(2015-03-03, 23:34)choekstr Wrote: [ -> ] (2015-03-03, 23:26)jclamster Wrote: [ -> ] (2015-03-03, 20:52)mikesilvo164 Wrote: [ -> ]If you create a local image folder with whatever images you'd like to have (or an image pack) and select multimage when setting up the menu item I think that would be the easiest way to solve this. The script used for the random images uses the fanart in the DB so you would need to build a movie library maybe this thread will help if interested in doing something like that.
Thanks. Can you direct me to where the folder should go? I'm not at my local machine right now...
Anywhere Kodi can see the files. This means the local filesystem, or even an SMB or NFS share or externally connected HD.
On Android I put mine in /sdcard/Pictures/XBMC
On Windows I put them in c:\users\username\Desktop\Images\XBMC
I got it working from transferring photos to storage/pictures. But it's weird, when I go to Setup the Aeon Nox main menu and then set item background to the path of storage/picture no photos show up, it's like that are invisible. Because when I activate that path the photos I put in that storage/pictures folder actually works, even though you can't see them.
Thanks Again
I thought I see an option to increase the time between background images. Is there an option on this skin or that or has that been taken out.
(2015-03-06, 04:51)AL8782 Wrote: [ -> ]I thought I see an option to increase the time between background images. Is there an option on this skin or that or has that been taken out.
There is no option in the settings but you can manually change it by opening Defaults.xml and changing line 13 to something higher.
(2015-03-06, 23:55)mikesilvo164 Wrote: [ -> ] (2015-03-06, 04:51)AL8782 Wrote: [ -> ]I thought I see an option to increase the time between background images. Is there an option on this skin or that or has that been taken out.
Thank you, I'll check that out.
The function to find trailer was disabled?
I can't seem to find the Defaults.xml file. Where would that be located? Thanks
It it just me, or did aeon nox 5 just went incompatible ? it disappeared from the repo, and i can't select it anymore ?
(2015-03-08, 12:48)Walt74 Wrote: [ -> ]It it just me, or did aeon nox 5 just went incompatible ? it disappeared from the repo, and i can't select it anymore ?
Same here. I guess it's because of this:
<import addon="xbmc.gui" version="5.8.0"/>
The stable channel is not there yet..
Accidentally the wrong version got pushed to the helix repo. Its already fixed on the backend so it should be updated automatically in a few hours.
Aeon Nox has just completely disappeared from Kodi about half an hour ago, came up with confluence.When I checked for the skin it wasn't even there anymore?
Ok I just read last few posts so I guess we wait for a few hours?..thanks guys.
Bignoid, the system updated to 5.5.9 so that okay now, thanks.
However to nice system (by phil65)to get additional movie/actor information with script.extended.info is completely locking up my Kodi 14.2 beta. I press down and the circle never stops turning again. Can anyone else conform this ?
(2015-03-08, 21:06)Walt74 Wrote: [ -> ]Bignoid, the system updated to 5.5.9 so that okay now, thanks.
Do you have all the required dependencies for extendedinfo installed?
(2015-03-08, 21:13)mikesilvo164 Wrote: [ -> ] (2015-03-08, 21:06)Walt74 Wrote: [ -> ]Bignoid, the system updated to 5.5.9 so that okay now, thanks.
I just reinstalled the addon from the repo to make sure i got all the dependencies, no succes still getting a script failure.
which dependencies should i check for ?
