I think I found a small bug: I am unable to define the content of (video) sources (TV Show, Movie etc.), both for newly added sources as well as of existing sources. I had to switch to confluence to do that.
What else can I provide to ease debugging?
Anyone know of a way to create a widget that shows recommended tv and movies based on what you've watched? Probably a pipedream but thought I'd ask!
(2016-01-07, 22:40)fach1708 Wrote: [ -> ]Anyone know of a way to create a widget that shows recommended tv and movies based on what you've watched? Probably a pipedream but thought I'd ask!
Smart(ish) Widgets is probably what you're after.
Can be found
here now.
EDIT: Thanks for asking about this as I'll try and add it to the next release.
(2016-01-07, 23:24)Hitcher Wrote: [ -> ] (2016-01-07, 22:40)fach1708 Wrote: [ -> ]Anyone know of a way to create a widget that shows recommended tv and movies based on what you've watched? Probably a pipedream but thought I'd ask!
Can be found here now.
Brilliant thanks, think I'll wait till you implement it as it seems a bit beyond me lol
Now you've added support how do I add the widgets?
Hang on I haven't added it yet.
Hey Hitcher, I've been loving the updates and collaboration you've been doing with other members too.
One thing bugs me alot, I don't want the "FTV widgets loading" indicator, I want it to just goto the home menu and eventually load my widgets like it used to.
See I test this on a fire tv stick and it takes almost 2 mins to get past that screen, I know as you've said before, take out some widgets but I don't want to, I just want it to goto the home menu like it used to and load the widgets later.
Can you direct me as to what code or calls I need to take out to get it back to how it used to be?
Thanks, really appreciate all the time you've been putting into this lately for us!
Quickiest way would be to change the following in the Home.xml.
<defaultcontrol>90000</defaultcontrol>
to
<defaultcontrol>9000</defaultcontrol>
(2016-01-07, 23:24)Hitcher Wrote: [ -> ]Smart(ish) Widgets is probably what you're after.
If you're using both skinshortcuts and skinhelper in the skin it should be available automatically, even giving the user the option to install smart widgets. Let me know if you need any assistance implementing.
(2016-01-08, 11:53)marcelveldt Wrote: [ -> ] (2016-01-07, 23:24)Hitcher Wrote: [ -> ]Smart(ish) Widgets is probably what you're after.
Only if it's enabled in the skin (it requires a skin bool set in order to work + show up in the default widgets), and only if the skin is using skinshortcuts GUI 312 or Just Select Widgets method - so unfortunately there is a little work Hitcher needs to do to enable it first
(Though if I ever get the time to polish my dev branch of smart(ish), I'll remove the enable-in-skin requirement if I can do so in a sensible way
(2016-01-06, 02:40)Kokonutcreme Wrote: [ -> ] (2016-01-04, 11:09)Kokonutcreme Wrote: [ -> ]Hitcher
I've created a favourite based on a video source for personal videos. In other skins I can add the favourite as a home menu item and when selected it will display the file list of content.
However FTV behaves differently. It opens the video source menu forcing me to navigate to the Files menu and manually select the source to display the content.
This behaviour is unique to adding video sources to favourites, other files added as favourites open directly.
Is this a bug?
Hi Hitcher, were you able to take a look at the issue I reported earlier?
Apologies, nothing wrong with video source favourites opening correctly from home menu, it was when I added them to a widget.
(2016-01-07, 20:27)Rasscal Wrote: [ -> ] (2016-01-01, 19:46)workstation Wrote: [ -> ] (2015-12-30, 14:24)Rasscal Wrote: [ -> ]Could you please re-link these files. I would love 20 widgets
Hello Rasscal,
this is not a problem.
I have asked the said files back online.
https://www.dropbox.com/s/zy06resbsgrt05...v.zip?dl=0
@all
Happy New Year
You sir are a gentleman and a scholar
Thanks hitcher for making it all possible
sorry, i'm a noob...how can i add more than 8 widgets using the .xml files into the dropbox folder?
Since the update with the new search function, my Kofi has been freezing randomly sometimes when I open up to search.
