Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
New LibreELEC.tv Krypton build #0817: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.7.0 #1 Wed Aug 17 22:58:39 BST 2016 armv6l GNU/Linux
# vcgencmd version
Aug 16 2016 14:36:37
Copyright (c) 2012 Broadcom
version 745cb6a4122e616a2e68534c3c98faaf237e0fc7 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160817225656-#0817-g81237d7 [Build #0817]
# vcdbg log msg 2>&1 | grep DTOK
002385.729: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of LibreELEC.tv master (81237d78, changelog) and tip of XBMC master (0300eae4, changelog) with the following modifications: Build Highlights:
  1. Fix GPU memory leak with windowed video, and hidden animations (link)
Build Details:
  1. LibreELEC.tv:
    • spotify-connect-web: rework (PR:616, 1 commit, 7 files changed)
    • kodi/Intel: Various improvements from fritsch (PR:573, 4 commits, 6 files changed)
    • webgrabplus: add user defined pre/post processing (PR:617, 1 commit, 3 files changed)
    • scripts/mkimage: set real volume label on system partition (PR:626, 1 commit, 1 file changed)
    • emby: update and enable optional platform specific hardware transcoding (PR:612, 4 commits, 8 files changed)
    • chromium: add xdotool (PR:597, 2 commits, 3 files changed)
    • multimedia-tools: add alsamixer, bump mpg123 and squeezelite (PR:620, 4 commits, 5 files changed)
    • imagemagic: udpate to 6.9.5-5 (PR:630, 1 commit, 1 file changed)
  2. XBMC:
    • [Language] - added a second label "Input" in the context of input dev… (PR:10301, 1 commit, 2 files changed)
    • Settings: make Peripherals a Standard setting, not Advanced (PR:10302, 1 commit, 1 file changed)
    • [darwin] - fix ssl access from python addons (PR:10108, 11 commits, 17 files changed)
    • TextureManager: We still need to free textures when playing video (PR:10305, 1 commit, 1 file changed)
    • Fix defect in CID 142067 and CID 142228 (PR:10303, 2 commits, 2 files changed)
  3. newclock5:
    • New commits in this build:
      • VideoPlayer: fixes for rewind (917b04e9)
      • GUIImage: Avoid hidden animation resources not being freed (35234a7f)
What version of SMB does LibreElec use? From what I can see it's defaulting to SMB1?
Is there anyway to enable SMB2 or 3?
My media is hosted on a Media server with Dedupe enabled, problem is that when using SMB1 it returns unreadable files, however every other client that uses SMB2 or 3 gets the right blocks and can play the files.
For now I've been hosting using a DNLA server instead of SMB but would much rather use SMB (since my server is on a different subnet from the pi usually)
Thanks for the help
@Milhouse:
First: Thank you for all this nice builds.Smile
Second: Since version #0731 the Library-Settings are not accessible any more (#0730 was working, #0817 is still bad).
(Changelog from #0731: ...Reorganise Library Settings (now called Media Settings)...)
Info: I am using Transparency Skin, I have not tested with the default Skin. I have the fear that the Skin developers have to do some adaptation because of the name change.
Please acknowledge or what info do you need or what should I test or where/to whom can I report this bug?
@Milhouse: How to fix error on build #816 (the same in built #814, #815 skipped)
(2016-08-18, 02:31)Corellon Wrote: [ -> ]What version of SMB does LibreElec use? From what I can see it's defaulting to SMB1?
Thanks for the help
Samba 3.6.25, which supports SMB1 and SMB2 but not SMB3.
With smb:// the connection is created by Kodi so you'll probably need to ask in the OS independent section as your question doesn't appear to be specific to LibreELEC or these builds.
SMB2 and SMB3 is not enabled in the kernel so OS mounts are unlikely to work with your server. Have you tried nfs:// instead?
(2016-08-18, 02:53)Transponder69 Wrote: [ -> ]@Milhouse:
Test with Estuary and only report issues reproducible with Estuary. Anything else is a third party skin issue that you report to your skin maintainer.
(2016-08-18, 04:23)TVPL Wrote: [ -> ]@Milhouse: How to fix error on build #816 (the same in built #814, #815 skipped)
I can't tell anything from your photograph. Did this problem start with #0814 (ie. #0813 is working)? What steps lead up to this problem? Upload a debug log (wiki).
(2016-08-18, 04:30)Milhouse Wrote: [ -> ]
Yes, this problem start with #0814 and show in Home screen when startup. Select OK and everything work fine.
