ok, i tried to make strm from my entire Library - big mistake
Takes FOREVER to run only through a couple of dozen folders, then dif things happen
kodi might crash
or plugin says, my credentials are no longer valid - this it not the case, i can still browse my folder.
and then when it starts again, it keeps reading the same files again instead of some new ones.
even without errors would take days nonstop running to read all my files.
so i guess i have to read it in piece by piece, but:
how do i make it stop to read that main folder
it never stops, keeps restarting that folder.
is there a config file i can delete the folder from?
unchecking that "watch cloud changes" didnt help
(2020-02-11, 12:13)z3us Wrote: [ -> ] (2020-02-11, 04:46)gilsonsjc Wrote: [ -> ] (2020-02-11, 04:25)z3us Wrote: [ -> ]Can you explain how did you solve the problems?
Here
(2020-02-10, 22:54)gilsonsjc Wrote: [ -> ]Sometimes it happens to me as well, it looks like the .../userdata/addon_data/plugin.googledrive/accounts.cfg file gets corrupted or something. So either delete the file all together OR delete your Google account from the plugin - either way you will have to add it back it. It will work right after you do it.
Thanks, but I was asking Kaido, who had problems playing 4k stuff
Sadly, I still have problems of buffering 4k so my bad. Idk if I need install “X 18.0 Kodi version” or Idk, its actually working better than kodi 18.5 but still getting buffer each 10 mins or just randomly.
resume play is not working well, it often does not ask.
Here
I guess I've replied to the wrong person 😅
(2020-02-12, 00:56)Kaido Wrote: [ -> ] (2020-02-11, 12:13)z3us Wrote: [ -> ] (2020-02-11, 04:46)gilsonsjc Wrote: [ -> ]Here
You guys having 4k playback issue with Kodi 18.5 on Xiaomi Mi Box S:
Xiaomi Box S. I have a detailed thread opened in the Android subforum to investigate this one, I suggest you guys following it as well 😊 ->
https://forum.kodi.tv/showthread.php?tid=350966
Hey guys
I entered my google drive "source" (as Source) not from Kodi, but within Firefox, to see what kind of error it will give me when I try to play any video.
This is what came up (from the google page)
error
errors
0
domain"usageLimits"
reason"dailyLimitExceededUnreg"
message"Daily Limit for Unauthenticated Use Exceeded. Continued use requires signup."
extendedHelp"https://code.google.com/apis/console"
code403
Hope this helps
Hi, This add-on can play ISO bluray file?
If I choose directly to 00000.m2ts in steam folder it work fine. But If I play folder or ISO file it not working.
I try to debug and got this msg.
"2020-02-12 11:39:30.236 T:5920 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(sources) in sources://video/VIDEO_TS/VIDEO_TS.IFO
2020-02-12 11:39:30.236 T:5920 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(sources) in sources://video/BDMV/index.bdmv"
Can I fix this issue?
Log removed pasted to https://paste.kodi.tv/vixawatola.kodi
(2020-02-12, 17:18)Kaido Wrote: [ -> ]Hello, I'm having problems with the addon again... I can't play any film, someone else?
http://paste.kodi.tv/ubusejijey
I'm having the same problem. I used to have my drive as a source for my library and it was working perfectly so far but one day it just stopped playing any files. I tried looking it up and th only solution I tried is installing the URL Resolver which I had already done and it still doesnt work. Don't know what to do really... Anyone help?
Its working right now just randomly, google drive thing or something
i exported file.strm from my folder. i added source but folder no show poster's folder, i used addon the movies database,
everyone can hepl me
I have added the Google drive Addon to my various Android based devices and want to use it to share content around the house.
so for example I download some content and rather than have to use usb sticks to view the content I put in on Google drive and then via the addon and kodi I can view this on the various sources.
When i set this up a couple of weeks ago it worked perfectly and I could see the content on all my android devices.
However in the last week its stopped working. I can physically see the content via Google Drive but when I click on the content it says "Loading" but then nothing plays.
Ive tried to clear cache, enable/disable the addon on, remove the google drive account that the content is stored on but none of this works.
Any suggestions??
TIA
