Getting so close to Pluto.tv, but still not working. I'm on 0.6.1 now. I think I'm all set up properly, but 1) I don't get guide data in my EPG, and 2) When I launch a channel, it just continuously plays the Pluto banners. I'm able to browse the ptvlguide source in the in app channel config. I can launch Kinkin's Plutotv plugin, and it plays fine.
Here's the settings2.xml section for the 2 channels I tried to test with.
<setting id="Channel_5_type" value="8" />
<setting id="Channel_5_rulecount" value="1" />
<setting id="Channel_5_rule_1_id" value="1" />
<setting id="Channel_5_rule_1_opt_1" value=" 111: Covers" />
<setting id="Channel_5_1" value="Covers" />
<setting id="Channel_5_2" value="plugin://plugin.video.plutotv/?url=51fff2c33b19eb510c000032&mode=2&name=111%3A+Covers&iconimage=http%3A%2F%2Fs3.amazonaws.com%2Fpluto.tv%2Fassets%2Fimages%2Fchannels%2Fed7c1998-d0a6-125e-d1cb-ac47aa39e9e3-covers_squareS.jpg&showname=The+songs+you+know+covered%2C+rearranged%2C+and+reimagined+by+famous+musicians+and+the+latest+web+stars." />
<setting id="Channel_5_3" value="ptvlguide" />
<setting id="Channel_5_changed" value="False" />
<setting id="Channel_5_4" value="" />
<setting id="Channel_6_type" value="8" />
<setting id="Channel_6_rulecount" value="1" />
<setting id="Channel_6_rule_1_id" value="1" />
<setting id="Channel_6_rule_1_opt_1" value=" Music - 101: Top 40" />
<setting id="Channel_6_1" value="Top 40" />
<setting id="Channel_6_2" value="plugin://plugin.video.plutotv/?url=51c75f7bb6f26ba1cd000017&mode=2&name=Music+-+101%3A+Top+40&iconimage=http%3A%2F%2Fs3.amazonaws.com%2Fpluto.tv%2Fassets%2Fimages%2Fchannels%2Fd95a9706-1fe0-5dfc-895f-8033dea0de5e-top40squareS.jpg&showname=Today%27s+hottest+tracks+from+the+Top+40+charts.+Non-stop+hits+served+hot+and+fresh+every+day." />
<setting id="Channel_6_3" value="ptvlguide" />
<setting id="Channel_6_changed" value="False" />
<setting id="Channel_6_time" value="797" />
<setting id="Channel_5_time" value="797" />
</settings>
Am I supposed to be using kinkin's plugin for this?
Hello,
Using the PseudoTV Live's Channel Configuration Tool, I setup channels for all of my TV Series.Works great; except, when refreshing, the TV series M*A*S*H is not picked up. M*A*S*H shows up in the selector in the Channel Configuration Tool but does not appear in the EPG. Kodi scrapes and displays it without issue. The series folder name is MASH.
Is this a bug or am I doing something incorrect?
Hey is there any reason ustvnow doesnt work in ptvl anymore??
(2015-03-28, 03:53)Bbold Wrote: [ -> ]Hey is there any reason ustvnow doesnt work in ptvl anymore??
Have you checked to make sure you were logged in and set at the proper bitrate? I had ustvnow stop working and it turned out that some how I was no longer logged in and the bitrate was set higher than free users are allowed. Once I logged into my account from the plugin settings and adjusted the bitrate everything worked again as expected.
Edit: Never mind, just started up after the update and I no longer have ustvnow either. Will play with it in the morning and submit a log then. Going to bed now.
you must copy again the skin in custom and than works
hi again guys
have searched through the thread for an obvious answer and i can't find one, so here goes
is there a way i can have a normal channel bug appear on screen and use a different logo in the channel list?
i remember once upon a time you could add "_c" to the end of the png file you use for the logo, but that functionality doesn't seem to exist anymore (or i'm too stupid to use it..
have donated too
hope that makes sense - thanks in advance
Update changed the xmltv field in configs from "ustvnow" to "ptvlguide". So you'll have to update you configs.
(2015-03-28, 15:15)mrsmooth81 Wrote: [ -> ]hi again guys
i remember once upon a time you could add "_c" to the end of the png file you use for the logo, but that functionality doesn't seem to exist anymore (or i'm too stupid to use it..)
have donated too
look at your settings2.xml file and see if there is space in front of the channel name (<setting id="Channel_XXX_rule_1_opt_1" value="channel name" />, you can remove the space and it should work, as long as the .png file is named the same without the space. Also make sure the channel name is less than 18 characters in length.
(2015-03-28, 07:32)bornagainpengui Wrote: [ -> ]Any chance you could make an update to the skin? After updating PTVL I'm getting told there's something wrong with the custom theme so I think something in the latest improvements may have disagreed with your skinning. I really like the skin though and hope you're planning on continuing to develop it!
I'll get a fix out in the week when I have some spare time
(2015-03-28, 19:16)RayW1986 Wrote: [ -> ] (2015-03-28, 07:32)bornagainpengui Wrote: [ -> ]Any chance you could make an update to the skin? After updating PTVL I'm getting told there's something wrong with the custom theme so I think something in the latest improvements may have disagreed with your skinning. I really like the skin though and hope you're planning on continuing to develop it!
I think you should rely on information from me... since absolutely nothing has changed that would break a skin.
(2015-03-28, 19:20)Lunatixz Wrote: [ -> ] (2015-03-28, 19:16)RayW1986 Wrote: [ -> ] (2015-03-28, 07:32)bornagainpengui Wrote: [ -> ]Any chance you could make an update to the skin? After updating PTVL I'm getting told there's something wrong with the custom theme so I think something in the latest improvements may have disagreed with your skinning. I really like the skin though and hope you're planning on continuing to develop it!
I haven't read through the thread so I was just going on what I quoted. But that's good news, means less work for me
(2015-03-28, 12:27)oibaf79 Wrote: [ -> ]you must copy again the skin in custom and than works
Thank you. I wasn't aware that updating the program deleted any custom skins. Thankfully the SKY skin is still available for download and wasn't that big to begin with so not a big deal. Sure would be nice if this was mentioned somewhere in the changelog.
Maybe it was this item?
[*] Various tweaks & bug corrections
In any case I now know about this undocumented behavior and will make sure I keep a local copy of the skin backed up so I don't lose it. Thanks for telling me about it.
Not a big deal. Turns out PTVL deletes the custom themes on update for some reason. Will just recopy and continue onwards. Sorry to have bothered you, but it had never occurred to me that this would be expected behavior.