I run RPi2 on my car so debug log not ready, sorry about that.
(2016-08-18, 06:47)TVPL Wrote: [ -> ]Yes, this problem start with #0814 and show in Home screen when startup. Select OK and everything work fine.
OK, nothing really obvious in #0814 so will need the debug log to comment further. Enable debug logging, reboot, then upload the log.
Still having trouble to use channel 13 for WIFI.
Is there a setting for WIFI country, or any way to enable channel 12/13
(2016-08-18, 07:27)Milhouse Wrote: [ -> ]
The same in #817, debug log here: http://sprunge.us/QRWd
(2016-08-18, 16:30)TVPL Wrote: [ -> ]The same in #817, debug log here: http://sprunge.us/QRWd
I don't understand why this would start only with #0814, as this would seem to be the source of the notification:
16:49:04  14.601470 T:1873802144   ERROR: CCurlFile::FillBuffer - Failed: Couldn't resolve host name(6)
16:49:04  14.601711 T:1873802144   ERROR: CCurlFile::Open failed with code 0 for http://mirrors.kodi.tv/addons/krypton/addons.xml.gz.md5
16:49:04  14.601950 T:1873802144   ERROR: Open - failed to open source <http://mirrors.kodi.tv/addons/krypton/addons.xml.gz.md5>
16:49:04  14.602110 T:1873802144   ERROR: CRepository: failed read 'http://mirrors.kodi.tv/addons/krypton/addons.xml.gz.md5'
Were you using a different skin prior to #0814, or some other configuration?
The cause of the above error (and thus, I believe, the notification) would be that you don't have a functioning network.
My advice would be to disable repository auto-updates (Settings > System settings > Add-ons > Updates).
(2016-08-18, 14:39)ElectricPim Wrote: [ -> ]Still having trouble to use channel 13 for WIFI.
This is most likely a configuration issue with your access point - if your AP is not announcing a country code then the Linux kernel in LibreELEC won't know which channels it is permitted to use so it will default to the most restrictive "global" regulatory configuration (country code 00, channels 1-11).
See this discussion for more details.
Install "Network Tools" from the LibreELEC Repository and you can check if your AP is announcing a country code:
iw dev wlan0 scan
For example my Netgear DGND4000 access point is not transmitting a country code, but one of my neighbours is:
BSS xx:xx:xx:xx:xx:xx(on wlan0)
        TSF: 0 usec (0d, 00:00:00)
        freq: 2462
        beacon interval: 100 TUs
        capability: ESS Privacy ShortSlotTime (0x0411)
        signal: -83.00 dBm
        last seen: 0 ms ago
        SSID: TALKTALK17xxxx
        Supported rates: 1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0
        DS Parameter set: channel 11
        ERP: <no flags>
        Extended supported rates: 24.0 36.0 48.0 54.0
        HT capabilities:
                Capabilities: 0x198e
                        HT20/HT40
                        SM Power Save disabled
                        TX STBC
                        RX STBC 1-stream
                        Max AMSDU length: 7935 bytes
                        DSSS/CCK HT40
                Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
                Minimum RX AMPDU time spacing: 16 usec (0x07)
                HT RX MCS rate indexes supported: 0-15
                HT TX MCS rate indexes are undefined
        HT operation:
                 * primary channel: 11
                 * secondary channel offset: no secondary
                 * STA channel width: 20 MHz
                 * RIFS: 0
                 * HT protection: no
                 * non-GF present: 0
                 * OBSS non-GF present: 0
                 * dual beacon: 0
                 * dual CTS protection: 0
                 * STBC beacon: 0
                 * L-SIG TXOP Prot: 0
                 * PCO active: 0
                 * PCO phase: 0
        Overlapping BSS scan params:
                 * passive dwell: 20 TUs
                 * active dwell: 10 TUs
                 * channel width trigger scan interval: 180 s
                 * scan passive total per channel: 200 TUs
                 * scan active total per channel: 20 TUs
                 * BSS width channel transition delay factor: 5
                 * OBSS Scan Activity Threshold: 0.25 %
        Extended capabilities: HT Information Exchange Supported
        WPA:     * Version: 1
                 * Group cipher: TKIP
                 * Pairwise ciphers: TKIP CCMP
                 * Authentication suites: PSK
        RSN:     * Version: 1
                 * Capabilities: 1-PTKSA-RC 1-GTKSA-RC (0x0000)
        WMM:     * Parameter version 1
                 * BE: CW 15-1023, AIFSN 3
                 * BK: CW 15-1023, AIFSN 7
                 * VI: CW 7-15, AIFSN 2, TXOP 3008 usec
                 * VO: CW 3-7, AIFSN 2, TXOP 1504 usec
        Country: GB     Environment: Indoor/Outdoor
                Channels [1 - 13] @ 20 dBm
        WPS:     * Version: 1.0
                 * Wi-Fi Protected Setup State: 2 (Configured)
                 * Response Type: 3 (AP)
                 * UUID: 63041253-1019-2006-1228-50a72b17f378
                 * Manufacturer: Realtek Semiconductor Corp.
