(2020-09-04, 08:14)rossomike1966 Wrote: [ -> ] (2020-08-17, 18:57)Paul Shield Wrote: [ -> ] (2020-07-06, 13:26)rossomike1966 Wrote: [ -> ]Sure, trying to find a way to send a PM.from Settings>Interface>Skin>Skin>Get more i see only Aeon MQ8 and Aeon Tajo and others skin..but not Nox 5
If you want this skin, i can help you with it, i have it on my Dropbox.
thank you very much..i'd like to get it!!
can you send me in PM link please?
Sure, trying to find out how to send a pm.
(2020-09-07, 09:20)Paul Shield Wrote: [ -> ] (2020-09-04, 08:14)rossomike1966 Wrote: [ -> ] (2020-08-17, 18:57)Paul Shield Wrote: [ -> ]If you want this skin, i can help you with it, i have it on my Dropbox.
I cannot find this feature to send you a pm, but check this link.
https://dl.orangedox.com/wT8vKr
(2020-09-07, 09:30)Paul Shield Wrote: [ -> ] (2020-09-07, 09:20)Paul Shield Wrote: [ -> ] (2020-09-04, 08:14)rossomike1966 Wrote: [ -> ]thank you very much..i'd like to get it!!
thank you very much..it works!
HELLO CAN THIS SKIN BE INSTALLED ON KODI 19 MATRIX?
(2021-03-31, 11:54)8carlos88 Wrote: [ -> ]HELLO CAN THIS SKIN BE INSTALLED ON KODI 19 MATRIX?
No
Try the Aeon Nox SiLVO which is based on Aeon Nox, you can install it from the Kodi 19 library.
Settings>Interface>Skin>More
(2021-03-31, 13:15)Jeffers24 Wrote: [ -> ] (2021-03-31, 11:54)8carlos88 Wrote: [ -> ]HELLO CAN THIS SKIN BE INSTALLED ON KODI 19 MATRIX?
No
I have already tried it and I like this one more.
(2021-03-31, 14:49)8carlos88 Wrote: [ -> ] (2021-03-31, 13:15)Jeffers24 Wrote: [ -> ] (2021-03-31, 11:54)8carlos88 Wrote: [ -> ]HELLO CAN THIS SKIN BE INSTALLED ON KODI 19 MATRIX?
No
Then you will have to stay on an old version of Kodi
(2020-09-04, 08:14)rossomike1966 Wrote: [ -> ] (2020-08-17, 18:57)Paul Shield Wrote: [ -> ] (2020-07-06, 13:26)rossomike1966 Wrote: [ -> ]from Settings>Interface>Skin>Skin>Get more i see only Aeon MQ8 and Aeon Tajo and others skin..but not Nox 5
Just edit addon.xml in the skin folder. Change xbmc.gui line to <import addon="xbmc.gui" version="5.14.0" /> and it will work for Leia, had no issues with it. Does not work for me in Matrix (5.15.0), made my CoreElec crash.
(2021-04-10, 18:20)Raytestrak Wrote: [ -> ] (2020-09-04, 08:14)rossomike1966 Wrote: [ -> ] (2020-08-17, 18:57)Paul Shield Wrote: [ -> ]If you want this skin, i can help you with it, i have it on my Dropbox.
It seems to work fine in matrix windows 10
Quick question:
Aeon Nox Five skin, list widgets display and work fine on a phones touchscreen, but when moved to a Fire stick, I am unable to select it and operate it no matter whether I press up or down, please help?
Thanx
(2021-08-10, 20:04)Macaroni Slick Wrote: [ -> ]Quick question:
Thanx
Have you checked that the widgets are. set up in skin settings ? The addon they are from is enabled ?
(2021-08-10, 20:23)ontap Wrote: [ -> ] (2021-08-10, 20:04)Macaroni Slick Wrote: [ -> ]Quick question:
Thanx
Newbie, am slightly familiar with editing xml, but dunno what to look for.
TIA
(2021-08-10, 22:17)Macaroni Slick Wrote: [ -> ] (2021-08-10, 20:23)ontap Wrote: [ -> ] (2021-08-10, 20:04)Macaroni Slick Wrote: [ -> ]Quick question:
Thanx
TIA
I mean't in skin settings , in kodi , not editing XML's. When you say moved to firestick , do you mean a build ? or just a fresh kodi ? The connyent that the widgets are from , is it your own , stored on HDD ?
Aeon nox skin 5.
Set up list widgets to play content on pages in a build.
When on a touch phone the list widget responds normally. Plays great.
When I put the build I made on the skin on a fire stick, that function is not selectable by any gesture of the remote control.
English is my second language, I hope I am communicating effectively.
