(2016-08-31, 11:26)ruskas21 Wrote: [ -> ]Hi,
Having problem with kernel panic with my Pi 2 Model B since build #0823 (works with #0822 and lower builds)
Crash seems to be related to Netgear A6100 (rtl8812au) when plugged in during boot or plugged in after successful boot.
Unplugged it works just fine.
Screenshot of kernel panic http://imgur.com/a/la4vK
Hi, I have the same problem with my D-Link DWA-171 stick.
http://imgur.com/a/CM3wI
Lindar
(2016-08-31, 11:26)ruskas21 Wrote: [ -> ]Having problem with kernel panic with my Pi 2 Model B since build #0823 (works with #0822 and lower builds)
Presumably an upstream bug from 4.7.2 kernel.
(2016-08-30, 23:54)mikeb8591 Wrote: [ -> ]I didn't try #613, but it was present in #825, #725, #622 and #611 as well. (I tried those working back to find where the issue started for me.)
Testing #602 with the firmware (start.elf/fixup.dat) copied from #601 and #613 would be useful.
You could also test the very latest build with firmware from #601.
It appears to be caused by the firmware change in #0602, but we'd like to confirm that.
That should have been fixed in #613.
By #725 and later it is always possible there is a different issue that has similar symptoms.
Update to 0830 last night. Honestly it's been a few builds since I tried using the Amazon addon. Now I'm seeing the following in the logs:
ERROR: AddOnLog: InputStream MPEG DASH: Decrypt Sample returns failure!
Before I start going back through builds, is anyone else seeing that issue with 0830?
(2016-08-31, 15:25)zaphod24 Wrote: [ -> ]Update to 0830 last night. Honestly it's been a few builds since I tried using the Amazon addon. Now I'm seeing the following in the logs:
There is more than one Amazon addon...
I'm not seeing a problem here - testing with Amazon Prime Instant addon, UK, #0830.
I played episodes of Lucifer, Mr Robot and Preacher without any issues.
(2016-08-31, 17:35)Milhouse Wrote: [ -> ] (2016-08-31, 15:25)zaphod24 Wrote: [ -> ]Update to 0830 last night. Honestly it's been a few builds since I tried using the Amazon addon. Now I'm seeing the following in the logs:
Yeah, I keep forgetting there are multiple Amazon addons. I am using the plugin.video.amazon-test from Sandman79. Just guessing that the decrypt error is actually from inputstream. Of course I'm in the USA and I've already had to force the Amazon plugin to stay away from Cloudfront since it always throws an authentication error. I'll wait to hear if anyone else using Amazon instant video in the USA is having a similar issue. I've had it happen on both my rpi3 devices.
(2016-08-31, 08:26)Milhouse Wrote: [ -> ] (2016-08-31, 08:17)Sinisan Wrote: [ -> ]Hello !
I've got problems I haven't in previous version (805 I think) : I can't move (chapter jump, or fast forward) in a 3D movie. It "jumps", but only one picture is displayed and frozen, as if it was paused.
Here the log : http://sprunge.us/aKWc
Thank you for your help,
Regards,
Turn off passthrough, any better?
If not, can you identify the exact build when this problem started.
Two things :
- I never found the "Passthrough" option, except regarding System/Audio setup.I can't find any "Passthrough" option regarding video (neither 3d).
- Looking for "passthrough" option, I found this post :
(2016-08-23, 15:51)drdwridav Wrote: [ -> ]A few things I'm observing at the moment - and a couple of queries. These aren't build specific, as it seems the same no matter what version I choose. For info I'm on pi3, 818 build at present:
1. Popcornmix, you'll remember our posts a couple of weeks back about 3D switching and the menu staying in 3D on exiting films? I thought I'd solved this by adding a 1 second refresh rate delay. This does work, but only if OMX is the player. If it's MMAL, gui stays in 3D on exiting. I have found a workaround to change the gui refresh rate. At first I used 23.98 (obviously works as no refresh rate change) but sluggish. Bizarrely a 25.0 refresh rate also works fine though (and is noticeably faster navigating the menu) so that's what I'm now sticking with. Any other combo (e.g 50 or 60) and 3D films using MMAL exit to the gui in 3D. At least I've found something that works for me though!
2. Out of interest what is the current status of OMX v MMAL? What is recommended for a 3D film for example? I don't notice much in terms of PQ, OMX perhaps a tad sharper.
3. What I have noticed though on 3D mkvs is that with OMX film plays fine, but if I jump forward/backwards the movie stops (even though the mins/seconds on play counter continues to go on). MMAL, I can use forwards and backwards without issue.
4. AC3 passthrough (using an external hdmi optical splitter to take optical to old AC3 decoder). Works fine on OMX. MMAL also works, but on codec information, rather than listing speakers as LR, FR...32 bit AC3, for 5.1 it says RAW, RAW, RAW, RAW, RAW, RAW 8 bit AC3. Don't quite understand that (displays it correctly if passthrough disabled).
5. Is there any way of switching between MMAL and OMX - selecting which player to use from the Movies section rather than having to amend system preferences? Doesn't seem to be an option in context menu. I've tried keymap editor and programmed 'switch player' to a remote - this brings up a 'video player (default)' message as a context menu during playback but doesn't seem to change anything on selection.
Happy to debug any of the above if if would be helpful for future builds. All very minor, I think the builds are amazing!
Cheers
I tried to switch off "OMX acceleration", as written in 3 : no more bug. fast forward/backward is ok again.
So, I'm not sure to have already used this option before, it will be hard for me to find when the problem started. Do you want me to do some other tests ?
