(2016-02-22, 21:15)Hitcher Wrote: [ -> ]Thanks both of you.
no problem, let me know if you need the PNG sequence file for better quality
(transparent gif usually cause some rough edges due to gif's limit)
(2016-02-22, 21:12)ghanafirst Wrote: [ -> ]I love this skin thanks for your great work. One question anytime I use the search on the home page I don't get any results, is there something I'm missing? if so can you please help. Thanks.
A library of videos?
What do you mean by A library of videos ??
Your locally stored videos that have been scanned to the library.
Sorry if this was asked before, how well does the skin for Krypton works on Jarvis?
(2016-02-24, 01:51)nikicampos Wrote: [ -> ]Sorry if this was asked before, how well does the skin for Krypton works on Jarvis?
Some thing will work, other things wont.
It looks like this skin consumes a bit too much power on my firetv stick, because 1080p videos and menu don't run really smooth.
Been away awhile but have been using this skin from day one. I'm picking through the thread but I have questions
1. Its highly unusual for me to use a skin whose predessor isn't officially a rc (least I don't think it is). Is there a good reason to skip Jarvis and jump to kryton? Major bugs?
2. It was awhile ago, but I needed to follow a tweak here to get 20 widgets to show up. Is this still the case or was it corrected?
#2 is really my main concern. I assume there'll be bugs with the newer kodi builds but if anyone wants to comment on specifics I'd appreciate it. Greatly appreciate it. It'll potentially save me a lot of time. Thanks
(2016-02-24, 10:31)Hitcher Wrote: [ -> ] (2016-02-24, 01:51)nikicampos Wrote: [ -> ]Sorry if this was asked before, how well does the skin for Krypton works on Jarvis?
What is the recommended "reliable" configuration then? Isengard or Krypton. Keep getting the widgets not showing problem so would like to know what is the best option.
If you want a stable version based on Jarvis, Sualfred has modified Hitchers skin to add live tv; even if you don't use the live tv, it's designed to be used on Jarvis:
http://forum.kodi.tv/showthread.php?tid=253058
Hitcher always develops on nightlies.
Hi Hitcher,
I have a Question:
I use jarvis in the final version.
I have updated today the ftv Skin and now all the categories like recently added films are in english.
By the way: i am an German user.
How Van i fix it.
In the old version all seems to be fine.
Flex
(2016-03-04, 15:12)imadunatic Wrote: [ -> ]If you want a stable version based on Jarvis, Sualfred has modified Hitchers skin to add live tv; even if you don't use the live tv, it's designed to be used on Jarvis: http://forum.kodi.tv/showthread.php?tid=253058
Does this include the ability to add 20 widgets?
(2016-03-04, 04:33)Route6 Wrote: [ -> ]Been away awhile but have been using this skin from day one. I'm picking through the thread but I have questions
1. All depends if you want to continue using this skin or not.
2. 8 widgets max.
(2016-03-04, 15:04)stuartmc Wrote: [ -> ] (2016-02-24, 10:31)Hitcher Wrote: [ -> ] (2016-02-24, 01:51)nikicampos Wrote: [ -> ]Sorry if this was asked before, how well does the skin for Krypton works on Jarvis?
Krypton if you're using my skin.
(2016-03-06, 04:08)Flexus83 Wrote: [ -> ]Hi Hitcher,
I have a Question:
How Van i fix it.
Flex
This skin is for Krypton only.
Oooh, I see good stuff to merge
