.desktop launcher
This is what happens when I just use wine and pathname:
wine '/home/heinrich/.wine/dosdevices/c:/Program Files (x86)/EA GAMES/Need for Speed Underground 2/speed2.exe'
fixme:win:EnumDisplayDevicesW ((null),0,0x32f8a8,0x00000000), stub!
fixme:d3d_surfaceurface_init multisample_quality set to 31, substituting 0.
fixme:dinput:IDirectInput8AImpl_EnumDevicesBySemantics (this=0x282c0f8,(null),0x86fa00,0x5ca5b0,0x86fa00,0000): semi-stub
fixme:dinput:SysKeyboardWImpl_BuildActionMap (0x2834294)->(0x32f7a0,(null),00000002): semi-stub !
fixme:dinput:IDirectInputDevice8WImpl_BuildActionMap (0x2834294)->(0x32f7a0,(null),00000002): semi-stub !
fixme:dinput:IDirectInputDevice8WImpl_BuildActionMap dwFlags =|DIDBAM_INITIALIZE
fixme:dinput:SysKeyboardWImpl_BuildActionMap (0x2834294)->(0x32f7a0,(null),00000000): semi-stub !
fixme:dinput:SysKeyboardWImpl_SetActionMap (0x2834294)->(0x32f7a0,(null),00000000): semi-stub !
fixme:dinput:IDirectInputDevice8WImpl_SetActionMap (0x2834294)->(0x32f7a0,(null),00000000): semi-stub !
fixme:winediag:AUDDRV_GetAudioEndpoint Winepulse is not officially supported by the wine project
fixme:winediag:AUDDRV_GetAudioEndpoint For sound related feedback and support, please visit http://ubuntuforums.org/showthread.php?t=1960599
fixme:dsoundSOUND_WaveFormat Limiting channels to 2 due to lack of multichannel support
fixme:dsoundSOUND_RecalcFormat Conversion from 4 to 2 channels is not implemented, falling back to stereo
fixme:dsoundSOUND_RecalcFormat Conversion from 6 to 2 channels is not implemented, falling back to stereo
wine: Unhandled page fault on read access to 0x00b50004 at address 0x5797c7 (thread 0009), starting debugger...
Unhandled exception: page fault on read access to 0x00b50004 in 32-bit code (0x005797c7).
Register dump:
CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b
EIP:005797c7 ESP:0032fd34 EBP:00000001 EFLAGS:00010287( R- -- I S - -P-C)
EAX:00a46c80 EBX:00000000 ECX:00b50010 EDX:0000d42c
ESI:44443333 EDI:00000003
Stack dump:
0x0032fd34: 00a71cb0 0057a44a 00a46c80 0057b33e
0x0032fd44: 00a46c80 00000001 0057e862 00000001
0x0032fd54: 00000001 00a417f0 0032fe60 7b8b9000
0x0032fd64: 0057ef8a 0057fb2e 00a46c80 0057ecfe
0x0032fd74: 00000000 00000ece 00580d89 00000001
0x0032fd84: 00a417f0 0075bd6a 00000001 00a417f0
000c: sel=0067 base=00000000 limit=00000000 32-bit r-x
Backtrace:
=>0 0x005797c7 in speed2 (+0x1797c7) (0x00000001)
0x005797c7: movl 0xfffffff4(%ecx),%esi
Modules:
Module Address Debug info Name (111 modules)
PE 400000- 92fc08 Export speed2