Thank you;
(2016-08-31, 20:40)Sinisan Wrote: [ -> ]Two things :
Set your settings level to Expert so that you see all settings, and you should see the "Enable passthrough" option in System Settings > Audio. Turn this off, as it looks like you have it enabled:
08:10:23 38.422821 T:1439691680 DEBUG: COMXAudio::Initialize device passthrough 1
08:10:23 38.428131 T:1439691680 DEBUG: COMXAudio::PortSettingsChanged - bits:0 mode:0 channels:0 srate:0 passthrough
Passthrough audio is currently causing an issue or two when seeking, so I wanted to see if disabling passthrough helped you with your seeking.
(2016-08-31, 14:19)popcornmix Wrote: [ -> ] (2016-08-30, 23:54)mikeb8591 Wrote: [ -> ]I didn't try #613, but it was present in #825, #725, #622 and #611 as well. (I tried those working back to find where the issue started for me.)
Do I just copy the files to the 3rdparty/bootloader folder in the 601 tarball, or is replacing these files more involved?
I am having issues with releases since I believe #0823 on my RPi2.
-Skipping backwards now shows buffering window (my wire network is uncongested and optimized - there has never been an issue previously).
-Radio plug no longer streams any audio stations (system hangs then eventually reboots)
This has been the case for some time now. (MMAL being superior to OMX for 3D MKV)
New LibreELEC.tv Krypton build #0831:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.7.2 #1 Wed Aug 31 21:05:39 BST 2016 armv6l GNU/Linux
# vcgencmd version
Aug 23 2016 15:58:54
Copyright (c) 2012 Broadcom
version f23e65aeeffca65654550c93254a0ee55f34fb07 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160831210440-#0831-gec9cf07 [Build #0831]
# vcdbg log msg 2>&1 | grep DTOK
002393.878: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
LibreELEC.tv master (ec9cf077,
changelog) and tip of
XBMC master (f39d849f,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.7.y
- Includes latest bcm2835-driver master (d0bc6ce8)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (fac3a954, ahead +34)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (20c47221, +2), inputstream.rtmp (9c05b8dd), inputstream.smoothstream (b63ecbb4), peripheral.joystick (88d4aab0, +28), pvr.argustv (299088b5), pvr.demo (01c68c88), pvr.dvblink (ea3d98cc), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (48b2e261), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (3c39bd0c, +7), pvr.mythtv (b1b426f3), pvr.nextpvr (4dabcf41), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (bb9c0b10, +10), pvr.vbox (2750c92a), pvr.vdr.vnsi (40c45dc9), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] kodi-999.99-PR10309.patch: Merged upstream
- Exclude [env] kodi-999.99-Revert-PR10247.patch: Not required
- Exclude [env] libcec-PR208.patch: Merged upstream
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: ffmpeg: Bump to 3.1.3-Krypton-Beta3 (e9002c3)
- Include [env] PR:535: init: Add upgrade check to avoid incompatible upgrades [RFC,WIP]
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: drm/i915: Fixes and diagnostics for Braswell (linux)
- Include [pkg] patch: drm/i915: Fix backwards test in Chris Wilson patch (link) (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Limit the depth of the display pipeline to the framebuffer (linux)
- Include [pkg] PR:50: Update to peripheral API v1.1.0: Add function to save button maps (peripheral.joystick)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
Build Highlights:
- Various kernel udpates
- peripheral.joystick updates
Build Details:
- LibreELEC.tv:
- connman: fix DNS ordering (PR:681, 1 commit, 1 file changed)
- kodi: Temporarily revert PR10247 for Kodi 17 beta1 due to OOM (PR:683, 1 commit, 1 file changed)
- XBMC:
- DVDAudioCodecPassthrough: Fix memory leak after (PR:10367, 1 commit, 1 file changed)
- Peripheral API v1.1.0: Fix mapping D-pad on RPi for some controllers (PR:10364, 5 commits, 31 files changed)
- Break out joystick improvements from #10364 (PR:10371, 5 commits, 10 files changed)
- peripheral.joystick:
- [udev] Fix rumble effect failing to play second time (88d4aab0)
- kernel 4.7.y:
- New commits in this build:
- Fix cfg80211 for kernel >= 4.7 (#1624) (34695bb3)
- suppress spurious messages (c7fa6a09)
- Add #if for 3.14 kernel change (#87) (9d2f8b14)
- Set dev_type to wlan (78ec4f93)
- Tentatively added support for more 8188CUS based devices. (1fa47427)
- Add support for more 8188CUS and 8192CUS devices (74c7d5a8)
- Add ProductId for the Netgear N150 - WNA1000M (e20a0c07)
- Fixes CONFIG_CONCURRENT_MODE CONFIG_MULTI_VIR_IFACES (32ebe4bc)
- Fixes compatibility with 3.13 (3f6c4fb6)
- Enables warning in the compiler and fixes some issues, reference => https://github.com/diederikdehaas/rtl8812AU (e09793a6)
- Starts device in station mode instead of monitor, fixes NetworkManager issues (ab6ac7c8)
- Enable cfg80211 support (8bb5b7f8)
- clk: bcm2835: Mark the VPU clock as critical (7cf85896)
- clk: bcm2835: Mark GPIO clocks enabled at boot as critical. (b7d3d626)
- clk: bcm2835: Skip PLLC clocks when deciding on a new clock parent (74746757)
- clk: bcm2835: Mark the CM SDRAM clock's parent as critical (b30022f1)
Newest build still doesn't work with rtl8811au/8812au.
Lindar
hi, the last build #0831 is the best for live-tv, im using tvheadend server+client on Raspberry pi 3(IPTV Playlist) and the switching the channels is perfekt, the build #0831 have a switch time from 0-2 sec.. (the #0829 have 4-7 sec)
can i use the update for kodi 16.1? maybe update kernel in Jarvis?
