mandark Wrote:hi Angelscry!
i am launching my lnk-files with my own shourtcut-launcher, which does a few other things too (e.g. loading a xpadder-(gamepad)-profile, if present).
of course this isn't working anymore since Version 0.9.6.
would it be possible for you to somehow re-add the old behaviour, where the lnk file is launched with the stated application? maybe your could add an option in the addon-settings like "Launch lnk-Files (=windows shortcuts) directly", or even make a third type of launcher item, with has the new behaviour:- Standalone (normal PC executable)
- File launcher (e.g. game emulator)
- Shortcut Launcher
... leaving the "File launcher" with the old behaviour.
I have added an option on the last version to deactivate the internal support of .lnk files. When this option is deactivated you can use the launcher like the other ones this .lnk files.
srsobieraj Wrote:You may be interested in this thread: http://forum.xbmc.org/showthread.php?tid=55776
SophT wrote a script to put Hyperspin on his Main View. It closes XBMC completely so there is no conflict between XBMC and Hyperspin (or in your case, Boxee) for Direct3D. When Hyperspin/Boxee is exited, the watcher launches XBMC again.
It's programmed around the Aeon Skin, but it shouldn't be that hard to add it to any other skin.
Hope that helps!
Thanks for the above however that is for windows and its outdated. I am using customizable confluence so I can make a custom label on the homescreen. I jsut need the launcher to be able to launch boxee, kill xbmc or minimize it (hope that no conflicts arise if minimize), and then relaunch xbmc when boxee is killed. Shouldnt this be possible with this launcher since you can launch other programs?
hey everyone im having few problems importing (.lnk) files. my shortcuts look like this "lcgol.exe - Shortcut" but in properties i can see the (.lnk) ext. ala dont seem to pick it up. what am i doing wrong? thank you
ali2k1 Wrote:hey everyone im having few problems importing (.lnk) files. my shortcuts look like this "lcgol.exe - Shortcut" but in properties i can see the (.lnk) ext. ala dont seem to pick it up. what am i doing wrong? thank you
It is related to the "." in the name of the file. Please name your "lcgol.exe - Shortcut" file correctly with the name ot the corresponding game of application. It will also help the scrapers to identify your game.
joelones Wrote:EDIT: I tried mounting the server on a mount ie: /home/xbmc/server/share/Thumbnails and then made a sym link to this directory in the userdata directory still no dice. Same error.
No you will have problem by doing this. Thumbnails in user data and your shared Thumbnails are totally different files. BTW... I have configured my system like yours (linux, roms and images on a distant smb server) and all is working perfectly. So according to all your observation the error seems related to the
shutil.copy2 python command... But only on your system.
Are you using a FAT32 partition ?
rflores2323 Wrote:running on full desktop ubuntu 10.04 (in my sig is my equipment).
Ok... I will have to compile boxee on my system. It could take time...
srsobieraj Wrote:SophT wrote a script to put Hyperspin on his Main View. It closes XBMC completely so there is no conflict between XBMC and Hyperspin (or in your case, Boxee) for Direct3D. When Hyperspin/Boxee is exited, the watcher launches XBMC again.
I think it will be actually the best alternative. I have also encounter on my side Direct3D incompatibilities when XBMC and Dolphin emulator where running at the same time.
Tried it bruv I tried Lara croft guardian of light and to show hidden ext but still not showing up. Tried manually but directory empty.il post the log for you to check I may have done something wrong
ali2k1 Wrote:Tried it bruv I tried Lara croft guardian of light and to show hidden ext but still not showing up. Tried manually but directory empty.il post the log for you to check I may have done something wrong
I have checked again with the last version... all is working great. Have you check the corresponding wiki page :
http://www.gwenael.org/xbmc/index.php?ti..._shortcuts ??
Angelscry Wrote:Version 0.9.9 :
Changelog- add option to desactivate internal shortcuts (.lnk) support (default ON)
yay! it works! many thanks for the fast update and also for your continuing great work on the advanced launcher!
Angelscry Wrote:Ok... I will have to compile boxee on my system. It could take time...
Thanks. I would really appreciate you helping out. Great job on this addon.
Angelscry Wrote:I have added an option on the last version to deactivate the internal support of .lnk files. When this option is deactivated you can use the launcher like the other ones this .lnk files.
to show my thanks, i have created a german language-file of the current version (v.0.9.9).
you can download it
here.
Angelscry Wrote:No you will have problem by doing this. Thumbnails in user data and your shared Thumbnails are totally different files. BTW... I have configured my system like yours (linux, roms and images on a distant smb server) and all is working perfectly. So according to all your observation the error seems related to the shutil.copy2 python command... But only on your system. Are you using a FAT32 partition ?
linux client (xbmc) to linux server (unraid) via smb. I followed this to get the shared Thumbnail directory going...
http://forum.xbmc.org/showthread.php?p=6...post688069
mandark Wrote:to show my thanks, i have created a german language-file of the current version (v.0.9.9).
you can download it here.
Thank you very much. Your translation will be included in the next version.
joelones Wrote:linux client (xbmc) to linux server (unraid) via smb. I followed this to get the shared Thumbnail directory going...http://forum.xbmc.org/showthread.php?p=6...post688069
I'm not sure it is related to the manner you mount your partition, but if so, here is how I mount my smb server on my system :
mount.cifs //192.168.2.10/Volume_1/public /media/HDNetwork/ -o nolock,user=angelscry,password=mypassword,domain=MYHOME,gid=1000,uid=1000,noauto,nounix,iocharset=utf8,file_mode=0777,dir_mode=07777
I will continue to investigate on the shutil.copy2 python command with SMB share.
EDIT : One thing you can try is to edit the
launcher_plugin.py file and replace any
shutil.copy2() functions by
shutil.copy().
Alright, bug report time!
The new "Import plot from file" feature is broke. Instead of putting a file path, it put the whole plot! See screenshot:
http://i.imgur.com/dIuZO.jpg
It also threw an addon.py error, which is here:
http://pastebin.com/f23uU8mJ
The "semi-automatic" scraping is good, but needs 2 things to be perfect:
- A "None" option (that skips scraping that file and moves to the next one. I can manually scrape the file later). Sometimes the scraper is just out to lunch so much that the game doesn't show up in the top 20 list.
- The filename of the ROM being scraped. (I can't tell if the scraper is doing it's job correctly if I don't know the name of the file being scraped). I was scraping "Snatcher" for SegaCD and the scraper told me that it was scraping for "Snack Attack".