ELF 795b8000-7b7fc000 Deferred libnvidia-glcore.so.331.89
ELF 7b800000-7ba5f000 Deferred kernel32<elf>
\-PE 7b810000-7ba5f000 \ kernel32
ELF 7bc00000-7bce4000 Deferred ntdll<elf>
\-PE 7bc10000-7bce4000 \ ntdll
ELF 7bcf8000-7bd10000 Deferred libresolv.so.2
ELF 7bd10000-7be88000 Deferred libvorbisenc.so.2
ELF 7be88000-7befa000 Deferred libsndfile.so.1
ELF 7bf00000-7bf04000 Deferred <wine-loader>
ELF 7bf10000-7bf3c000 Deferred libvorbis.so.0
ELF 7bf40000-7bf74000 Deferred libflac.so.8
ELF 7bf78000-7bfc3000 Deferred libdbus-1.so.3
ELF 7bfc8000-7c0fd000 Deferred oleaut32<elf>
\-PE 7bfe0000-7c0fd000 \ oleaut32
ELF 7c408000-7c411000 Deferred libogg.so.0
ELF 7c418000-7c421000 Deferred librt.so.1
ELF 7c428000-7c432000 Deferred libwrap.so.0
ELF 7c438000-7c4a7000 Deferred libpulsecommon-4.0.so
ELF 7c508000-7c525000 Deferred libgcc_s.so.1
ELF 7c528000-7c631000 Deferred comctl32<elf>
\-PE 7c530000-7c631000 \ comctl32
ELF 7cb88000-7cbb0000 Deferred winepulse<elf>
\-PE 7cb90000-7cbb0000 \ winepulse
ELF 7cbb0000-7cbd3000 Deferred mmdevapi<elf>
\-PE 7cbc0000-7cbd3000 \ mmdevapi
ELF 7cbd8000-7cc0f000 Deferred uxtheme<elf>
\-PE 7cbe0000-7cc0f000 \ uxtheme
ELF 7d5a8000-7d5af000 Deferred libasyncns.so.0
ELF 7d5b0000-7d5bb000 Deferred libjson-c.so.2
ELF 7d5c0000-7d60b000 Deferred dinput<elf>
\-PE 7d5d0000-7d60b000 \ dinput
ELF 7d840000-7d844000 Deferred libnvidia-tls.so.331.89
ELF 7d848000-7d94d000 Deferred libgl.so.1
ELF 7d980000-7d986000 Deferred libxfixes.so.3
ELF 7d988000-7d993000 Deferred libxcursor.so.1
ELF 7d998000-7d9a9000 Deferred libxi.so.6
ELF 7d9b0000-7d9b4000 Deferred libxcomposite.so.1
ELF 7d9b8000-7d9c3000 Deferred libxrandr.so.2
ELF 7d9c8000-7d9d3000 Deferred libxrender.so.1
ELF 7d9d8000-7d9de000 Deferred libxxf86vm.so.1
ELF 7d9e0000-7d9e4000 Deferred libxinerama.so.1
ELF 7d9e8000-7d9ef000 Deferred libxdmcp.so.6
ELF 7d9f0000-7d9f4000 Deferred libxau.so.6
ELF 7d9f8000-7da1a000 Deferred libxcb.so.1
ELF 7da20000-7db54000 Deferred libx11.so.6
ELF 7db58000-7db6b000 Deferred libxext.so.6
ELF 7db70000-7db95000 Deferred imm32<elf>
\-PE 7db80000-7db95000 \ imm32
ELF 7dba0000-7dc33000 Deferred winex11<elf>
\-PE 7dbb0000-7dc33000 \ winex11
ELF 7dc38000-7dc5e000 Deferred iphlpapi<elf>
\-PE 7dc40000-7dc5e000 \ iphlpapi
ELF 7dc60000-7dc8f000 Deferred netapi32<elf>
\-PE 7dc70000-7dc8f000 \ netapi32
ELF 7dc90000-7dcb3000 Deferred tapi32<elf>
\-PE 7dca0000-7dcb3000 \ tapi32
ELF 7dcb8000-7dce3000 Deferred msacm32<elf>
\-PE 7dcc0000-7dce3000 \ msacm32
ELF 7dce8000-7dda1000 Deferred winmm<elf>
\-PE 7dcf0000-7dda1000 \ winmm
