cguZZMan I was about editing my comment right now! You're right, it seems to be a network issue. I restarted my router and now it's streaming without buffering.
Thanks for your help
(2018-07-09, 07:08)joaohkfaria Wrote: [ -> ]Hi! Subtitle (srt) file is only working when I start the video inside the Google Drive add-on, when the Movie is added to my library it doesn't work anymore.
Any way to make this work?
You need to start playing a video.
Then go to video settings or subtitle settings on leia.
Select the subtitle, it's the external subtitle that you see there.
Then press "set as default for all media". Press yes on the confirmation dialog.
Now every time you open a video, kodi will remember to select the external subtitle.
I noticed that kodi, does not bring the arts when you play strm, is there anything you can do?
Another question, possibility of generating strm automatically? After the addition of a new film ....
Even if it forces us to run the addon. But generating only new strm.
iorifly I'm working on fixing the source mode functionality so you can add your media to your library using the source url. In that way you can use the automatic library scanning native in Kodi.
Also I'm thinking in removing the "export to strm" option after the source mode is working as expected. So no need to develop the automatic generation of strms so far.
I do not know if it would be useful to me. Because I use emby to do scraper in my media. Because with it I have a server upgraded to all my kodi's.
Please do not remove this function.
The emby searches and manages the media database. And in kodi I use the addon-emby to pull the bundle of data.
Interesting. I'm not sure how your stack works, but I'll take that in count. I'll keep the option.
And may be I'll take a look on Emby.
(2018-07-09, 21:56)cguZZMan Wrote: [ -> ]Interesting. I'm not sure how your stack works, but I'll take that in count. I'll keep the option.
It would be great if you would "take a look on Emby" since having a server backend is one of the reasons im still using plex rather than Kodi
KingKaka I see the issue. It will be fixed in the next release.
tremocoivo Looks like google is blocking you for exceeding the number of requests. I will suggest you don't share your account.
A new release is in the repository. Version
1.1.0.
If anybody had an issue, please check if is resolved now.
The source mode should be working fine now. If you use the source mode to add your videos to the library, the scanning for new content should work as expected now and no more stucks. Artwork should work too. If somebody has an issue, post the debug log with your message.
The default source mode port has been changed to :8587. So the URL you should use is http://localhost:8587/source
The old port 8585 is still working only for compatibility, but what that port will do is to forward your request to the correct port 8587. That will create unnecessary requests to the server and will kind of slow your scanning process.
I strongly recommend updating your library to the direct port. You can change this port in the settings. A Kodi reboot is required after the change.
So this is the port mapping for my addons as of now:
Port 8585 <- Deprecated (Used as a forwarder to the correct port. Will be removed in the future).
Port 8586 <- Default port for the OneDrive addon.
Port
8587 <- Default port for
this Google Drive addon.
Again, if you have an issue post always your message with your debug log file.
https://kodi.wiki/view/Log_file/Easy
You can get this version if you have my repository installed:
https://github.com/cguZZman/repository.plugins
Or you can wait for the update in the Kodi Repository (already submitted).
BTW, you need to restart your Kodi once you get the update. This is due to the change of ports.
Team Drives support in development now...
New bits in the repository. Get it while is hot!
Version
1.2.0:
Team Drive support added.
Just re-add your account with Team Drive (if you did it before the support). No need to delete it first.
You can get this new version if you have my repository installed:
(2018-07-13, 01:26)cguZZMan Wrote: [ -> ]New bits in the repository. Get it while is hot!
Version 1.2.0:
- Team Drive support added.
You can get this new version if you have my repository installed: https://github.com/cguZZman/repository.plugins
Thank you.
Everything is working super fast. The only problem is the localhost/source. Still can't open it with a folder of 100+
https://paste.kodi.tv/tivalaqujo
Thank you again.
KingKaka please activate the debug logging and reproduce the issue again.
