You might want to ask Phil in the ExtendedInfo thread and do you have the script.favourites script installed?
The new skin looks nice, but it's not very convenience. For example, I am unable to add video sources, only movies are shown on the home screen . At least the default Confluence gives me the option to create new short cuts on each category ( movies, video, Live TV,....)
(2015-05-20, 14:26)Hitcher Wrote: [ -> ]You might want to ask Phil in the ExtendedInfo thread and do you have the script.favourites script installed?
Yes I have the script installed. When I open favourites via home menu Kodi shows me the addons I added to favourites. Only the widget is not display on home screen.
Hitcher your skin fires a "similarmovies" call to extendedinfo when opening episode info dialog, probably in combination with an episode DBID. That´s why those script errors occur.
I'm using this inside the content tags to fill a list -
plugin://script.extendedinfo?info=similarmovies&&dbid=$INFO[ListItem.DBID]
I'm on the latest version of Extended Info and have no errors here.
(2015-05-20, 15:02)effy123 Wrote: [ -> ]The new skin looks nice, but it's not very convenience. For example, I am unable to add video sources, only movies are shown on the home screen . At least the default Confluence gives me the option to create new short cuts on each category ( movies, video, Live TV,....)
(2014-10-28, 00:42)Hitcher Wrote: [ -> ]To do
Customisable home widgets
Videos > Files > Add videos.
(2015-05-20, 15:36)dimaceti Wrote: [ -> ]Yes I have the script installed. When I open favourites via home menu Kodi shows me the addons I added to favourites. Only the widget is not display on home screen.
Tried resetting the home menu?
yes for movies that´s perfectly fine but you also start that call when opening the episode info dialog. tested it here, too.
For TV shows I use -
plugin://script.extendedinfo?info=similartvshows&&dbid=$INFO[ListItem.DBID]
Is that wrong because it works for me?
(2015-05-20, 16:11)Hitcher Wrote: [ -> ]For TV shows I use -
no, that´s also fine, but tvshows != episodes.
It actually should have been -
plugin://script.extendedinfo?info=similartvshows&&dbid=$INFO[Window(home).Property(TVShowID)]
Videos>Files > Add videos
Where is the file located? Which file?
(2015-05-20, 16:30)Hitcher Wrote: [ -> ]Home screen - Videos.
Thanks Hitcher. I'll try it tonight.
Video > Files > Add Videos
This opens a new window "Add Video Source - Enter the path or browse for media location"
I am unable to find the file. What's the name of the file and where is it located?