ELF 7dda8000-7de1d000 Deferred ddraw<elf>
\-PE 7ddb0000-7de1d000 \ ddraw
ELF 7de20000-7de68000 Deferred dsound<elf>
\-PE 7de30000-7de68000 \ dsound
ELF 7de68000-7dea0000 Deferred ws2_32<elf>
\-PE 7de70000-7dea0000 \ ws2_32
ELF 7dfa0000-7dfc9000 Deferred libexpat.so.1
ELF 7dfd0000-7e00b000 Deferred libfontconfig.so.1
ELF 7e010000-7e038000 Deferred libpng12.so.0
ELF 7e038000-7e052000 Deferred libz.so.1
ELF 7e058000-7e0f8000 Deferred libfreetype.so.6
ELF 7e0f8000-7e11a000 Deferred libtinfo.so.5
ELF 7e120000-7e145000 Deferred libncurses.so.5
ELF 7e178000-7e1f2000 Deferred shlwapi<elf>
\-PE 7e190000-7e1f2000 \ shlwapi
ELF 7e1f8000-7e42d000 Deferred shell32<elf>
\-PE 7e210000-7e42d000 \ shell32
ELF 7e430000-7e444000 Deferred shfolder<elf>
\-PE 7e440000-7e444000 \ shfolder
ELF 7e448000-7e4cc000 Deferred rpcrt4<elf>
\-PE 7e450000-7e4cc000 \ rpcrt4
ELF 7e4d0000-7e612000 Deferred ole32<elf>
\-PE 7e4f0000-7e612000 \ ole32
ELF 7e618000-7e634000 Deferred dinput8<elf>
\-PE 7e620000-7e634000 \ dinput8
ELF 7e638000-7e793000 Deferred user32<elf>
\-PE 7e650000-7e793000 \ user32
ELF 7e798000-7e80b000 Deferred advapi32<elf>
\-PE 7e7a0000-7e80b000 \ advapi32
ELF 7e810000-7e92f000 Deferred gdi32<elf>
\-PE 7e820000-7e92f000 \ gdi32
ELF 7e930000-7ea3f000 Deferred opengl32<elf>
\-PE 7e950000-7ea3f000 \ opengl32
ELF 7ea40000-7eb80000 Deferred wined3d<elf>
\-PE 7ea50000-7eb80000 \ wined3d
ELF 7eb80000-7ebbe000 Deferred d3d9<elf>
\-PE 7eb90000-7ebbe000 \ d3d9
ELF 7ef38000-7ef45000 Deferred libnss_files.so.2
ELF 7ef48000-7ef54000 Deferred libnss_nis.so.2
ELF 7ef68000-7ef82000 Deferred version<elf>
\-PE 7ef70000-7ef82000 \ version
ELF 7ef88000-7efce000 Deferred libm.so.6
ELF 7efd0000-7efe9000 Deferred libnsl.so.1
ELF 7eff0000-7eff9000 Deferred libnss_compat.so.2
ELF f7360000-f7365000 Deferred libdl.so.2
ELF f7368000-f7517000 Deferred libc.so.6
ELF f7518000-f7534000 Deferred libpthread.so.0
ELF f7568000-f771e000 Dwarf libwine.so.1
ELF f7720000-f7742000 Deferred ld-linux.so.2
ELF f7742000-f7743000 Deferred [vdso].so
Threads:
process tid prio (all id are in hex)
00000008 (D) C:\Program Files (x86)\EA GAMES\Need for Speed Underground 2\speed2.exe
0000002c 15
0000002b 15
00000029 0
00000028 0
00000027 15
00000026 0
00000025 1
00000024 15
00000023 2
00000009 0 <==
0000000e services.exe
0000001d 0
0000001c 0
00000016 0
00000014 0
00000010 0
0000000f 0
00000012 winedevice.exe
0000001b 0
00000018 0
00000017 0
00000013 0
00000019 plugplay.exe
0000001f 0
0000001e 0
0000001a 0
00000020 explorer.exe
00000022 0
00000021 0
