For an HDhomerun, is there a way for PTVL to pick next available tuner? Right now, my tuner is hard coded in settings2.xml which works, but wonder if there is a better way, as I want to share the config between multiple devices.
::Update::
I'm writing a caching system for BCT's to write to file all BCTs found and fill channels off that info... This will speed up channel building (First run might be slow, while building "cache list")...
Using Youtube commercials on auto causes black screen, empty channels. Works fine when using a set number.
LOG
Local commercials seems to do the same thing with auto on.
LOG
But local with a set number doesn't cause crashes, just no commercials.....
LOG
(2014-01-03, 21:27)Redkiller223 Wrote: [ -> ]Using Youtube commercials on auto causes black screen, empty channels. Works fine when using a set number.
LOG
LOG
LOG
I posted that auto wasn't finished, thanks 4 the logs anyway...
http://forum.xbmc.org/showthread.php?tid...pid1588099
Channels are being parsed and I can use PTV fine, but there are no local commercials (set to 3) in-between movies.
Commercials are on SMB and in mp4 format. Also don't have Commercials when I select Internet and have donor details entered.
https://gist.github.com/anonymous/8246896
I don't know what to put in "Trailers", could you explain that for noobs please.
(2014-01-03, 23:27)MovieJunky Wrote: [ -> ]Channels are being parsed and I can use PTV fine, but there are no local commercials (set to 3) in-between movies.
BCT's was a beta code push, still some work needed...
I will try and finalize code soon...
Ah okay, cool work nonetheless! Funny how everyone wants to put commercials back into the system ha
Luna, would you happen to know an answer to my question regarding changing the audio language within PTV? The regular hotkeys (xbmc commands) do not work,
those being AudioNextLanguage or XBMC2: Language. It's working perfect outside of PTV, just not inside.
(2014-01-04, 01:22)MovieJunky Wrote: [ -> ]Luna, would you happen to know an answer to my question regarding changing the audio language within PTV? The regular hotkeys (xbmc commands) do not work,
'm' opens info bar
try changing mapped button,
http://www.maiman.net/2012/03/how-to-eas...s-in-xbmc/
::Update::
BCT local cache expires 30 days from when it's created or when a force channel reset is triggered. The cache applies to Local and Internet BCT's but not Youtube.
First run will create local BCT cache and may take longer then your normal channel building, on all runs after that BCT's will build off it's local cache...
Which should speed things up... since query and parsing media is skipped.
I also removed the "all" feature since it's overkill and slows down PTVL to much...
Also something I should mention is to disable "debugging" in PTVL when your not experiencing problems.
Debugging creates a lot more log entries then needed and can slow down your system... Only enable when you want to recreate a bug and send me a log...
When you switch channels does the dynamic artwork option need to be enabled to get the poster and logo to show up for local movie files?
(2014-01-04, 20:38)Dumyat Wrote: [ -> ]When you switch channels does the dynamic artwork option need to be enabled to get the poster and logo to show up for local movie files?
Dynamic artwork means that while you scroll through the EPG the infocus (highlighted) media's artwork is displayed and changes. Instead of just displaying the artwork for what is playing.
So Yes it needs to be enabled to work, but if you don't have the artwork stored locally it won't display, you need to run artwork downloader script.
for LiveTV you don't need the artwork stored locally, but you need to enable api's inorder to parse and store show data.
(2014-01-04, 20:54)Lunatixz Wrote: [ -> ] (2014-01-04, 20:38)Dumyat Wrote: [ -> ]When you switch channels does the dynamic artwork option need to be enabled to get the poster and logo to show up for local movie files?
Thanks Luna.
Yeah, I understand what you are staying and the concept of having dynamic artwork enabled.
I know it might have sounded a bit of a weird and dumb-ass question to ask, but there was a reason for asking. Well, 2 reasons actually.
1) I'm not getting any posters/logos showing up for local movie files, but I am getting posters for my local TV shows, but not the logo. I do have all the necessary artwork stored locally for both Movies and TV shows.
2) When I enable API key for TMDB, PTVL is successfully parsing/updating all channels and opening with no problem. Artwork is also shown, but after 30 seconds or so, I'm getting a screen freeze and unable to move anywhere within the guide. Also, I've noticed that while I'm getting movie posters, I don't seem to be getting them for all. I've never seen this happen before, so it's quite un-usual. The only way I can exit is to close XBMC down completely via CTRL/ALT/DEL option.
So I have 2 different probs, so guess you would want 2 different logs?
Log when Dynamic artwork is not enabled, but no posters/logos showing :
http://xbmclogs.com/show.php?id=105840
Log for when dynamic artwork is enabled, but I'm getting screen freeze/crash :
http://xbmclogs.com/show.php?id=105847
Also, updated to latest build today. Been really scratching my head about this one, but if I scratch it anymore, then for sure I wont have any hair left!
(2014-01-04, 22:07)Dumyat Wrote: [ -> ] (2014-01-04, 20:54)Lunatixz Wrote: [ -> ] (2014-01-04, 20:38)Dumyat Wrote: [ -> ]When you switch channels does the dynamic artwork option need to be enabled to get the poster and logo to show up for local movie files?
Thanks Luna.
Log when Dynamic artwork is not enabled, but no posters/logos showing : http://xbmclogs.com/show.php?id=105840
Log for when dynamic artwork is enabled, but I'm getting screen freeze/crash : http://xbmclogs.com/show.php?id=105847
Thanks, I need you to enable debugging in XBMC, and also in the "misc" option in PTVL settings...
Please recreate the dynamic artwork enabled freeze bug, so I can find out what the problem is.
your other problem sounds like just a skin issue, hope you can understand my primary goal is to finish major features and then turn to cleaning up skin and interface problems...
(2014-01-04, 22:24)Lunatixz Wrote: [ -> ] (2014-01-04, 22:07)Dumyat Wrote: [ -> ] (2014-01-04, 20:54)Lunatixz Wrote: [ -> ]Dynamic artwork means that while you scroll through the EPG the infocus (highlighted) media's artwork is displayed and changes. Instead of just displaying the artwork for what is playing.
Thanks Luna.
No, No, that's totally fine and totally understand your priorities with the project. I normally do a search of the thread first anyway to see if any other users have had the same issue, but couldn't see anybody else reporting this, so maybe thought it was unique to me, or possibly more likely something I may have been doing wrong.
Yeah, I did enable debugging in PTVL as well as XBMC in the first instance, but for some reason the log uploader was giving me a script error......Grrrrrrr! Will try again and post the log when I have it. Thanks again
