Hello,
Well not yet, because that's what I'm about to do BUT I'd like to post something like :
"Hello, I think there is a bug in the Netflix add-on because the inputstream adaptive is working perfectly with the Youtube add-on, but doesn't work in the Netflix add-on"
But to write something like that, I must be sure that I'm REALLY reading streaming trough inputstream adaptive in the Youtube add-on...
... and that's what's not clear to me, because it's written "ff-h264 (SW)" when I'm reading a mpd source in Youtube.
badsheep
On my windows install it shows 'ff-h264-d3d11va (HW)', the 'inputstream.adaptive.' prefix when using Netflix may be due to some Netflix specific requirements in InputStream Adaptive but I do not know for sure--I've never used the Netflix add-on--.
If you are seeing 1920x1080/1920x1088 on a YouTube video it is definitely using inputstream.adaptive. If you'd like extra confirmation you can change InputStream Adaptive Settings - General - Stream Selection to 'Manual', this will allow you to change video streams during playback--from OSD - Video settings--which in our case is only possible with mpeg-dash/inputstream.adaptive.
Thanks you're right, I test that !
You're absolutely right, when I enable "Manual" I can switch of resolution during a Youtube streaming... so it's definitely using inputstream adaptive.
Thanks for that good idea, I'm going to do a reclamation to the Netflix add-on
bye bye everybody !
badsheep Good to hear you were able to confirm
@all Live streams are currently not working
All of a sudden I am unable to play live YouTube streams. A live stream “runs” without actually loading for 5 seconds then stops. I can run the exact same live streams from within Internet Explorer on the same NUC box without problem. Further, non live YouTube streams run OK in Kodi (K 17.6).
I have made no changes to settings so am at a loss as to why this has happened. Does anyone have any suggestions, please?
JNRW YouTube has changed something, and live streams are not working. See the post before yours.
I only saw your post after sending mine!
Thanks for the reply. So a bit of patience required for now, then?
I am not sure, then, why I can play the same live streams satisfactorily in Internet Explorer.
It should be fixed today in the next alpha version
As I wish to continue learning about such things could you tell me what is going to be fixed and where would I look to check it out?
Hello, I'm using the YouTube version 6.2.3 with MPEG Dash enabled and the latest version. The streams are reproduced with only audio for 3 seconds and then it dies.
I thought the issue was fixed :S
I downloaded plugin.video.youtube-unofficial-6.3.0.alpha7.zip
although live streams work with this updated... they are (all) terminating after about 10 seconds.
So, I think live streams is _NOT_ fixed in plugin.video.youtube-unofficial-6.3.0.alpha7.zip
But thanks so much for working on this -- I rely on live streams for HSN, HSN2 and QVC (keeps my wife off my back)
(2019-01-11, 08:55)meNick Wrote: [ -> ]I downloaded plugin.video.youtube-unofficial-6.3.0.alpha7.zip
Same here aswell, am now using Alpha 7 but keeps cutting after 10 seconds
