(2021-07-01, 13:08)frankihang Wrote: [ -> ]Hi everyone,
i'm using Kodi under Android TV Version 10 and installed the Addon Google Drive.
So i see my Video Files in Google Drive but no Pctures like jpeg or something else.
cguZZMan wrote as Solution in 2018 "...enter the addon thru the Pictures option"
But in can't find any Pictures Option.There is also no Addon under Android TV like Google Photos.
Has any one an idea?
Thx for your Help
Kind reguards
Andreas
I have the same problem. I see all my folders but I can only see video files, I cannot see audio or images.
I have been using your addon since 2 year and really loved this but now when my updated to android 11 , this addon doesnt work whenever i play something within a minute app freezes and i need to close the app . firstly i thought app isn't working on android 11 but then i checked other addons working perfectly fine then i knew issue is with google drive addon. please is there any update for android 11. this is my most used app in my phn .
khushalnath please do not post in all-caps. It is seemed as shouting and demanding, and is very disrespectful to other forum users.
(2021-07-25, 11:31)DarrenHill Wrote: [ -> ]@khushalnath please do not post in all-caps. It is seemed as shouting and demanding, and is very disrespectful to other forum users.
I am sorry I didn't know that before , I'll delete that post but I can't find that option . Sorry for that but my intentions aren't bad .
khushalnath
I quickly converted it for you. No need to delete the post now.
(2021-07-25, 07:10)khushalnath Wrote: [ -> ]I have been using your addon since 2 year and really loved this but now when my updated to android 11 , this addon doesnt work whenever i play something within a minute app freezes and i need to close the app . firstly i thought app isn't working on android 11 but then i checked other addons working perfectly fine then i knew issue is with google drive addon. please is there any update for android 11. this is my most used app in my phn .
My guess, your Android device has been updated to Kodi 19.
If you are using Kodi 19 and Google drive then you need to
disable http2, because it's enabled by default.
Google Drive doesn't work ok with http2.
That's not something related with Kodi only, Google Drive in general doesn't like http2.
For example if you mount your Google Drive in Windows, linux, Mac with rclone, rclone warns you
NOT to enable http2 for Google Drive.
http2 ih Google Drive causes exactly what you are experiencing, the stream to stop in about a minute and any attempt to seek the stream makes Kodi to freeze.
Create an advancedsettings.xml
and add on it
<advancedsettings>
<network>
<disablehttp2>true</disablehttp2>
</network>
</advancedsettings>
For more information
https://kodi.wiki/view/Advancedsettings.xml
2.9.4 network
<disablehttp2>false</disablehttp2> <!-- Added in v19- Allows disabling HTTP2 for broken Curl / HTTP2 servers -->
(2021-07-11, 00:00)AshipaEk0 Wrote: [ -> ]Wonder if there's a way to use this addon to generate .strms that contain the file URLs instead of the plugin://........ that it currently does
That's not possible, because the links are dynamic and they expire.
If you want something like that (your files to be opened in any application in your system) your only option is to mount your Google Drive as a local disk.
rclone is the best software for this purpose.
(2021-07-25, 22:50)olympus Wrote: [ -> ] (2021-07-25, 07:10)khushalnath Wrote: [ -> ]I have been using your addon since 2 year and really loved this but now when my updated to android 11 , this addon doesnt work whenever i play something within a minute app freezes and i need to close the app . firstly i thought app isn't working on android 11 but then i checked other addons working perfectly fine then i knew issue is with google drive addon. please is there any update for android 11. this is my most used app in my phn .
If you are using Kodi 19 and Google drive then you need to disable http2, because it's enabled by default.
For example if you mount your Google Drive in Windows, linux, Mac with rclone, rclone warns you NOT to enable http2 for Google Drive.
and add on it
<advancedsettings>
<network>
</network>
</advancedsettings>
2.9.4 network
But I tried 18 version also but faced the same issue. I don't how to do this process , you are telling me , the link you provided telling about windows not android. Is is available on YouTube ?
(2021-07-26, 08:01)khushalnath Wrote: [ -> ]But I tried 18 version also but faced the same issue. I don't how to do this process , you are telling me , the link you provided telling about windows not android. Is is available on YouTube ?
The process is the same for any OS.
What differs is the location of the userdata folder where advancedsettings.xml should be placed.
Create the file in Windows, copy it in a usb disk mount it in your android installation and copy paste the file.
Kodi's userdata folder in Android in most cases is loacated at
Android/data/org.xbmc.kodi/files/.kodi/userdata/
https://kodi.wiki/view/Userdata#Location
Google Drive is working perfectly for me, but unfortunately Google Photos is not. I get error 400 "invalid value", I clicked report when the error popped up. I just logged in, are there further steps to setup google photos?
(2021-07-26, 08:01)khushalnath Wrote: [ -> ] (2021-07-25, 22:50)olympus Wrote: [ -> ] (2021-07-25, 07:10)khushalnath Wrote: [ -> ]I have been using your addon since 2 year and really loved this but now when my updated to android 11 , this addon doesnt work whenever i play something within a minute app freezes and i need to close the app . firstly i thought app isn't working on android 11 but then i checked other addons working perfectly fine then i knew issue is with google drive addon. please is there any update for android 11. this is my most used app in my phn .
and add on it
<advancedsettings>
<network>
</network>
</advancedsettings>
2.9.4 network
Don't expect people to do simple things for you. We all started not knowing "how to do this process" but we searched and learned. Dealing with Kodi is not simple and you do need to learn how to do some things by yourself - it is expected from you to read the help pages and search the forum before you ask a question. I am here from 2009 and I have only 108 posts since then - I read and try to do things myself but I also try to contribute and help others from time to time.
The link he provided is not for windows but for all platforms, including Android. It tells you about advancedsettings.xml file. Kodi doesn't have a special GUI section to modify its advanced settings, so you need to tell it what to modify. That's why you need to create that file and tell kodi which advanced setting or settings to modify.
The file
does not exist untill you make it and put it in a
specific location (your userdata folder) on your device. See the links to find out where to put it.
You just need to create a text file, call it advancedsettings.xml, open it in notepad (or some other text editor) and paste the code in it. Then save it and put it in the specified location on your device. That will disable http2 (in this case) and maybe fix your problem. The problem you have may not be a problem for other people on Android 11 so the solution you have here might not be a solution at all. Try it. Nobody will really know what is causing your problem if you don't provide a
log file. The log file is also in your
Kodi data folder.
and add on it
<advancedsettings>
<network>
</network>
</advancedsettings>
2.9.4 network
hey bro, thank you so much it worked in my phone , but i am facing the same issue in my laptop . i did the same thing there too but there problem still persist.
i can't play uhd iso's from my google drive account? but it's working well with my extern hdd. is this normal?
Hi everybody,
Can we hope to have google drive as a source ?
(2021-08-27, 11:30)boss92500 Wrote: [ -> ]Hi everybody,
if you want to use the addon as source then you should use RCLONE instead
