(2015-02-14, 15:43)bry- Wrote: [ -> ] (2015-02-14, 15:00)queenofpop Wrote: [ -> ]Hi guys........ F.T.V and other plugins.
Please read Forum rules (wiki) and Banned add-ons (wiki) don't want this thread to get binned
Sorry - didn't read the rules before. I have tried to delete the post but am not allowed to do that. So I have edited it
Anyone have any suggestions for channel names that aren't displaying their logos?
Is there a plugin compatibility list?
(2015-02-14, 19:05)kizz Wrote: [ -> ]Is there a plugin compatibility list?
I think there's too many plugins to have such a list. I always make a test channel of each plugin I want to try, see if it builds an EPG and loads inside PTVL, and then go ahead and make the channels I want.
(2015-02-14, 19:15)RayW1986 Wrote: [ -> ] (2015-02-14, 19:05)kizz Wrote: [ -> ]Is there a plugin compatibility list?
Thanks for the answer, i have been doing that, but its trial and error. It would be nice if someone post a working list
(2015-02-14, 15:39)RayW1986 Wrote: [ -> ] (2015-02-14, 10:55)bornagainpengui Wrote: [ -> ] (2015-02-13, 16:30)bry- Wrote: [ -> ]you should probably learn how to use the new channel manager which is far better anyway.
Awesome, where's the link to the Linux version? Oh, wait....
The new channel manager is in the settings of the plugin, not an external program. It's been mentioned several times this week since its being added, Lunatixz has asked twice for feedback on it, and its in the changelog.
So, if you'd kept up with this thread and/or read the changelog, you'd know.
Holy ####, that is awesome news, I'll have to sit down and look through the new settings!
I do try to keep up with the thread but at over 800 pages in Tapatalk I admit I sometimes miss stuff. Ditto on the changelogs which I try to be better at following to see what is new, but honestly I always thought any reference to the channel manager was talk about the external app, which as alluded to is Windows only.
Thank you for correcting my ignorance.
Wouldn't it make sense to split this thread up and create eg. three threads: General help and support, bugs/issues/test, feature requests?
(2015-02-14, 19:45)jaochoo Wrote: [ -> ]Wouldn't it make sense to split this thread up and create eg. three threads: General help and support, bugs/issues/test, feature requests?
Nope, it would make more sense for users to include that information in the post subject: and message...
General Help needed...
What does Stream Validation do? I'm assuming it checks to make sure the streams have working links? So having Override Stream Validation turned off I'm assuming will make the channel building slower?
If anyone could confirm or correct my assumptions, that'd be great. Thanks.
When I use the concast skin with channel logos, this is an example of what happens. Every logo takes up a good chunk of the screen and blocks the epg when its station is selected. The logo is a png and 145 x 73.
On the default skin, the logos go where they need to and I can see the rest of the epg correctly.
Any ideas or suggestions on what I can do alleviate the issue? Do I have to mess with the xml settings and if so how?
Thanks in advance for your help
(2015-02-14, 20:44)lwsfs Wrote: [ -> ]Any ideas or suggestions on what I can do alleviate the issue?
I just released version 0.5.8e which fixes this problem. Download it and you should be all set.
I updated to PseudoTV Live 0.5.8e and I'm getting script failed....
Debug log
Running SPMC 14.1 on an Amazon Fire TV, unrooted. It was working fine before the update. I restarted SPMC and tried rebooting the AFTV to no avail. Any ideas?
(2015-02-14, 21:48)LakersFan Wrote: [ -> ]I updated to PseudoTV Live 0.5.8e and I'm getting script failed.... Debug log
Are you using the default PTVL skin? If not switch to it and try again.
Sorry, switched back to PTVL skin and I don't get the script error any longer. However, it is stuck on updating channel 2 (1%) for a couple minutes now. I'll let it continue for a little longer to see if it's just hung up.
Note: My prior channel configurations did not start at 1 (and I don't have autotune enabled), so I'm really sure what it's doing.
NVM rebooting windows fixed it sorry about that.
