THX popcornmix
on all my 3 peaces of Pi i use the equal Samsung 32GB evo SD card with equal testbuilds and AddOns.
All Pi have the correct mpeg codecs from Rasp-shop -> verified
i observed this mode of behavior with the pi3 also on the lanports 2,3 and 4 with different mode of behavior (equal manufacturing company from RSonline).
Tested with an other Kingstenfresh insalled sd-card on pi3 with no positiv result (LibreELEC-RPi2.arm-7.0.3)
I think i have to put this PI3 into the garbage can / trash ... tzz :-(
(2016-08-02, 21:17)doldi Wrote: [ -> ]on all my 3 peaces of Pi i use the equal Samsung 32GB evo SD card with equal testbuilds and AddOns.
Did you swap the Pi2 and Pi3 over?
i.e. you currently have Pi2 with SDcard A connected to ethernet cable A, and Pi3 with SDcard B connected to ethernet cable B.
I want you to swap so Pi2 uses SDcard B and ethernet cable B and Pi3 uses SDcard A and ethernet cable A.
popcornmix,
1)
have put the SD card from fine working Pi2 into the raspiPi3 and he did not work without stuttering with 1Gb/s or 100Mb/s on all my lanports.
2)
put the pi3 SD card into my raspi-pi2 all LAN Ports will work fine without video stuttering.
checked all options i think
(2016-08-02, 21:50)doldi Wrote: [ -> ]checked all options i think
Does adding smsc95xx.turbo_mode=Y to cmdline.txt help?
(2016-08-02, 21:52)popcornmix Wrote: [ -> ] (2016-08-02, 21:50)doldi Wrote: [ -> ]checked all options i think
hmm, only temporarily, a little better but after 10 seconds stuttering begins.
Problem with #802 (upgrade from #801), unable to boot on Pi2 B and Pi3, Just loops endlessly between Kodi and LibreELEC animations. Doesn't get any further
(2016-08-02, 23:08)beertank Wrote: [ -> ]Problem with #802 (upgrade from #801), unable to boot on Pi2 B and Pi3, Just loops endlessly between Kodi and LibreELEC animations. Doesn't get any further
Same here. It looks like the restart happens pretty far up the loading sequence. I can still remote in and put #801 in .update. Unfortunately after uploading the old version it does not load and stays in the loop.
Bill
(2016-08-02, 23:10)bill_orange Wrote: [ -> ] (2016-08-02, 23:08)beertank Wrote: [ -> ]Problem with #802 (upgrade from #801), unable to boot on Pi2 B and Pi3, Just loops endlessly between Kodi and LibreELEC animations. Doesn't get any further
Bill
I was able to copy #801.tar to .update then rebooted OK to #801 and gave warning message that #802 was NOT installed. Seems to be working fine in #801
Apologies, #0802 is not a good build, I've pulled it from the servers.
I just came home to find the Pi1, Pi3 and NUC on the splash screen. Since Kodi is failing to even create a new log, my "good build" detection (which parses kodi.log to detect successful startup) failed to identify this snafu as the log from #0801 is being verified (which was an OK build), sigh. Anyway that's fixed now so we shouldn't have a repeat of this (ie. publishing a build that can't even start kodi).
PR10217 is needed which will be in #0802b.
(2016-08-02, 23:28)beertank Wrote: [ -> ] (2016-08-02, 23:10)bill_orange Wrote: [ -> ] (2016-08-02, 23:08)beertank Wrote: [ -> ]Problem with #802 (upgrade from #801), unable to boot on Pi2 B and Pi3, Just loops endlessly between Kodi and LibreELEC animations. Doesn't get any further
Bill
On the second try, I was also able to recover. I was forcing the reboot by pulling power. I think you have to yank out the power cord at the right spot in the loop.
(2016-08-02, 23:35)bill_orange Wrote: [ -> ] (2016-08-02, 23:28)beertank Wrote: [ -> ] (2016-08-02, 23:10)bill_orange Wrote: [ -> ]Same here. It looks like the restart happens pretty far up the loading sequence. I can still remote in and put #801 in .update. Unfortunately after uploading the old version it does not load and stays in the loop.
Bill
After the copy to .update I could SSH (Putty) and issue a reboot command, so no need to pull power.
Confirm #802b boots up fine. Thanks for prompt fix Millhouse.
