Thank you, the beta5 zip fixed to problem for me
Smasherr It looks to be on YouTube's end; "This video contains material from a partner Dogus Digital, who blocked their display in your country in order to respect copyright"
Thank you, Beta 5 did the trick for me. However only after doing the extra function cache clear.
Thank you everyone for confirming the issue resolved. I've bumped the add-on to 6.3.0 stable and submitted to the official repository for review. There is no functional difference from beta5 so you are fine to wait for 6.3.0 from the official repository.
Hi folks,
w/ beta5 some videos now work, but a lot still dont. Neither do playlists.
See log:
https://file.io/CU68r4
metux
There appear to be
banned add-ons (wiki) present on your system. To receive assistance, the banned add-ons will need to be removed and a complete clean
debug log (wiki) provided.
Greetings,
Yes, the problem was solved in Beta 5.
I want to ask, when can we watch the 4K Resolution?
I'd be very grateful if that happened.
Best regards...
(2019-01-20, 19:29)anxdpanic Wrote: [ -> ]@Smasherr It looks to be on YouTube's end; "This video contains material from a partner Dogus Digital, who blocked their display in your country in order to respect copyright"
Then the error message should indicate that ;-)
Hi folks. Is there a Leia specific problem with trailers? I'm running beta 5 and libreelec 8.95.003 as well as rc5 on Windows and I just seem to get mostly crashes with trailers.