                 * Model: RTL8xxx
                 * Model Number: EV-2010-09-20
                 * Serial Number: 123456789012347
                 * Primary Device Type: 6-0050f204-1
                 * Device name: ADSL Modem/Router
                 * Config methods: PBC
                 * Unknown TLV (0x1049, 6 bytes): 00 37 2a 00 01 20
Another neighbour has thinks he is in America, even though we are both in the UK...
Country: US     Environment: Indoor only
                Channels [1 - 11] @ 27 dBm
However most of the APs that I can "see" do NOT announce any country code, so any connecting (Linux) client will default to regulatory domain 00 (ie. global).
To force a specific regulatory domain/country, you can try (on your LibreELEC client):
echo "options cfg80211 ieee80211_regdom=GB" > /etc/modprobe.d/cfg80211.conf
reboot
(change GB to whatever is appropriate for your location - see country codes)
To see which frequencies are currently supported by your LibreELEC client:
iwlist wlan0 frequency
So for my RPi3, before forcing the regulatory domain to GB:
rpi22:~ # iwlist wlan0 frequency
wlan0     11 channels in total; available frequencies :
          Channel 01 : 2.412 GHz
          Channel 02 : 2.417 GHz
          Channel 03 : 2.422 GHz
          Channel 04 : 2.427 GHz
          Channel 05 : 2.432 GHz
          Channel 06 : 2.437 GHz
          Channel 07 : 2.442 GHz
          Channel 08 : 2.447 GHz
          Channel 09 : 2.452 GHz
          Channel 10 : 2.457 GHz
          Channel 11 : 2.462 GHz
          Current Frequency:2.447 GHz (Channel 8)
and then afterwards once I had forced the regulatory domain to GB:
wlan0     13 channels in total; available frequencies :
          Channel 12 : 2.467 GHz
          Channel 13 : 2.472 GHz
Forcing a specific regulatory domain is not likely to be something that will be implemented or even needs fixing in LibreELEC - if the AP you are connected to is not announcing the correct regulatory domain (ie. country) then the current default behaviour ("global") is entirely correct. In such circumstances you will have to manually configure the regulatory domain/country in /etc/modprobe.d/cfg80211.conf.
(2016-08-18, 17:24)Milhouse Wrote: [ -> ]
No other skin or configuration, I only run update by your .tar file, that all.
I'll try to disable auto-update and report later.
Thank.
(2016-08-14, 20:04)raptorjr Wrote: [ -> ]
(2016-08-14, 18:34)popcornmix Wrote: [ -> ]
(2016-08-14, 18:04)raptorjr Wrote: [ -> ]I'm having some buffering/stuttering problems on some files. Don't know if the Pi3 is not powerful enough, or if there is something wrong with my setup.
The format of the file is fine and you data is arriving over network okay (buffers fill up and remain full).
There are a few PVR/EPG messages while playing like:
17:45:45 684.769470 T:1472197536   DEBUG: EPG - UpdateFromScraper - updating EPG for channel 'VH-1' from client '440135507'
Is it any better with live tv disabled?
If not a sample would be useful (e.g. use makemkv or similar to produce a two minute sample) and upload somewhere (e.g. dropbox/google drive) and I'll test it here.
Thank you. I will try and disable LiveTV and see if that helps.
Haven't tried to figure out if the buffering/stuttering is happening at the same time every time, but will find out and make a sample if it is.
Disable LiveTV didn't help and I'm having a hard time to produce a sample. The problem doesn't occur at any specific point in the video, I only know that it will happen a few times.
Anyway, while continuing through the seasons I encountered a x265 file. I know that there are some problems and limitations with the Pi 3 and x265. But my knowledge is limited about this so I don't really know what files work and don't. This file only plays sound and no video, MMAL. I don't know if it is a bug or just something I have to accept? Works fine in VLC on Windows.
https://www.dropbox.com/s/9cz4sy1300g60m...e.mkv?dl=0