New LibreELEC.tv Krypton build #0802b:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.7.0 #1 Tue Aug 2 22:32:12 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jul 28 2016 12:46:32
Copyright (c) 2012 Broadcom
version e12916091ba9d68ef2780e4e142ade56aa301754 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160802223029-#0802b-gfb39931 [Build #0802b]
# vcdbg log msg 2>&1 | grep DTOK
002390.470: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
LibreELEC.tv master (fb39931f,
changelog) and tip of
XBMC master (f5f9dc51,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.7.y
- Includes latest bcm2835-driver master (1205048f, ahead +1)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (fac3a954, ahead +34)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (44447b07, +8), inputstream.rtmp (7bf2298e), inputstream.smoothstream (b63ecbb4, +3), peripheral.joystick (6090a90e), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (20e1ccb4), pvr.dvbviewer (7a7ead36), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (66dcb89f), pvr.iptvsimple (21e91a5f), pvr.mediaportal.tvserver (72452b9d), pvr.mythtv (d10d210b), pvr.nextpvr (32b3c2ff), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (5f440e00, +4), pvr.vbox (f38f82f0), pvr.vdr.vnsi (8515b4bf), pvr.vuplus (4f2ad621), pvr.wmc (979c37db)
- Exclude [env] kodi-999.99-PR10164-add-aetempo-filter.patch: Merged upstream
- Exclude [env] kodi-999.99-PR10206-recursive-remove.patch: Merged upstream
- Exclude [env] libcec-PR208.patch: Merged upstream
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] PR:535: init: Add upgrade check to avoid incompatible upgrades [RFC,WIP]
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:171: fix seeklabel (kodi-theme-Estuary)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:10157: [WIP] Double the backslash in mysql in case we're in 'LIKE'
- Include [pkg] PR:10217: [linux] fix datadir (KODI_HOME) detection
Build Highlights:
- More libcec updates
- inputstream.mpd and inputstream.smoothstream updates
- #0802b: PR:10217: [linux] fix datadir (KODI_HOME) detection
Build Details:
- LibreELEC.tv:
- kodi: update to 17.0-alpha3-fc46cf2 (PR:592, 5 commits, 28 files changed)
- RPi: Fix Kodi build failure due to aetempo commits (PR:595, 1 commit, 1 file changed)
- projects/imx6: update kodi patch for 17.0-alpha3-fc46cf2 (PR:596, 1 commit, 1 file changed)
- XBMC:
- VideoPlayer: fix pixel format for ffmpeg based hw decoders (PR:10213, 1 commit, 1 file changed)
- [xbmc][improvement] Fix detection of KODI_HOME (PR:10180, 2 commits, 5 files changed)
- [PVR][json-rpc] Added field PVR.Fields.Channel.isrecording (PR:10179, 1 commit, 3 files changed)
- [xbmc/fix] Fix crash on shutdown (PR:10204, 1 commit, 3 files changed)
- [xbmc[[cleanup] Add a variadic overload to AddFileToFolder to simplify usage (PR:10012, 2 commits, 21 files changed)
- [settings] restore input devices to system, and move json-rpc app set… (PR:10201, 1 commit, 5 files changed)
- fix listprovider updating (PR:10203, 3 commits, 2 files changed)
- libcec:
- added: enduring events (long press) in eventghost. fixes #188 (240b195c)
- Merge branch 'pr192' into v4 (44a3d14c)
- added: TransmitSystemAudioModeRequest() (1157d109)
- fixed: send a <system audio mode request> when an avr is found and the source is activated (73546ee1)
- Merge branch 'pr208' into v4 (4c75c4de)
- Fix TDA995x check, part 2 (2bd62826)
- TDA995x: Add missing std:: namespace (85709f47)
- Merge branch 'pr214' into v4 (511163e7)
- Fall back to look for libudev.pc if udev.pc is not usable (298e62bd)
- Merge branch 'pr231' into v4 (66deb68d)
- Merge branch 'v4' (0f2be44e)
- added: EnableAudio() API command (f7551592)
- added: udev rule to prevent modemmanager and mtp from probing the CEC adapter, which prevents it from working right after it gets plugged in (71dbfcdc)
- fixed: missing param check in TransmitSystemAudioModeRequest() in 1157d1095ac5e406b4163d3950d77b716990ec23 (62b8520c)
- inputstream.mpd:
- inputstream.smoothstream:
- pvr.stalker:
- session manager (PR:71, 4 commits, 15 files changed)
(2016-08-02, 22:24)doldi Wrote: [ -> ]hmm, only temporarily, a little better but after 10 seconds stuttering begins.
What does
vcgencmd get_throttled
report after you have had stuttering?
I seem to have video stuttering with DTS videos. Any setting I need to change?
