Hitcher
Thank you for taking the time to develop this theme its a solid theme, just to let you know that on matrix there are a couple of issues i found with the theme from the GitHub repo, one being the shutdown timer currently doesn't seem to work on matrix (think it maybe to do with the xbmc naming), not sure if your still developing this theme but if you are i can post the fix in PR on GitHub if you point me in the right direction.
Also just wondering if you will be sending this skin upstream for the matrix repo?
Kind regards
(2021-02-25, 01:28)Hitcher Wrote: [ -> ]Didn't think anyone was still interested to be honest but you can get it from GitHub.
https://github.com/HitcherUK/skin.ftv/ar...master.zip
Hello, I'm currently using your ftv skin on matrix but can't seem to get the skin shortcuts installed, any help pls?
(2021-03-20, 19:22)Hitcher Wrote: [ -> ]You'll need the latest version.
https://github.com/mikesilvo164/script.skinshortcuts
Just wanted to give you a huge thanks for this skin. Using Kodi with any other skin is such a chore and I was absolutely gutted when Matrix first came out and I couldn't use this skin.
I have tried to install the one you linked here with the latest version of Kodi Matrix (19.1) and it says that it is not compatible. Please please please can you make it work
(2021-05-19, 14:50)pyr0maniac Wrote: [ -> ] (2021-03-20, 19:22)Hitcher Wrote: [ -> ]You'll need the latest version.
Please disregard, I was trying to install from the wrong zip
Just tried to install on Kodi Matrix (Firestick) using that link and it gave an error. Says failed to install a dependancy. Am i doing something daft? I previously installed a different skin using the same install process and that worked ok.
Hello Hitcher,
Thanks for bringing my fave skin to Matrix.
I’m not sure if I did something wrong. I have a clean install with SQL db and only amber skin and basic add-ons installed.
As soon as I modify the Home Screen at all, all the widgets (in progress, recently added, etc) disappear. I have to reset Home Screen to get them back.
Is this because any modification means I need to manually add the widgets? Or is this maybe a problem on my side (if so I’ll try totally clean install).
Thanks again!
(2021-08-19, 18:45)themindset Wrote: [ -> ]Hello Hitcher,
Thanks again!
Having exact same problem - if I try to disable any of the widgets I don't use on the Home Screen, they all disappear.
Do you have the skin shortcuts addon installed?
(2021-10-19, 00:49)Hitcher Wrote: [ -> ]Do you have the skin shortcuts addon installed?
Was not installed by fTV, but I installed Rapier skin last night, which added it. Tried to remove "Games" from the Home Screen under fTV, but again it took out everything
(2021-10-19, 17:23)christoofar Wrote: [ -> ] (2021-10-19, 00:49)Hitcher Wrote: [ -> ]Do you have the skin shortcuts addon installed?
Actually I spoke too soon, I'm not finding it listed under supported addons. I grabbed the linked addon zip of it from earlier upthread, but it doesn't want to be installed. Select install from zip, and point it to it, but no further activity or confirmation of it's install.
