BigNoid
I try to change View_59_Logo; my wish is to erase the gradient floor and the background fan art to black.
But I can't find it in the Code.
Help please
(2017-02-16, 19:28)Solo0815 Wrote: [ -> ]I have a problem on Leia v18
The window MyPVRRecordings is empty, it shows no recordings. Estuary is fine. The log says when I open the window:
17:21:10.491 T:1961836544 ERROR: Control 50 in window 10701 has been asked to focus, but it can't
I compared the code with the one from Estuary, but can't find anything that would point me to a fix :~
The fix for this
is here. Please add it to your master branch
Thx
(2017-03-07, 11:19)tjost Wrote: [ -> ]@BigNoid
Help please
That code is all in Includes_Backgrounds.xml. if you have trouble let me know through PM
Hi.
Is there a way to customise this notification ?
For example, display the country flag instead of the blue i ?
Blue i icon is named defaulticoninfo.png but I didn't find any reference of this texture in any xml file
Is it manage by Kodi and not by the skin ?
@mikebzh44: yes that is controlled by either Kodi core or through a script. In the skin there is only a teference to a blank image control.
Can I add the fanart of a movie or tv show to the Netflix based pause screen?
I am sure this question has been asked a million times but outside of using a skin like titan or mimic is there a mod or anything for aeon nox that just updates the look? I love the skin but would be nice to get a more modern look without all the drop shadows and gradients.
Hey Guys,
Wondering if anyone knows which xml file and location in that file that would increase the size of the center main menu when highlighted.
(2017-03-15, 12:15)Raytestrak Wrote: [ -> ]Can I add the fanart of a movie or tv show to the Netflix based pause screen?
Looking at the code in custom_1134_PausedOverlay, shouldn't it already show the fanart in the pause screen?
<control type="image">
<include>FullscreenDimensions</include>
<texture>$INFO[ListItem.Art(fanart)]</texture>
<animation effect="fade" time="600">WindowOpen</animation>
</control>
(2016-06-02, 23:49)Shinjiru Wrote: [ -> ]
Any idea why the "" are showing up before and after the plot here? If I remove the tagline the top "" disappear and if I remove the outline the bottom "" dissappear. Obviously, I want to continue using my taglines and outlines so I'd appreciate any assistance. This happens whether the movie is scraped or if I use a custom .nfo.
I'm using Kodi 16.1 and Aeon Nox 5.8.6.
I'm still having problems with quotation marks showing up at the beginning of my plot descriptions. Is there any way to get rid of them?
Here is another example and you can see that everything is fine at first:
But when I press 'OK' to see more...
Those quotes appear at the beginning of every plot description.
Any idea what's going on here?
Someone can point me where to find Add-on menu on Aeon Nox 5 for Krypton? There used to be in the System but not any more. Txs
(2017-03-24, 16:57)skullmonkey Wrote: [ -> ]Someone can point me where to find Add-on menu on Aeon Nox 5 for Krypton? There used to be in the System but not any more. Txs
System/System/Add-On's/Manage Dependencies/And click the back browsing.
Hope it helped -I'm using Swedish settings so I hope I did get it right in English.
